Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Roller not turning when I drag vacuum across the rug. Got something caught in it, pulled it out, then stopped working properly.
  • 4 Answers
Check the belt and what got stuck in it
Posted on Jun 21, 2009
I had the same thing happen and when I removed the bottom plate on the bottom (there are three plastic screws to turn and the plate slips off) I found that when I got the thing caught and pulled it out it broke the belt and that was why the beater bar brushes didn't turn.
Brushes will not turn on oreck xl classic. caught rug in vacuum and then it will not turn..is there a reset button
If the motor is running but the brush roller is not, then the belt is probably snapped or burned through and needs replaced. If nothing is running when you try to turn it on I would recommend taking it to a service center because you may have burned out the motor. If it is just the belt, that is something that you can do yourself.
Jul 03, 2014 | Oreck Vacuums
Miele seb 213 quit spinning on rug
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first let's focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Miele replacement parts for your Miele Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 14, 2013 | Miele SEB 213-2 Vacuum
I need instructions on how to change the belt on my Hoover Model U4264-930 vaccum.
Tool Needed, flat head screwdriver (larger one works a little better). Serious Safety Precaution: Make sure unit is unplugged. Preliminary: Check: that nothing is caught like threads etc, preventing roller brush from turning. I've had this model vacuum 10 years and have pulled threads out countless times. However it still has the original belt on it. To change belt: 1.) There is a plastic plate underneath roller, towards front.. Pry the 3 tabs at front, the plate hinges downward slightly (to clear the front tabs). Next, there are 2 little clips at bottom of plate. Insert screw driver at each of these clips to fully release the plate the rest of the way. (Or it may even come off without having to pry back on these. The plastic clips need pushed towards front, to clear the ridge that catches towards the back). Pry one, then the other, clip forward, while gently pulling the plate the rest of the way out. (Gentle prying will assure it will snap back together OK, so you still get a good seal.) You now should see the whole roller brush. 2.) Remove the shell/motor cover: To do this, a.) pull off the rug height adjuster lever, and take not where you put it so you won't loose it. b.) push foot release down and keep vacuum bag in the vacuuming/hinged/operating position (not the upright/locked position), and position cleaner on it's side, or upside down. c. Pry around the bottom edge, starting at right corner, then go around, prying in about 4 different places. Shell/motor cover will now easily pull off (upward and out towards front), exposing motor shaft and light bulb. 3.) remove belt from motor shaft. 4. slide roller and old belt out the bottom. 5.) remove old and place new belt on roller 6.) slide roller back into place. 7.) wrap other end of belt on motor shaft. 8.) shell cover, rug height adjuster knob, and bottom plate snap back into place. check that roller turns without much effort. 9.) It now should be ready to plug in and vacuum.
Aug 21, 2011 | Hoover Soft Light Supreme U4262-930 Bagged...
My sd40025 dirt devil ..it is not a upright. it is the follow along, bagless vacuum. has wonderful pick-up but the brush stopped spinning when i was vacumming my rug..i love this vacumm but it is only the...
That's because you got something caught in the brush and it tore the belt (likely) or slipped off the drive portion of the motor (unlikely).
If you look at the bottom where the brush is, there are a bunch of screws to remove the bottom cover usually and can access the belt and motor to run the brush. \
belts are usually 5 to 10.00 get a pack of 2 if possible and don't do heavy rugs or get material caught in the brush lest it will happen again.. typically you can find vacuums in the trash and remove their belts, usually is only 2 or 3 types of belts so get one for free perhaps from trash.
Nov 23, 2017 | Dirt Devil SD40020 Bagged Canister Vacuum
While using the power mate rug part I caught a small rug and the vacuum would no longer pick-up .
Check to see if there is a reset button on the head. This protects the machine for times like you described. When something jms up the reset button will turn ofdf th machine. Simply push the reset. Hope this helps, Chris
Feb 07, 2011 | Kenmore Vacuums
I ran over a big floor rug with my vacuum and some of the strings from the rug got tangled in the roller on the vacuum. It makes a terribly loud noise even now after I have cleared the strings from the...
You will need to pull the roller out and clean it. I think some of the strings are tangle up at the end of this roller. (Most rollers will come apart at the end for cleaning.) Make sure that the strings are not tangle up on the belt pulley as well. I hope this will help you.
Jan 25, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
When I put the vacuum in position to use on rugs, it makes a horrible grinding noise like something is stuck.
Hi If the Dyson model you have has a protected brush model (i.e. roller wheel at the side that goes up automatically to turn off the brush roll) then the belt will have to be replaced by a Dyson engineer. If its not that model and doesn't have the brush roll stop function, check that the roller beater bar and the brush are properly aligned, also checking the main dust channel isn't clogged.
Feb 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
String caught in end of rug brush
This pdf file should help you - there are instructions in it for removal of the roller.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0412323.pdf
Rate if this helps :)
Feb 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Bottom roller bush does not spin
Sounds as if the v-belt came off the idler arm or you broke the v-belt. Either way, take the 4 screws out of the plate around the roller brush and make certain the belt is there and that it sits on the idler wheel. If you remove the roller brush you'll see the wheel. Pay attention to how the ends of the roller brush go back into the vacuum when inserting it and put the plate back on. Also check the thicker main belt is in place as well, it's to the left of the v-belt.
Also, the roller brush should stop when you put it in the upright position. Next time just stand it upright so the throw rug doesn't get drawn quite so far into the vacuum.
Dec 19, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Roller brush on vacuum will not turn
This other than it's capabitlities to clean is a very fragile product for this reason. Everytime you get something wrapped around the rollers it quits allowing the roller brush to turn. My repair guy says it is in the switch on the handle it causes some sort of short or something. Everytime it happens it costs me $45-50 to get it repaired the first time it was still under warrantee next time I'm just going to buy something with a better track record and a longer warrantee. I think Dyson has a five year warrantee.
Oct 05, 2007 | Hoover U8145-900 Savvy Bagless Upright...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
333 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
