Question about Saws
Black and Decker 9" variable speed bandsaw. Overworked it and the thermal fuse blew. Documentation said to turn it off and then turn it back on and it would be alright, but it does not turn back on.
  • bhinkle54 Jun 21, 2009
    Can not locate the fuse. Do not know where it is, but I took a voltage reading across the brushes and I had juice at that point.
  • Smoking Loon May 11, 2010
    Do you have access to the fuse?
    Do you have a multimeter?
    President:
  • 1,996 Answers
Sometimes there's a little reset button on the motor itself, that can be pushed in with a nail punch or something. Look for that....
Otherwise, you may be able to get parts for your machine here, or see a service manual.
Without a model number to work from, I'm afraid I can't offer much more...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 08, 2009
MY BLACK & DECKER D2030 DOES NOT POWER ON?
my black nd decker iron lights up but will not heat.
Jan 01, 2013 | Black & Decker D2030 Iron
Black & Decker Q200 not variable speed now??
if you took it apart to change the chuck you might have disconnected some wire id check that first
May 29, 2012 | Office Equipment & Supplies
There is no power to the unit, the breaker is on, there is power to the plug, but the unit does not work. The clock is also not on
the thermal fuse has blown.
be careful after replacing it because the reason it blew is probably because the unit overheated which means the thermal switch failed (stayed closed)
Jan 24, 2010 | Black & Decker SpaceMaker ODC440B 12-Cup...
Are the thermal fuses near the coil or where the
The thermal fuse should be located near the coil. Usually just below the plate, but that all depends on the model.
I hope this helps! :)
Jan 17, 2010 | Black & Decker SpaceMaker ODC325 Coffee...
Black & Decker KX2000K Heatgun Kit 2000w cuts pout after minimal usage is it fuse blown ??
no its not the fuse in the plug but it could be the internal turmal fuse triping out on you,,,if its getting to hot this thurmal fuse will tip out keep intake vents clean and clear when using the hot air gun,,
Aug 27, 2009 | Black & Decker Black and Decker 1500w...
Same Issues with my Black/Decker 2030
change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside.
Aug 19, 2009 | Black & Decker D2030 Iron
Iron just stopped getting hot
The thermal cutoff device blew and must be replaced. It acts like a fuse when the iron gets too hot. Thay are very cheap and it would be well worth replacing. Hope this was helpful.
George
Apr 16, 2008 | Black & Decker D2030 Iron
Saws Logo
62 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
