Question about Motorola Mobility RAZR V3
*Unable to charge
An *Unable to charge message comes up on the screen when plugged in. With or without a battery in it. Is it not picking up the battery?
  • 3 Answers
My wife spilled some water on her Pebl and she shut it off for the night. She dried it pretty good but it had a protective case over it and she thought that it didnt get water into the inside of the phone but it did. The next morning the phone wouldnt work. We left the battery out all day and yes, the "wet" dot had turned red. We thought all was lost, but that evening after it had dried we replaced the sim card and battery and turned it on and it worked fine....except it needed to be charged and when she went to plug it in we got the "unable to charge" msg and the phone shut off. Well, since I had bought the phone second off of Ebay I knew there was nothing that Cingular would do, I took the screws out of the back and took the phone apart. There is another one of those dots back there as well....and it wasnt tripped. I did notice a little bit of white stuff around were the battery prongs touch the main circuit board, I gently used the small screw driver I used to take out the screws and cleaned that stuff off. I also gently scraped those prongs and the metal they touch on the circuit board. Thought it was a long shot but I put the phone back together and plugged it in and bygod, its charging. Guess we will see how long this fixes the problem. Hope this helps you out some.
Posted on Apr 30, 2008
    Sergeant:
  • 316 Answers
Try a different battery in it when you are trying to charge if it works your fixed if not it may be as you suspect.
The other way is to try a different chargers well if the prob is still there then it is in the phone and needs a tech to look at it
Posted on Nov 03, 2007
Unable to switch on my samsung T210 tablet
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
Feb 17, 2014 | Samsung Galaxy Tab 3 SM-T210 8GB 7"...
I was hoping you could tell me how long to charge my Samsung R519 notebook/laptop for the first time and when it should be charged afterwards. Thankyou.
I recommend that you use the laptop without charging it to fully drain the battery. Then you are guaranteed a 100% charge when you come to charge the battery.
You can let the battery run down until you get a warning message saying battery low plug in mains power.
Regards.
Jul 06, 2010 | Computers & Internet
Battery issues
sound like you need a new battery
Aug 19, 2009 | Motorola Mobility RAZR V3
Voicemail picks up too soon and New voice mail message always on
Check call waiting feature with mobile provider on number of rings to voice mail. Many problems repaired with booting phone (holding on/off button down till screen logo comes on & removing charged battery cleaning contact connections on phone and battery with DRY SYnthetic NOT cotton cloth ideally clean battery with alcohol swab let dry before returning to phone
Aug 07, 2009 | Vtech DS6111 Cordless Phone
Battery is fully charged but when I push button to take a
Camera takes pictures with flash off. With flash on message comes up and says flash charging and camera freezes unable to turn off I have to take the battery out
Jul 12, 2009 | HP Photosmart R707 Digital Camera
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
Garmin nuvi 200 pick up charger as a usb cable
The problem is very simple... The GPS unit perceives whatever you plug in depending on the power supply figure.
If you car charger is not giving enough power, then the GPS perceive the cable as being connected to a pc.... thus not charging. Check with an car electrician if you can raise the power supply on your car...
Nov 24, 2008 | Garmin nuvi 350 GPS Receiver
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
I have a nuvi 200 that wont run when it is hooked up to a power supply
The Nuvi 200 only has a 5 hour battery. Once charged, it can be removed from the charger, but the battery will only last 5 hours. Can you plug it into the car charger and navigate while charging BEFORE the battery dies? If so, and you don't have to remove the charger, you can leave the unit plugged in while you navigate without damage to the unit.
Feb 09, 2008 | Garmin nuvi 350 GPS Receiver
Phones won't pick up calls...say connecting
HOLD THE HANG UP BUTTON AND THE POUND BUTTON DOWN FOR 5 secons. select base unavailable....yes. then hang it up on the base and it will register to the base. if that doesn't work then unplug the base then plug it back in then put the reciever on the base.
Nov 20, 2007 | Uniden TRU9380-2 Twin Phone
Motorola Mobility RAZR V3 Logo
133 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
