Question about Dishwashers
Over the past two years, the machine has occasionally stopped in mid cycle, while the pump continues to run, but the cycle stops advancing. Each time there has been water in the plastic pan under the pump, valves, and other mechanisms. The float switch has been tripped, stopping the cycle. Occasionally. but not always, the pump inlet has been partially obstructed by food waste. After bailing out the pan, the machine will run normally for weeks or months. There is no indication of a leak into the pan.
  • 2 more comments
  • wreid66 Jun 21, 2009
    The Bosch spray arm does not have a "boot"- it snaps into a fixed base fitting, with no readily apparent seals. I realize that water intrusion through the lower arm coupling is a logical assumption, but this particular diagnosis does not explain the problem I have. Thanks, anyway.
  • wreid66 Jun 22, 2009
    Probably not as simple as a stripped shaft seal. The pan flooding problem first occurred four years after installation, then one year later, then one day later, then one month later - not a typical shaft leak. Besides, checking the shaft seal entails totally removing the machine and disassembling it. I'm looking for a simpler solution.
    Someone asked for the dishwasher make and model, which I specified when I first signed on. To repeat, this is a Bosch model SHV66A03 UC/14, purchased in January, 2004. Please help me - I tried one "factory authorized" repair technician, but all he succeeded in doing was to shock himself, burn up the control board, and charge me $100.
  • wreid66 Jun 28, 2009
    The pan flooding problem has gone dormant again, so I am assuming that the leakage is occurring through the door seal, as suggested by the "expert". The question of whether the seal leakage is caused by contamination of the seal face, or by flooding of the tub, or both, remains.
  • 15,935 Answers
Please post the exact make & model # so we can be more exact.
THanks!!
Posted on Jun 22, 2009
  • blueextc3221
    blueextc3221 Jun 22, 2009
    The only leak point from the tub is the door seal - or the sump gasket.
    These are the only 2 methods for water to seep into the catch pan and trip the sensor.
    You can find it HERE.
    This seal will seep if food gets under it. Also - the seal shrinks and expands from periods of non-use, as well as from temp fluctuations in the unit.
    Many times you will notice the leak after a "sanitizing" cycle with extra heat involved.
    You should also pay close attention to the end of cycle - there is supposed to be a little bit of water left over after draining that keeps this seal moist and lubricated.
    Thanks for using FixYa!!
  • 508 Answers
Check shaft on waterpump it maybe possibly stripped?
Posted on Jun 21, 2009
    Sergeant:
  • 326 Answers
The main problem is with the boot that screws on to the spray arm which serves as the seal from the spray arm to the motor.To find out spin the base of the spray arm loose and take off the screw tightened clamp that holds the boot to the motor. Hope this helps
  • SABARI ANAND
    SABARI ANAND Jun 21, 2009
    essortment.com/home/dishwasherleak_shrz.htm
  • SABARI ANAND
    may i know the the exat model please
My washing machine washed a load on the medium cycle but when it is time for it to drain the water it just stop the only thing it is doing is fulling back up with water and not doing anything else on
Not sure what you are saying, I assume the water is not pumping out at the end of the wash cycle. Is the water draining out at the end of each cycle? Is it spinning at all? Is the exhaust tubing clogged? Is the pump burned out or are you trying to pump it uphill too much. If it's stopping mid wash, try advancing it manually past where it's stuck and see if it continues. I have that problem, the tank fills with water and it gets stuck at the 6 minute changeover. It will run stuck at this point indefinitely if I let it. We just set a timer for the fill time, then manually advance it past this stopping point.
Sep 30, 2014 | Washing Machines
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Electrolux washer stopped in mid cycle with clothes in will not empty water out. What do I check. Brian
Most likely something caught in the pump. Coins and balls of lint are real common.
Sep 17, 2009 | Washing Machines
GHW9100LW randomly stops during cycles, has a severe clicking noise
the water leaking back in may be due to a fill valve not fully shuting off allowing water to leak into washer after shut off...reclean pump ck as far as possible into pump itself something may be hung in impeller the shaking may be due to excess water in clothes causing off balance and shaking ..cleaning pump may solve problem..if possible pull pump completely out to clean ck pump impeller to be sure it has not come loose on motor shaft this would also cause slow or no pump out ..if impeller is loose replace pump..good luck
Nov 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer stops in mid cycle
have a front load mah9700a. Unit will not run door is locked , have found that control board shorted. Still need to open door manually, need a parts scheme to look on how to open????
Sep 03, 2008 | Washing Machines
Stops mid cycle
It may be a out of balance alarm during a spin cycle. Re-balance the clothes and hit start.
Jun 12, 2008 | Fisher Paykel EcoSmart GWL15
Stops mid cycle
CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
Jun 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Dishwashers Logo
180 people viewed this question
Top Dishwashers Experts
