Question about JVC PD-42WX84 42 in. HD-Ready Plasma Television
JVC PD42WX84 Plasma TV. blinking blue power lights--nothing else
JVC PD42WX84 Plasma TV. Worked fine for 2 years--then lost picture and sound (no light on screen at all) and blue power lights on front of both display unit and receiver unit blink at about 1/sec. Unplug and replug----starts off until TD relays click in and then blinking power lights begin again.
Display unit problem? or Receiver/tuner unit problem??
Thanks
  • rbecker1 Jun 21, 2009
    Thank you----I concur!
    Genius:
  • 1,847 Answers
From the information you have provided I can say there is a good chance the problem is a failed power supply. Likely caused by bad capacitors. I would expect this repair to be about $350. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly. Small TV repair shops will often charge less than a large repair facility.
Thanks
Kindly rate the answer
Kevin
Posted on Jun 21, 2009
    Sergeant:
  • 326 Answers
Sound like you have a problem w/ your tuner or your unit in had protect itself
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Jvc no power when plugged in
you tube might have blown ouy that's a big problem.Next time make sure you plug your TV in a surcharge protector
Nov 12, 2012 | JVC LT-37X898 37 in. TV
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Aug 13, 2009 | Televison & Video
JVC LT-32P679 Blinking Power Light, Automatic Shutoff
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Mar 17, 2009 | JVC LT-32P679 32 in. LCD TV
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first
Jan 28, 2009 | JVC LT-42X579 42 in. LCD TV
No picture or sound, just blinking power light
Hi...I am sorry to say that I had this exact problem. It ended up being the upper and lower panel drives. I contacted Hitachi and even though my unit was out of warranty, they agree to pay for parts. I paid for labor myself, and it cost me $199.95.
Good luck with it...let me know how it turns out for you.
Aug 10, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
"Fan lock"
Use the below link to locate ur nearest service centers ...
its an hard ware cognitive factor u alone cant rectify it ..
http://maps.jvc.com/cAscList/index.asp
Dec 23, 2007 | JVC HD-56FN97 56" Television
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
JVC PD-42WX84 42 in. HD-Ready Plasma Television Logo
264 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
