Question about Acer X193W LCD Monitor
"No signal" msg on new Acer X193W LCD Monitor with Vista 64-bit
I have an new HP Pavilion Entertainment PC Notebook and just bought a 20" X193W Acer LCD monitor. Went through the set up menu and I think answered the questions correctly but not sure. Only thing on CD that came with monitor was instruction book 1 page in English rest of about 20 pgs in foreign languages.. Just told you how to plug it in--no installation disk. Tried to do the "add hardware" but it didn't show monitors. Don't see Displays or monitors in my control panel... Searched for drivers on Google and found this site. The message I get is "No signal". I know the cable is plugged in properly because if I unplug it, msg comes up on screen stating "cable unplugged) I.. I'm no computer expert but I am thinking it had to do with the first set up or Vista 64-bit maybe??? Help will be greatly appreciated!
Thanks!
Jodi
  • 7 more comments
  • jodi453 Jun 22, 2009
    It was helpful (I didn't know about right clicking on desktop to find the monitor settings--was trying to find it in control panel) but I did what you said, but #2 says "not active" and when I click on it nothing happens.. Appreciate your help!
    Jodi
    Ok, I had to go to something called ATI Catalyst Control and got it to work on extended screen--I could move cursor over to the other monitor, but what I want is to use the external monitor when working at home not both at once.... Thanks! Jodi
    OK, Now I got it to work on both screens at the same time. Still have a couple of questions...
    (1) On my HP mini when it was really small I made the type larger, but now with the 19inch monitor it is huge.. can't remember where I went to adjust resolution. I found that slide bar but it was gray'd out and could't increase it, and type is so large I can't get to the bottom of that screen.
    (2) Is there a way to turn the screen off on the HP mini without it going off on the duplicate larger monitor? (No sense to waste both monitors at the same time..)
    Thanks much for any help you can give.
    Jodi
    I downloaded the latest driver. I found the two places you mentioned to make the print smaller but it is so huge (both places) there is no way to scroll down after I make my selection to save it... Sorry to be such a problem child ;-)
    Jodi
    OK, I finally was able to move down far enough to see the tip of the button OK, so clicked it, rebooted and still no change.
    I do have options for screen resolution as I mentioned in my last comment.. but it was so large and no way to scroll down to save or click OK.. but finally I did see the tip of the OK button and clicked it, rebooted, but still big. Went to the other option through ATI and there are different options, but they don't hold either. 60Hz is selected. Under the "personalize" method, the highest resolution shown is 800x600 which is selected. Under ATI I can select higher resolution but it doesn't work.
    Tab button (and down arrow) both just go from one selection to another (eg: DPI page, arrow does nothing. Tab goes from 96 DPI button to 120 DPI button. I leave it on 96 DPI but since I can't get to the bottom to save, it doesn't get saved. (also tried CTRL + and - etc. which works on other stuff but not on that screen. On Monitor screen, slide bar for resolution does't work on monitor 1, but does on monitor 2. I change it and on that screen I can see the very top of the OK button, so I click it but nothing happens. rebooted.. still nothing.
    That is just is what this "senior citizen" needed was OLD SCHOOL! On the DPI screen, you were on the right track with tab (which didn't work) but using Enter worked!!!!! Thank you SOOO MUCH!
    Jodi
    Yep! All is right with the world ;-)
    You are SO patient.. I really appreciate your help.
    thanks again,
    Jodi
  • 107 Answers
This should be easy...go to your desktop...right click on it and choose "personalize" it will open up a window. on the bottom it will say display settings...click on it...at the top right it should say "identify monitors" click on that...if that dosent work.click on the monitor that has a 2 on it and it will ask you if you want to add a monitor...it should work
if not, post a comment and i will check back with you
Posted on Jun 21, 2009
  • 4 more comments
  • aklarichjr Jun 22, 2009
    np,
    1, when you right click desktop then personalize, there will be an option on the left that says "adjust font size(dpi)"
    2, you should be able to turn off your original monitor 2 ways...either though display settings ( the 1 or 2 monitor I described before) or in your ATI catalist center under the monitor tab
    its always best to make sure you have the latest verison of your drivers..heres a link where you can download the most updated drivers
    http://support.amd.com/us/gpudownload/Pa...
    ok then..its weird that you dont have any options for screen resolution...you certainly should...they should be under display settings in personalization or in your ati center...
    try this..click advanced settings, under display settings...it will give you another way to get to ati...
    also make sure that your refresh rate is set to 60hz
    ok...were going old school then...after you make your selection, be it font size or resolution, hit the "tab" button untill your selection (save or OK) is highlighted then hit enter to select
    you should also be able to use the arrow keys to scroll the page
    remember in my first post how I said this will be easy?...lol
    when you change dpi setting (or resolution) with tab try to just hit enter..by default you shoud be prompted to save and it should already be highlighted.
    When you change screen res. you should not have to reboot...it should take a couple of secs to refresh
    also under personalize you can go to "mouse pointers"..under pointer options tab, check the box that says "snap to" that will auto put your mouse on the default box
    how did you navigate on the old screen?
    glad to help... all probs solved and all is right with the world now?
Base system drivers
Card reader drivers, get it either from HP or Windows update. If you are running Windows 7, use the vista drivers. Just make sure if you are running 7 64, use vista 64 or 7 32 bit, use vista 32.
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-dv9900-entertainment-notebook-pc-series/3725216/model/3747256
Look under storage section. Ricoh download and install. This for using SD cards from cameras to pull up pictures you have taken or any other files on it
Apr 02, 2014 | HP Pavilion dv9930us NoteBook Intel Core 2...
Dv6-2150us webcam
Your new camera driver is simply not compatible with the 64 bit version of windows. Get a camera that is specifically designed with a driver for Win 7 64 bit version.
Sep 03, 2017 | HP Computers & Internet
Acer X193W not getting any signal when connected to 8600GT by DVI
If you know the cable and the place it was before
replace it and reboot the dude (Ps if you dont have the referce and instructions for the take a polaroid
Oct 19, 2009 | Acer X193W LCD Monitor
I NEED TO CHANGE FROM 64 BIT VISTA OS TO 32 BIT " XP OR VISTA OS
Ummmm. Its quite expensive to do that but i suppose if you need to ten its a viable option. You could buy a cheap 32 bit machine instead or try downgrading vista.http://www.microsoft.com/windowsvista/1033/ordermedia/default.mspx This may help you if you retail bought the machine.
Jun 24, 2009 | HP Pavilion dv5-1150us NoteBook
Acer x193w LCD Monitor repeatedly auto configures.
Here is a link to get the manual:
http://www.acerpanam.com/synapse/data/7117/documents/X193W%20(Qisda)%20user's%20manual.pdf
Starting on page 15 are the directions for the monitor controls. Page 17 indicates a "RESET" feture to Clear the Old-Statuses of "Auto-Configuration". There are quite a number of setting for this monitor.
Jun 11, 2009 | Acer X193W LCD Monitor
Compatibility between HP Quickdock 2.0 Docking Station KN745AA and HP TouchSmart tx2-1020us laptop for external monitor viewing
Your tx2-1020us is not compatible with the KN745AA as this device is only compatible with the following:
  • HP Pavilion dv2700 Entertainment Notebook PC series
  • HP Pavilion dv6700 Entertainment Notebook PC series
  • HP Pavilion dv9700 Entertainment Notebook PC series
  • HP Pavilion dv2600 Entertainment Notebook PC series
  • HP Pavilion dv4-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1100 Entertainment Notebook PC series
  • HP Pavilion dv6-1000 Entertainment Notebook PC series
  • HP Pavilion dv6-1100 Entertainment Notebook PC series
  • HP Pavilion dv6600 Entertainment Notebook PC series
  • HP Pavilion dv6800 Entertainment Notebook PC series
  • HP Pavilion dv6900 Entertainment Notebook PC series
  • HP Pavilion dv7-1000 Entertainment Notebook PC series
  • HP Pavilion dv7-1200 Entertainment Notebook PC series
  • HP Pavilion dv7-2000 Entertainment Notebook PC series
You can find the compatibility chart by clicking here
You can find the compatibility information for the ES631AA by clicking here
To resolve your issue you should purchase one of the following:
To dock your notebook you need the HP QuickDock KN744AA#ABA or
You could get HP Notebook Media Docking Station
May 15, 2009 | Computers & Internet
My HP 9311 Tx does not give display on its LCD screen
after loading Operating system just press F5 and wait for 2-3 seconds. if display not appear try 1-2 times. it will come. plz replt if ur problem solved
Apr 10, 2009 | HP Pavilion dv9000z Notebook
I cant install autocad 2009 in windows vista 64 bit operating system.
I cant install Autocad 2009 on Acer Apire 5715z, when i try to install the operating system is not supporting
regards,
Johnson Idukkula johnsonkollam@gmail.com
Mar 05, 2009 | HP Pavilion dv4000 Notebook
Sound drive
On the HP site, the Hp pavilion tx1240ef only have audio drivers for Microsoft Windows Vista and Microsoft Windows Vista (64-bit).
» Microsoft Windows Vista
» Microsoft Windows Vista (64-bit)
Sep 13, 2008 | HP Pavilion tx1000z Notebook
Monitor saying no signal
you need to return to where you bought this because it is still under warranty, you can not open this because the warranty will be cancelled once the stickers will be damaged
Jan 13, 2008 | Computers & Internet
Acer X193W LCD Monitor Logo
527 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
