Question about Amana Comfort Zone 18M33PCEH Air Conditioner
Not heating Unit works on cooling mode, will not work in heating mode..blows cold air.Does reversing valve have a seperate coil or built in
    Scholar:
  • 41 Answers
I'm a Certified HVAC Technician and have been working in the industry since 1996. I totally agree with Rob. But, I'm a bit confused in that I have read "Problem with Amana Comfort Zone 18M33PCEH Air Conditioner" but then I read "Not heating
Does reversing valve have a seperate coil or built in"
First of all, an AIR CONDITIONER does not have a "REVERSING VALVE" - only a HEAT PUMP has a REVERSING VALVE. If the THERMOSTAT was REPLACED, did the ORIGINAL COLORED WIRES and ORIGINAL TERMINALS get RECORDED onto a piece of paper? It is imperative that the CORRECT COLORED WIRE within the Thermostat is CONNECTED to the "O" which, on MOST HEAT PUMP Thermostats is the REVERSING VALVE and, in MOST cases is the ORANGE wire. In every HEAT PUMP system that my company has installed, I have directed all of my technicians to use the STANDARD wiring COLOR Codes, regardless of WHAT was previously used. That way, when another HVAC Technician is called, he or she can easily troubleshoot and reduce the amount of time spent on the Service Call, thus saving the homeowner $$$ in the long run. Good Luck!!!
Posted on Sep 20, 2012
  • Ed Riggle Sr Sep 20, 2012
    By the way, for MOST Heat Pump Thermostat/System wiring, the following is the "TYPICAL" COLOR WIRING DESIGNATIONS:
    R = RED = + 24Volts DC from the Transformer ... Y = YELLOW = COMPRESSOR ... G = GREEN = FAN (INDOOR FAN) ... W = WHITE = HEAT ... O = ORANGE = REVERSING VALVE ... C = BLUE = COMMON ... E = BLACK = EMERGENCY HEAT ... And their are SO many OTHER variations ... i.e., W1, W2, RC, RH, Y1, Y2, etc, etc, etc .... again, Good Luck!!!
    Sergeant:
  • 288 Answers
Yes, the reversing valve has a separate coil. some energize on cool mode, some on heat mode. Has the thermostat been replaced? I find this a common mistake.
Posted on Nov 04, 2007
In AC mode the cooler fan doesn't turn on and after a little while the warm air starts to blow instead of cold air. Any ideas
Sounds like a bad or stuck reversing valve. Typically r.vs. are energized in cooling, verify 24 volts to valve, if yes , bad valve
Sep 30, 2016 | Whynter ARC-14SH ECO-FRIENDLY 14000 BTU...
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
My Home AC blows hot air
You need to check to see if you have 24 volt signal from thermostat to your reversing valve. To go into cooling mode the reversing valve needs to be energized. Orange is normal color of the reversing valve power supply. On your unit will be a reversing valve which looks like a pipe with 3 pipes attached to one side and 1 pipe attached to the other side. On the side of the the reversing valve will be a coil with a 2 wire connection. This coil needs 24 volts applied to shift unit into cooling mode. In your thermostat wire bundle where it is connected, check for voltage between common and the orange wire. If it does not have 24 volts with the thermostat in cooling mode, you have a break in the line normally a connection on the orange junction inside your air handler or your thermostat orange wire is loose. Keep checking for 24 volts available until you find the source of the loss. If you have 24 volts at the reversing valve, you can check to see if the valve is working by unplugging the 2wire connection on the side of the valve, if it clicks its powered if not and 24 volts available then the coil needs replaced.
Any more than this you will need a professional tech to troubleshoot and fix.
Hope this helps.
Jun 21, 2014 | Goodman CLQ36AR49 Air Conditioner
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Using heater...cold air out of the back
With heat pumps that's the way they work. In heat mode they are using the evaporator as the condenser and it blows heat out the front and cold out the back. In cooling mode, a reversing valve switches the gas flow reversing the operation of the coils and it blows cold out the front and heat out the back.
My mistral reverse cycle mss25ss model does not work at all in heat mode. what would be broken?
firstly is the air comming from the outdoor unit cold or warm? if it is cold then the 3way valve is working and it has changed to heating. If it stays warm then it is still in cooling mode. The indoor fan wont come on until the coil temp gets warm enough, ( so it doesnt blow cold air on you straight up). If it is changing into heat mode then the larger of the pipes connected to the outdoor unit should get warm/ hot. If this is not happening then the unit is either out of gas or the compressor is on hollidays and wont come back to work.
May 22, 2012 | Heating & Cooling
Indoor fan blowing cold air when on heating
The indoor fan will continue to run. When heat pump goes into defrost the outdoor fan stops, the reversing valve switches and the unit is basically working in the cooling mode. In order for you not to feel a blast of cold air in the winter the electric strip heat also comes on so the indoor fan must run while the strip heaters are on.
Jun 03, 2010 | Heating & Cooling
Hi, I have a wall mount midea split a/c model- MSG-36HR that will only heat. when put in cool mode it only blow's room temp air and the outdoor unit won't run. On heat mode it works normally. I have cycled...
Most heat pumps are 'fail-safe to heat'. That is: the normal position of the valve which reverses the function is in the position which provides heat. The reversing valve must be powered to switch to the cooling position.
Although the lack of valve function could be a mechanically defective reversing valve - it's more likely to be an electrical issue. Start with checking for power at the reversing valve's coil. If it's powered unpower it - you will be able to hear the reversing valve distinctively
Oct 03, 2009 | Midea Heating & Cooling
Heat Pump and fan work fine, but will not blow cold air on AC setting
The reversing valve coil may be bad or no power to it during cool. Most heatpumps are set to have the coil of the reversing valve energize in the cool mode. The heating mode is the fail safe mode if the rev valve fails to energize. Check this and let me know.
Jun 18, 2009 | Dometic Rooftop RV Air Conditioner
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Amana Comfort Zone 18M33PCEH Air Conditioner Logo
410 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
