Question about Jensen 8.5" Overhead DVD Player Package (MVB85) Car Monitor
Our Jensen overhead dvd player wouldn't eject the dvd (finally got the disk out), now the screen is black.
  • 578 Answers
You have a a problem with unit best solution replace unit short out in one of it circuit
Posted on Jun 27, 2009
Have a Jensen UV8 That will not eject the disk any ideas?
Yes, I have a Jenson UV8 that not eject the disk any ideas?<!-- from fixya rte -->
Jul 29, 2010 | Audiovox UV8 Car DVD Player
When I turn on the player, it states its "reading" a disc, then states "No Disc", but it wont accept a new disc. When I push "Eject" the screen states "No Disc", but I believe one is in there
Machine needs to be taken apart and adjusted on the disc drive belt,
let us know if we can assist you in anyway, if sent to us
estimated repair cost $20-$29.00
Nov 23, 2009 | Jensen 8.5" Overhead DVD Player Package...
CD does not eject from my VM 9410 Car DVD Player
it probably got jammed in there what you can do is unplug the power source and replug it back in a brief power push should eject the disk. make sure you have your unlock codes as the unit may think it got stolen if you undo the power. if that does not work to get it fixed around $89 bucks Thanks and please rate
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 18, 2009 | Jensen VM9410 Car DVD Player
DVD will not Eject
answer - had the same issue turned out to be 3 dvds in it, Remove the 4 screws holding the dvd player to the roof. wire harness will hold it up. There is an fm transmitter on top held on by three screws. remove the little screws and push the transmitter to the side. you winn now see the stuck dvds. push the extras out with a small screw driver. once they are out the eject button will eject the last dvd.
just worked for me hope this helps.
Jul 04, 2009 | Jensen 8.5'' Overhead DVD Player Package...
Jesen touch screen player new will not play cds or dvds , it will scan the disk and in a moment will promptly eject the disk . is this a factory recall?
My first question is: Has it ever played CDs? If not, it try using factor CD's and NOT Burnt ones.
I also recommend taking the cover off the player and use rubbing alcohol and a cotton swab and clean the glass laser eye. They tend not to read when they are dusting.
If the player is going to work, it will after the suggestions I just made. Otherwise the laser or laser motor may be faulty.
May 22, 2009 | Jensen Car Audio & Video
It takes multiple times for the DVD player to accept DVD
your ganna have to buy a dvd player lense cleaner disk you can get them from wal-mart or online for cheaper but it sounds like the lasers lense is dirty
Mar 29, 2009 | Sanyo DVW-6000 DVD Player/VCR
DVDS stuck in overhead DVD player
the motor will not be strong enough to eject. you can try the emergency eject hole with a paper clip . just push straight in and the gears will began to turn so push straight in a couple of times and it should began to eject.
Dec 13, 2008 | Jensen 8.5'' Overhead DVD Player Package...
Jensen 9410 will not load or eject
i had my jensen three weeks everything was okay until all of sudden the unit wounld not load or eject CD's or DVD's
Mar 20, 2008 | Jensen VM9410 Car DVD Player
Jensen MVB85 A8.5 dvd player
Problem: All DVDs would not play in Jensen MVB85A overhead 8.5 DVD player. Error code: "Incorrect Region Code"
FIX:
1. Use the remote to power on DVD player
2. Ensure there are NO DVDs in the drive
3. When you see the DVD logo screen, press 9653 on the remote
4. A hidden menu will open stating the region code. My region code was set to 0 and my I was receiving the error.
5. Press the "OK" button to change the Region Code to "1".
Once the region code was set to 1 all DVDs were playing.
Key words: Jensen Audiovox MVB85 incorrect region code
Nov 13, 2007 | Jensen 8.5'' Overhead DVD Player Package...
A broken screen
I just pulled a nearly new one out of our Expedition prior to trading it in. I have the unit only with remote. No mounting braket and I kept the headphones for our new vehicle. Will consider all reasonable offers.
Jun 08, 2007 | Jensen 8.5'' Overhead DVD Player Package...
Jensen 8.5" Overhead DVD Player Package (MVB85) Car Monitor Logo
653 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
