Question about Whirlpool Calypso GVW9959K Top Load Washer
Calypso Elite Model 110.2506* OB errror code
My machine after about 12 minutes of washing clothes goes out of
balance. It doesn't matter how many clothes are in the machine. The OB flashes on the display panel and it shuts itself right down. After that, I have to shut the hit the stop button twice. Once to stop the macine and the other to completely shut the machine off. After that, I have to ring out the clothes by hand and put them in the dryer. Is there a problem with the shocks on this machine? Should they be replaced?
What is the problem with this machine?
  • mcavana426 Jun 21, 2009
    Thank you, I am going to try your solution.
  • 867 Answers
Something is loose, pull of the top of the agitator, aplastic nut ( where you pour softener in). should be a metal nut there, make sure it is tight, if not ,yes it may be the shocks
Posted on Jun 21, 2009
What is 06 code on a calypso washer
could this be an OB code? if so it is an off balance code meaning the wash load is to unbalanced.open the lid redistribute the load and start it back up. all of the manuals for the calypso do not show any numbers or an 06
Nov 15, 2011 | Kenmore Elite 45986 Front Load Washer
I own a kenmore elite heavy duty plus washer. During operation it stops and a message apears saying ob when you open the lid and close it ob disapears and I restart it and minutes later the timer never...
The OB error code is short for out of balance. There are two fixes that you can try: One is to move the clothing around in the tub. or Two the machine isn't level and is causing it to falsely error as out of balance.
Oct 30, 2009 | Washing Machines
Calypso code ob
Code "OB" means Off Balance.
Oct 17, 2009 | Kenmore Washing Machines
Whirlpool Calypso stops at 26 minutes and throws ob code
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso GVW9959K washer with OB code
This is a common problem with the Calypso washers. The problem that you are having is related to the pump. There is something in the pump that is causing the error code to occur. Since the pump isn't working right all of the water isn't draining out thus causing it to be out of balance. If you can get down to the pump and check it out chances are you will find something in it. It might just be some fabric or string from clothing caught around the pump motor. Just make sure you clamp off the hoses or you will flood your laundry room. Once you clear out the pump unplug the washer and wait a few minutes before plugging it back in. Let me know if you have any other questions and let me know if this was helpful. Good luck and glad I could help.
Jan 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso Washer troubleshooting
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^#@#$%
Jan 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso ''ob'' problem
ob Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an ob for Off Balance The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
if this does not fix the issue it is most likely the strut and shock system that is falty on the machine. you could replace them yourself but they are fairly expensive
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Calypso kemore elite washer
May 01, 2008 | Kenmore 15864/15862 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
276 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
