Question about Nokia 7373 Cellular Phone
I want to open up all networks - Nokia 7373 Cellular Phone
    Sergeant:
  • 220 Answers
Go to setting, network settings and you have the option there
CHEERS
Posted on Jun 21, 2009
How do i reset it my wireless adapter
If I were you, I'd first let Windows Manage Wireless Network Connections:
  1. Click Start If you're using XP, click Start then open the Control Panel. Find the Switch to Classic View button in the Control Panel and click it.
  2. Open Network Connections Open Network Connections then double-click the Wireless Network Connection icon.
  3. Click the Properties Click the Properties button. Look for the boxes at the bottom of the Properties window that read "Show icon in notification area when connected" and "Notify me when this connection has limited or no connectivity" and make sure they are both checked.
  4. You could also right click on the Wireless Network Connection icon and click Properties from there.
  5. Open Wireless Networks tab Open the Wireless Networks tab and make sure the box labeled "Use Windows to configure my wireless network settings" is checked. Then click OK.
  6. under Control Panel\Network and Internet\Network and Sharing Center you could find "manage wireless connection" there you could assign/delete wireless connection.
Oct 26, 2014 | Lenovo ThinkCentre M72E 4004-B8U Tiny Form...
How do I activate Wi Fi on Kindle Fire?
Step 1
Power on the Kindle, and then press the "Home" key to open the home screen.
Step 2
Press the "Menu" button, and then tap "Settings" to open the Settings menu.
Step 3
Tap "Wi-Fi Networks" to open a list of available wireless networks.
Step 4
Tap a network to connect. If security is configured on the network, a password dialog box opens.
Step 5
Type the network password, and then tap "Connect" to connect.
Jul 01, 2014 | Computers & Internet
Reset password on wireless router
That more than likely mean you have put the password in wrong or you are using the wrong authentication type.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the WirelessNetwork Connection and select Properties. When the Properties window openclick the Wireless Networks tab. Click on the SSID for your wirelessnetwork that you connect to and the Properties window will open. You canchange the Authentication Type to match the type set in your wireless routerand you can also change your password or Network Key to make sure you have itin correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left ofthe open window and click Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center thenlook to the left and select Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
Jun 08, 2012 | NetGear N300 Wireless Router
Thinkpad having limited to no connectivity
More than likely your password is wrong or the Authentication Type such as WEP, WPA, WPA-2 is wrong.
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 11, 2012 | Lenovo ThinkPad T420 Notebook
Dell inspiron 8000 password authentication system
Are you talking about the authentication process on trying to connect using wireless?
That means you probably don't have the password or theAuthentication Type set correctly.
May 10, 2012 | Dell Computers & Internet
Cannot get the internet to work
That means you probably don't have the password or the Authentication Type set correctly.
May 08, 2012 | Computers & Internet
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
Network software keeps switching to other network that does not w
Try this steps:
- Open the control panel of the computer
- Open the network connections
- Right click on wireless network and click view available networks
- Open the change advance settings
- Click on wireless networks on this section create a profile (Make sure that you have the wireless network name and security ) you might manually create a profile, just click add under preferred networks.
Mar 14, 2009 | Hawking (PN210X) Network Adapter
Slowdowned opening of My Network Places
Does the network eventually show up or is there an error?
When connecting to a network, especially a large network or a network with a lot of shared files and folders, My Network Places will take a while to open because it searches the network for all shared items and all connected equipment. Just give it time, and it will either show you your network, or give you an error.
Mar 09, 2009 | Microsoft Computers & Internet
Nokia 7373 Cellular Phone Logo
76 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
