Question about Carrier Heating & Cooling
On a split unit the contacts are closing but compressor wont come on or the fan what could be the problem
  • 284 Answers
If you have access to a multi meter tester you need to check the voltage at the top of the contactor you hear and at the bottom with the contactor closed should have 240 volts ac (+ or-) top and bottom (Line and Load)
if you have voltage at the top and not at the bottom replace contactor or check for debris in the contacts and remove --also check for blackened or burnt contacts also(shut off electric first)
check your circuit breaker for your outdoor unit from the house panel for on position and it may be labeled a/c unit or outdoor unit
check the box near your outdoor unit for a breaker off or tripped or if you have fuses check to see if they are good with a contiuity tester, Again with the power to be off in doing so.
if fuses are good you will have continuity across them( a reading) if not no continuity(no reading fuse bad)
Posted on Jun 21, 2009
I meant the AC does not cool
Make sure the mode is set to freeze and temperature is set to below the room temperature.
If it is a split system, check the outdoor unit whether it is running. If it is running, see if you can reach and feel the temperature of the pipes connecting between the indoor and the outdoor unit. It should be cool.
If it is not cool, you may need to get somebody to check the refrigerant.
May 22, 2014 | Dometic 57915531 Air Conditioner
LFTR1814LW4 - unit runs, however, it wont get cold. Looking to purchase this unit from someone who is selling. I believe that it is just the thermostat. Any other possibilities?
There are many possibilities, from simple to expensive. It could be a low refrigerant problem (leak) to a burned out compressor or anything in between. A running compressor cant be all that bad. Saying it runs means nothing. The fan blowing has nothing to do with the compressor. If you believe it's the Tstat, just short the compressor wire (yellow) to the red wire at the Tstat and it should work. Not sure if it's a split unit, but a defective run capacitor will prevent the compressor from operating
Aug 27, 2013 | Heating & Cooling
Hunter thermostat 44110
This sounds like a split system, the condensing unit outside and the evaporator coil and fan inside. You must be referring to the indoor fan, since the compressor and outdoor fan are controlled by the same contacter. The indoor fan relay contacts sounds to be welded shut, and needs to be replaced.
Aug 24, 2013 | Heating & Cooling
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
Ac unit wont come on the breaker was tripped, reset the breaker, checked the unit for 220 volts has the correct voltage. The unit is a split system heat on one side ac on the other. The blower motor wont...
hello
maybe you have over current .compressor act over loud.
you wait was cooled compressor .than start again and check current and over loud and condenser fan.
Sep 06, 2011 | Friedrich WallMaster WS07A10D Air...
LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
Indoor unit freezing up
THE OUTDOOR UNIT HAS A CONTACTOR WITH THE CONTACTS WELDED TOGETHER THE CONTACTOR CONNECTS TO THE COMPRESSOR AS IT TYPICALLY PULLS A SURGE OF 20 -30 AMPS OR MORE..WITH THE INDOOR UNIT IN FAN ONLY THE COMPRESSOR SHOULD NOT BE RUNNING. THE CONTROL WIRES GOING TO THE UNIT HAVE 24 VOLTS TO THE CONTACTOR TO PULL IN THE CONTACTS TO SUPPLY 220 TO COMPRESSOR.
Mar 09, 2010 | Heating & Cooling
York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Oct 21, 2008 | Sanyo 09KS51 Mini Split Air Conditioner
Aou18c1 not shutting off
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Sep 12, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
105 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
