We are trying to locate the Knock Sensor and are unnable to find it?
The Knock Sensor is Located under the Intake Manifold.. It can be seen vias a flash light from the Driverside Looking down into the open area below the intake manifold approx 8in. Inside. If you are going to Remove/Replace the Knock Sensor You will have to Remove the Intake Manifold. Whick is not as hard as it may look. You will also have to replace the Gasket on the intake it self.
whats the year and make??
i will need the engine specs as well??
