Question about Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ0 spins but not fast enough
The machine goes through all cycles,but doesn't spin the clothes fast enough (they are very wet after the full cycle). The last few times, my wife can smell something "burning" like a belt--but I can't find one. I checked to make sure it is spinning and it is. I also checked to see if I could find anything under the basket per/one of the solutions on Fixya. Also tried turning the basket manual and wasn't able to do it.
thanks
  • dantracy17 Jun 21, 2009
    If the clutch is slipping on the transmission it would still spin? What do I do to change the clutch or do I need to change the transmission?
    What parts are required?
    Thanks
  • 867 Answers
If it has no belt, seams like the clutch is slipping in the transmission, hence the burning smell
Posted on Jun 21, 2009
  • 6,784 Answers
HI, your unit dose not have a belt. it is a direct drive system that has a transmission. this is motor failure the actual motor is weak, due to internal windings breakdown. the burning smell is coming form the motor itself. it is recommended to replace thsi failing motor asap. this is a fire hazard at this point.
  • 1 more comment
  • Michael Masters
    Michael Masters Jun 21, 2009
    IF your clutch or trans mission was the issue, your machine would sound like a Air plane taking off during the spin cycle. you would hear very loud noises.
  • Michael Masters
    if the unit agitates correctly, your Transmission is ok.....
  • Michael Masters
    lol, your clutch is fine as well....
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine not spinning fast enough and
Check motor capacitors. Check freeness of the drum rotation, if you suspect clutch
Apr 02, 2010 | Washing Machines
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
In spin cycle, water sometimes does not drain at all; other times the clothes are wet, other times the spin cycle works fine. Problen can be rectified by placing the washer into spin cycle a few times.
when on spin check to see if you can hear a low whirring noise {the pump} if the machine is not pumping or not pumping fast enough for sufficient water to drain out of the machine then the machine will not spin due to having to much water in. i would also check to see if all filters on the waste water output are clear of any foreign bodies as this will reduce the speed of which the water is pumped out of the machine{some machines have 2 filters } good luck
Jul 23, 2009 | Washing Machines
Roper RAS8445KQ Top Load Washer Logo
362 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
