Question about Ariens 34 In. Zoom Series Riding Mower
Older model Ariens ride around lawn mower - drive belt slips off
Ariens 927 Series - Model Number 927041
For no apparent reason - no stress or engine slowing or turning, even on flat grade - the drive belt to the gear disk from the motor shaft slips off the idler wheel - after about 10 minutes. It can be slipped on very easily but does not stay on. It is a major nuisance to turn the whole mower up or over to reposition the belt.
    Problem Solver:
  • 19 Answers
It could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Posted on Jun 23, 2009
How does the drive belt go around the pully system on an Ariens lawn tractor
Go to this site:
http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=0.5721913612416231&Site=ARIENSS
Aug 02, 2014 | Ariens Garden
How to relace drive belt on ariens tractor a20va46?
There are multiple belts on the Ariens A20VA46 lawn tractor. Which belt are you asking about?
Service and Owner's manuals can be downloaded from the following link: Find Manuals by entering your tractor's model and serial numbers.
The deck drive belt is easy to change by releasing spring pressure on the idler pulley (usually under a plastic cover). See the user's or service manual for directions from the above link.
The two transmission belts are somewhat more difficult, but are usually long-lasting. The newer type of continuously variable transmissions used on these tractors have a friction belt like a snowmobile but under much less load. As a result, they are long-lasting. The engine to transmission belt is a conventional V-belt and may require occasional replacement. Usually, there's a similar tensioner pulley you would release in order to replace this belt.
Jul 14, 2014 | Ariens 34 In. Zoom Series Riding Mower
I have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or jackssmallengines.com
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens 34 In. Zoom Series Riding Mower
Where can i get an ARIENS drive belt, new or used
Anyplace that sells Ariens mowers will have one. Most other lawn mower stores can also sell you one. Remove the old belt and take that and the model Airens you have to get a replacement. You do not want a used belt just get a new one.
May 01, 2010 | Ariens 34 In. Zoom Series Riding Mower
Cant find the PTO deck belt for a Ariens Sport Zoom Model 915031-1232. Ita a zero turn mower. The manual calls for belt # 07242700 cant find it anywhere! Help.....
I own this model as well. The manufacturer issued a "cutting improvement kit" for this model number. The belt number has changed as well. The number you now need is # 07242200
I am in the process of ordering one for mine right now. Good luck!
Apr 14, 2010 | Ariens 34 In. Zoom Series Riding Mower
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
Parts for Ariens Model Number FM626E
you need to get the model number from the mower body and verify that it is correct the age should not matter some hardware stores work primarily on ariens mowers hope this helps
Apr 03, 2009 | Ariens 34 In. Zoom Series Riding Mower
Battery cables hooked up backwards on ariens model 927041
You may have blown a fuse. Follow the wires from the ignition to the battery and look for the fuse housing also from the starter to the battery. There may be more than one fuse so look good. If all your fuses are ok then it's possible you may have fouled the battery in which case it's time for a new one.
I'm a little worried that the smoke you saw was coming from the starter moter in which case you may need to replace but there should be fuse to protect it so let's not worry about that yet.
Hope you get it running but if not post back and we will figure it out
Sean
Mar 13, 2009 | Ariens Garden
Ariens 34 In. Zoom Series Riding Mower Logo
1,728 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
