Question about Nikon Cameras
My Nikon coolpix camera lost it's charge very quickly after recharging the battery. I replaced the battery. The problem still exists with a brand new battery. What could be causing the camera to drain the battery? What other problem could it be?
  • 13,433 Answers
Try a higher mah battery for example 2500 mah.
if the problem is still there the issue is most likely on the mainboard of the camera, draining too much power, the camera would need to be serviced.
http://www.advancecamera.com/repair
depending on where you live, you can get a free repair estimate from the above website.
if you are on the warranty perioid contact nikon directly or your dealer.
Heres another repairer, I don't know where this guy is at but I think he will provide a free repair estiamte also.
http://www.digitalcamrepair.com/
Posted on Jun 21, 2009
Nikon Coolpix L110. Less than a month old. Keeps saying "batteries exhausted" even with brand new batteries
Are you using good quality batteries? Cheap supermarket batteries (usually zinc carbon) tend to be weaker than quality alkaline batteries. Look for alkaline batteries with the code "mn1500" somewhere on either the battery or the packet. Also, rechargeable batteries can vary between brand in that some hold less charge for less time than others. So look for the code "2000" or "2500" on the pack if you want to use rechargeables. Many cameras use only 2 AA batteries and it takes a lot of power just to start them (charging the flash and extending the lens etc.) and need a good battery for them to work.
If this doesn't solve the problem (I think it should) then you may want to return the camera and have it replaced under warranty.
Hope this helps.
Jan 20, 2011 | Nikon COOLPIX L18 Digital Camera
How come the battery will not charge AT ALL
The rechargeable battery needs to be replaced, or there is something wrong with the charging circuits. If the charging light is working it means the circuits are okay, the battery needs to be replaced. If not sure! take it to a camera shop for a quick check.
Jan 14, 2011 | Nikon Coolpix S4000 Digital Camera
My Nikon Coolpix S3000 says battery exhausted, but when I plug into charge it won't charge. Any suggestions?
The rechargeable battery probably needs to be replaced, I would take it to a camera shop let him have a quick look to make sure the charge light is coming on and try a new battery.
Jan 14, 2011 | Nikon Coolpix S3000 Digital Camera
Camera shuts itself immediately after starting it
Did you try using the coolpix batteries that came along with the camera? check the ratings on coolpix batteries and compare them to the batteries that you are using now.
Mar 23, 2009 | Nikon COOLPIX L10 Digital Camera
Battery exhausted
I found this happening until I decided to change to re chargeable batteries and havnt had this problem since.
Aug 19, 2007 | Nikon Coolpix 3200 Digital Camera
Drains my batteries too quickly
I would purchase new set of rechargeable batteries(good brand because they are cheap) and see if the batteries were going bad. If the problem still persist, 4600 main circuit is not good. Time to reward yourself with brand new digital camera.
Mar 14, 2007 | Nikon Coolpix 4600 Digital Camera
Coolpix 2200/3200 Battery Compatibility
The Coolpix 2200 / 3200 camera is designed to use 2 (two) AA type batteries. Due to Nikon’s advanced power management technology, two standard AA Alkaline batteries can provide more than 100 photographs. For better performance, please consider using Nikon EN-MH1 rechargeable batteries. These are available as an optional accessory at Nikon dealers and at The Nikon Mall Recently a new type of battery, the CR-V3, has been released to the market from several battery venders. The CR-V3 is similar in shape to two connected AA batteries and easily fits in your Coolpix camera compartment. Nikon has confirmed compatibility only with the following battery brands. Please use one of the following brands when using CR-V3 type batteries. Duracell Sanyo Panasonic Due to it’s unique design the Eveready Energizer® brand CR-V3 battery may not be compatible with the Coolpix 2200/3200 camera.
Aug 30, 2005 | Nikon Coolpix 2200 Digital Camera
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Cameras Logo
24 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
