Question about Kenmore 98702 Stacked Washer/Dryer
Electric dryer stacked unit dryer gets too hot.
  • 867 Answers
Make sure the lint filter is clean, and the duct outlet to the wall is clear. try unplugging the duct from the wall if youa re in an apartment, if it runs cooler , meansi ts clogged in the wall ducts
Posted on Jun 21, 2009
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
I have a Frigidaire GLET1031 Top Load Stacked Washer / Dryer. The water valves do not work unless the dryer is turned on. Also the washer drum will not spin with dryer on or off and the dryer does not get...
WHat ya need to check is for proper power going to the entire unit it sounds as if either a breaker is off or their is burnt/broken wire from the main power connection.
All symptons listed i suppose occured suddendly?? and to me its a lack of proper electrical power that is causing all of them.
GENE
Oct 03, 2011 | Frigidaire GLET1031 Top Load Stacked...
Dryer does not get hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 17, 2011 | Frigidaire GLET1031WH Top Load Stacked...
Whrilpool washer/dryer stack the dryer doesn't get hot
You will find that the drier wont get hot because the timer is not forwarding onto the heating part of the cycle. Possibly if you click one click at a time, you will possibly get to the heating part of the cycle but its not safe as it wont go any further. Install a new timer and you will be happier I'm sure.
Sep 28, 2009 | Dryers
Why does my apartment fill up with moist air and fumes whenever I use the electric dryer on my GE SpaceSaver stacked washer/dryer combination?
You have a 4 inch duct hooked to the back of the dryer. The hot air, moist air etc. go through it to wherever it is vented to. Outside, attic or inside your apt. if it has come loose.
Jul 03, 2009 | GE WSM2420D Unitized Spacemaker Washer /...
How to un-stack Bosh Washer WFL 2060/Dryer WTL 5410
Did you ever get an answer? I have the same problem...
Mar 21, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Dryer quit after about 20 minutes-see more details below
do you have clothes on top of dryer? if so, i'll say it again never ever stack clothes or anything on top of it. Things on it insulate it and will overheat the machine. Yes it has a overheat linit switch but to get to it you have to take it apart and pull the drum out depending on the style of heat element you have. Some are in the back of drum and others are in a tube on the floor of the unit inside. If yours is behind the drum then drum needs to come out to check for the problem
Feb 26, 2009 | Amana Dryers
Dryer to hot
your dryer has 2 thermostats in it more than likely that no1 thermostat has burned out it will need replacing usually when u buy the stats they come in a pack of 2 lower and higher temperature stats
Aug 15, 2007 | Frigidaire FWT449
Kenmore 98702 Stacked Washer/Dryer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
