Question about Roper Refrigerators
Does not hold temperature, warms up.
We transported the fridge on its side for about 10 minutes, left it outside upright over night (maybe 12 hours) and got it into the house and plugged in. It did not cool properly, the freezer did not freeze, the other part not below about 50.
After talking to some advisers, we unplugged it for 24 hours, and plugged in again. For several days it went through cycles of: freezer down to 20 degrees, hot to the touch on the outside of the fridge; freezer up to 50, cool on the outside of the fridge. The main part oscillated between 40 and 70. It deteriorated, now neither part can get cool, we have it unplugged.
This fridge did function without problems for years up to our moving it.
    Sergeant:
  • 212 Answers
If you hauled on its side then it is very possible you have oil in evaporator. replace all sealed system parts. compressor, drier and evaporator.
Posted on Jun 21, 2009
Can I transport one of your 2 door Fridge/ freezers laying on its side.
only transport a fridge or freezer on it's side if the upright transport is NOT an option.
any chiller using compressed liquid/gas and placed on it's side should be left for 24 hours to settle before powering at the mains, this will allow the coolant time to sink where it should be and prevent the pump (& chiller) from failing.
Nov 23, 2017 | Refrigerators
Just got a new fridge yesterday it's not cold yet or freezing
if it was transported upright it should be fine , if layed down even for a few minutes it has to be left unplugged for at least 12 hours , for the oil in the compressor to come back down .
Nov 18, 2016 | Refrigerators
My fridge knocks when running
Your fridge's compressor motor is suspended inside the compressor housing on three or four springs. These springs are designed to hold the motor load in a vertical position. Transporting a fridge on it's side can stretch or break these springs which can cause a shudder stop condition (the fridge makes a shuddering banging noise everytime the compressor stops and sometimes when it starts).
It's a good idea to let a fridge sit for a bit anytime it is moved. Over night won't hurt but an 8-10 hours is more than enough time some say less.
the internet consensus seems to be that you should limit the amount of time the unit is not upright. And as stated above, leave it upright at least overnight before starting it. Apparently damage can arise from mixing of lubricant and coolant, so damage is more likely in an older unit with worn seals.
Apr 11, 2015 | Hotpoint HSS25GFP Side by Side...
I moved a fisher and paykel upside down fridge freezer to a new house, I turned it on a half hour after it was in my new home but it has not gotten down to a cold enough temp, if I turned it on too so
It is possible damage will result. Your fridge's compressor motor is suspended inside the compressor housing on three or four springs. These springs are designed to hold the motor load in a vertical position. Transporting a fridge on it's side can stretch or break these springs which can cause a shudder stop condition (the fridge makes a shuddering banging noise everytime the compressor stops and sometimes when it starts).
It's a good idea to let a fridge sit for a bit anytime it is moved. Over night won't hurt but an hour is more than enough time.
Jan 18, 2015 | Fisher and Paykel Refrigerators
After plugging in refrigerator, compressor not running correctly (educated guess) runs for 10 seconds exactly, off for two minutes and keeps repeating this cycle continuously. Top of compressor warm
Not likely a defrost timer issue, but I suspect (1) a low refrigerant charge (2) If the fridge has been on its side, it should remain unplugged and upright for 8 hours before powering up or (3) If the ambient air temperature of the space it is in (garage, etc. or any place where it below 45 or so degrees), the refrigerant has likely migrated to and flooded the compressor. There's too much liquid refrigerant causing the compressor to slug. Allow the ambient air to warm before attempting to power up the fridge - or you could damage the compressor and lose the refrigerant charge.
Feb 25, 2014 | General Electric GDSL0KCXLS GE Energy Star...
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
Freezer temp on GE profile French door fridge was rising rapidly. I believe I did not shut the freezer door tightly after retrieving something about 9pm. Outside of freezer on sides of fridge was very...
This is by design. It should be warm. This is where the heat exchanger is located to save space.
No worries.... right now it is being over-worked until it reaches operating temp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Cool down period for plasma TV for transport.
I believe 20 minutest just enough. But when you bring it back from cold outside to your new home it have to stay/warm 2-3 hours before you plug it in.
Dec 18, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Can I transport a whirpool side by side refrigerator / freezer, laying it down on it's side for 5 hours?If when I reach my destination I stand it upright for 48 hrs. before I plug it in.
The short answer is yes, but the key is to make certain not to plug in and start the fridge for at least 24 hours once it is upright and in the final location.
The reasons manufacturers caution against transporting/moving a fridge on it's side also has to do with the possibility of damaging the doors and hinge plates. The big reason is because people tend to want to start filling up their new fridge with food right away, so they plug it in once it's in their house.
If a fridge has been shipped on its' side, the compressor oil tends to wick/flow into the piping and can cause a failure, if not allowed to drain back into the compressor when the fridge is placed back upright.
Although not the best way to transport, you can do it if you allow time for things to settle back before powering it up.
Jul 17, 2009 | Dometic RM2193 Compact Refrigerator With...
Is it okay to transport a new fridge on its side or back?
The key here is that you must let the unit stay upright for a period of time BEFORE you plug it in. So, yes it is ok to transport it on its side. Let the unit sit in its correct position for 4 hours or so and you should be fine. The issue is the oils and freon (or equivalent) that must be allowed to pool in the bottom before you attempt to run it.
Dan
Nov 11, 2008 | Kenmore Refrigerators
Refrigerators Logo
144 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
