Question about Vehicle Parts & Accessories
Immobiliser wont disable but key fob works electric windows, door
Rover 45 impression 2003 reg immobiliser wont work and therefore engine wont start but key fob works electric doors
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
SOURCE: Audi a3 central locking 2003
Hi John.
Inspect the key fob for a place to open it and check for a battery.
Regards Johngee10
Posted on Aug 10, 2008
SOURCE: renault megane key fob wont work
I had the same problem with mine
your key fob is now out of sync with the ECU to sync them just follow this link (renault will charge up to £180 for new key and to sync it)
http://renaulthelp.110mb.com/ImmBypass.html
Posted on Jan 09, 2009
TLRogue
  • 99 Answers
SOURCE: immobiliser wont go off , wont unlock the doors.
There is a way to override the code, however you need the code number. The only other way is to sit in car with door shut, play with the central locking button on dash, locking and unlocking. While doing this occassionally turn the ignition on and off. If you do it long enough, you may find the immobiliser light goes out, if it does, quickly start the car.
TL
Posted on Jan 21, 2009
  • 345 Answers
SOURCE: vw passat 1.9tdi
the water in the footwell can make the wiring rotten check under the tape for any corrosion,i have changed a couple of units that have blown due to the water but it is a common fault
Posted on Mar 03, 2009
reynosaelect
  • 165 Answers
SOURCE: alarm/immobiliser
i cant help you but i need to send you by fax the information,email me reynosaelectronics@live.com.mx send me your fax number.
Posted on Mar 17, 2009
Immobiliser doesnt recognise key
check whether the chip still inside the key fob,possible lost on any time dropped,or if you were putting the fob on any electric machine ( washing machine,micro wave,fridge, tv etc lost memo and need to get reset.
Nov 21, 2013 | 2003 Vauxhall Vectra
CAR WONT TURNOVER AND START
Immobiliser fob battery dead? Battery flat? Corroded battery or earth terminals? Dead starter motor or relay? Engine seized (will it bump start if manual?)?
You need to describe what happens when you turn the key.
Oct 03, 2013 | 1997 Land Rover Range Rover
How to disarm the immobiliser on rover 200
Is the key fob battery flat? If so fit new CR2032 and re-sync to car by pressing lock 4 times in succession
Jun 09, 2012 | Rover 200 Cars & Trucks
Tried to open car with fob but wouldnot open so used key which let me in but did not turn off the immobiliser so car wont start. Only drivers door will open and lock how do i get immobiliser to turn off...
The RCDLR (remote control door lock receiver) could have failed, or the battery in your key fob is dead. The only way to get the immobilizer off is to use the key fob.
May 09, 2011 | Land Rover Freelander Cars & Trucks
Key fob would not open 1995 discovery ,used key in door then alarm went off ,after a few seconds alarm ceased then put key in to start engine and got nothing now cant lock doors with key but red light is...
The red light means the Immobiliser has not been turned off, the deactivator in the key must not be working correctly, visit your local land rover dealer who will be able to make sure the key is paired to the car correctly, otherwise you may need a new key.
Feb 11, 2011 | 1995 Land Rover Discovery
Rover 400 immobilised and I cant over ride it with my code!!
not sure about this model ,depends on year but removing fuse F! stop immobilisor from working
Dec 03, 2009 | 1991 Peugeot 405
I have a rover 200 when opening the door with the fob, some times the immoberliser light stops on and the engine wont start, i have changed the battery in the fob worked for a while then is playing up...
rover 200 ,remove fuse F1 in the box under the bonnet and then the immobilisor is disabled.their is a box right up under the dash and you would need to take dash out to get to it ,use the key to open the door because to repair is more than the car is worth especialy in the uk ,car not worth more than a monkey(500)
Nov 25, 2009 | 2002 Land Rover Freelander
Rover 200 fob will not lock/unlock or disarm the immobiliser is there anyway of bypassing it?
Hi, I have a 1999 reg Rover 200 1.4. When I bought the car it did not come with a fob. To cut a long story short, the battery went flat and now I cannot start the car with the key. Is there anyway I can start her without buying a fob? Cheers :o)
Aug 31, 2009 | Vehicle Parts & Accessories
Rover 216 wont start
unlock your car with the key, put the key in the ignition switch, remove one of the battery terminals now switch the ignition to the running position then put the battery terminal back on this will bypass the rovers immobiliser and alarm system
Feb 14, 2009 | 1995 Land Rover Defender
Vehicle Parts & Accessories Logo
353 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
