Question about Maytag Atlantis MDG7400AW Gas Dryer
Maytag gas dryer-plug glows but flame will not kick on
I replaced the coils and the flame will still not click on unless I tap on the valve or coils-then sometimes it will fire up. Is it my valve? or could my glow plug not be getting hot enough?
    Sergeant:
  • 212 Answers
Gas solenoid bad. replace. not opening up on its own til you hit it
Posted on Jun 21, 2009
No dryer heat
If the coils are bad the unit will light with flame for 4 - 8 times then all of a sudden the ignitor will glow, kick off with no gas coming threw valve. it sounds like the high limit thermostat is short cycling the flame. This is the thermostat that sits on top of the burner chamber. remove 1 screw from the thermostat and blend it upwards away from the heat. Then plug unit back in and test to see if the flame stays on longer. Click here to see maytag dryer no heat posts. Contact me anytime here. Hope this helps..
May 20, 2013 | Maytag Neptune MDG6700A Gas Dryer
Sg7800 maytag dryer stopped giving heat
Sounds like burner not igniting. On front of dryer in the lower right there should be a gas valve/burner access panel. Usually you just have to pry out at bottom of panel & swing out and up to remove. This gives you access to valve coils and igniter. With panel removed set timer for heated dry and start dryer, observing first the igniter which should glow bright orange-red, then after a couple seconds you should hear a "Click" which is gas valve opening and a blue flame ignites for heat. If no glow is seen after a few seconds or at least a minute, igniter is bad, if it does glow and no click is heard from the gas valve, the coils (electro magnets) on the valve are bad, or the "Flame present" sensor is bad. Chances are it's either the coils or igniter.Try this on all heat settings, if you get heat at only one setting it might be in timer contacts, but not common. Again you can repair/replace both the igniter (usually just plugs into a receptical) and the coils (2 donut looking objects on the gas valve, replace both.) Access door may be on back if not on front, but normally their on lower right of front.
Feb 13, 2011 | Dryers
I have a Maytag LDG 4000 gas dryer with electronic ignition. The igniter glows, but does not ignite the gas. I can not smell any gas, so I'm assuming a valve of some sort, internal to the dryer, is not...
Igniter glows - No gas ignition. If the igniter heats
up but the main burner flame is not ignited, remove
power and using an ohmmeter, check the following:
• Open secondary coil
• Open holding coil
• Open wire harness
• Stuck flame sensor (Stuck closed)
Most likely bad gas valve coils.
Sep 07, 2010 | Maytag MDG4000 Dryer
Gas maytag dryer not heating up
check the thermal fuse in the dryer vent duct to be open,then if not the flame eye" radiant sensor" or the high-limit thermostat both on the burner tube if the sensor doesn't see(sense) a flame the gas valve will stay shut,then check the gas valve coils,both the BOOST and SECONDARY coil valves on the gas valve body as these can open up and not gas into the burner
May 04, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Mdg 4000aww turns on and heats when started. runs for 5 five minutes then flame goes out. ignitor glows but no flame. one minute later dryer still running ignitor glows, no flame. this repaets until turned...
Either the venting needs cleaned or the coils on the gas valve are bad. Unhook the venting from the back of the unit and run. If works ok then clean venting. If you still have the problem, replace the two coils on top of the gas valve.
Sep 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas neptune dryer fires up for 45 sec. to 1 min, then goes out
Could be a couple different things,Possibly a thermostat or high limit that is kicking out too soon,also has a flame sensor next to the burner that can come and go.if you have a toggle switch or pushbutton switch you can unplug the unit take the two wires off the flame sensor (black box about the size of a cigarette pack on the left of the burner)plug them into the switch start the dryer Turn the switch on till the igniter glows bright,turn the switch off and the burner will light if it stays lit at least till it gets to temp replace the flame sensor.(It won't cycle with out flipping the switch each time)
Sep 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
The glow plug just lights up but no flame on my maytag mdg 5500aww
If the ignitor is glowing but the gas does not light check the flame sensor. If it is OK then the gas valve coils may have to be replaced.
Aug 12, 2009 | Dryers
My Maytag model # mdg6000bww doesn't heat up?
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Jul 18, 2009 | Maytag MDG2600BWW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
220 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
