Question about Whirlpool Calypso GVW9959K Top Load Washer
28 comes up in the window. I can press buttons and the thing beeps, but comes back 28 (goes blank when I push cancel). I took out the controller board. Nothing obvious wrong. Put it back in and it worked for a few seconds! I could hit "Normal" and 48 came up in the window as usual (time for Normal wash with the the other settings and options). Then after a few more seconds it went to 28 again. I don't see in the manual that 28 is in any way a diagnostic code or anything like that. Other codes are like SP, FL etc - two letter codes. I'm giving this service a shot, but frankly a response like "replace the controller board" is just as acceptable as 'call the repairman'. I hope you can seriously help!
  • 1 more comment
  • David Frazer Jun 21, 2009
    What do you mean "reconfigured to no avail"?
    I know there is a newer replacement board, missing one of the connectors.
    So the history of this board is that they die and lock up with funny codes in the window? You're sure it's not a diagnostic code from the board?
    There was no update to your response.....
  • David Frazer Jun 22, 2009
    Thanks for the extra response and clarification.
  • 15,935 Answers
If it simply says 28 - the control board/timer has failed.
All sensor errors have a letter in front of the number.
CLICK HERE for a replacement board.
Since the problem is in the Timer Logic - there will be no visual evidence of failure - it is a computer chip.
Most of these problems are caused by an extremely unbalanced load causing vibrations which damage the chip.
There is no other fix or bandaid to get your machine operational. The board must be replaced.
Thanks for using FixYa :D
Posted on Jun 22, 2009
    Sergeant:
  • 326 Answers
Retrevo.com/s/Whirlpool-GVW9959K-Washers.../1-2
Posted on Jun 21, 2009
  • SABARI ANAND
    SABARI ANAND Jun 21, 2009
    this particular brand is notorious for this. the actual control boards were reconfigured to no avail.
    Unfortunately, you will need to replace this failed control
Wont start
First you have to find the error code.
So! To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Dec 03, 2011 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire GLFT294OES3 turns on, but after a few seconds, it goes to "No Spin" and errors out. The water won't come through and it just shuts off, please help!!!
Wait 5 seconds
You may also have a code such as E47 or E24 etc..
Comme back with the code and I will explain what is the meaning of the code
Oct 02, 2011 | Frigidaire GLTF2940ES Front Load Washer
My washer will not come on all it does is beeps and flashed, there is no error code
when a fault occurs the unit stops and beeps and flashes to recall the error code you would press any button wait about 5 seconds then press start and cancel together the led's will go blank and after a few seconds the control will signal the error code using audible beeps and blinking lights the control will keep giving this error as long as the start and pause/cancel buttons are depressed the code is obtained by counting the number of flashing lights you can read more about this on this site click here http://www.advantagesupplyfl.com/FrigidaireWasherFaultCodes.html message me back with which error code you are receiveing as well as the model number of your machine if you require more assistance in this repair and please also remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 22, 2011 | Frigidaire Washing Machines
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
GBD RBD Whirlpool Oven Problems Causes and Solutions
Hello Edward!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
When i turn my ps3 on nuthin would show up on the tv. You can't even hear anything on the tv...it's just blank. Someone please help me..!!!!!!!!
Alright mate, Try these steps...
1. turn on the ps3 so it is in stanby i.e. the red light is on. 2. push and hold down on the red button for as long as it takes to turn the ps3 back off on to standby, you should hear a beep. 3. when it goes back to standby do the same thing again, and this time you will hear one beep (when you pressed it) and two more beeps and it will go back to standby 4. when it is back in standby again, push and hold down the button again, you'll hear the first beep, then three more beeps, and it will go back to standby. 5. do the same again, however when it turns on this time, if done correctly, it should say connect the controller using a usb cable. do this and turn it on. 6. Go through everything it says on screen, 6 options should eventually appear, for me, option 4 did the trick, but i heard option 3 works too, as the other ones do too i presume. 7. the final part is that it will ask you to restore the hard drive etc... just keep pressing the ok button.
if all fails, then phone this number (sony) 0818 365 065. glad to help. let me know.... David.
Jul 18, 2009 | Sony Playstation 3 (PS3) Console
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
My washer won't turn on. It just beeps when i
Hi, this is a main control panel issue. here is a procedure you can preform to gain control back.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press START.
If the problem persist, you will have to have the control panel repaired by the service tech.
Mar 07, 2009 | Whirlpool WFW9400S
Maytag gemini f1-9 error
plug it back in and press the cancel button
Mar 31, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Whirlpool Calypso GVW9959K Top Load Washer Logo
55 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
