Question about HP Computers & Internet
Computer starts but never lights up have tried
Computer starts but never lights up have tried other monior, replaced hard drive
  • 50 Answers
Try removing the memory cards, cleaning out the dust on the cards and in the slots themselves. Then put them back in.
If this fails, try plugging in a different PSU (power supply unit)
Hope I helped,
Tom
Posted on Jun 21, 2009
When i power on my pc moniter not started hard disk light not blinking..
Are you powering on your computer and your monitor...
If your computer appears to boot, but nothing on your monitor...
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
If your computer won't boot...
The hard drive, motherboard, or some other critical component may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. That way, at least you may not lose your files.
Then, you could try to do a Factory Restore or Reload on the computer, and if that works, copy your personal files back to your newly restored computer. Good luck.
Aug 05, 2014 | Computers & Internet
My acer extensa 5630 will not start
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Apr 29, 2013 | Acer Extensa 5630-6806 Notebook
Keyboard and monitor not working
Desktop: check cables
Laptop: I have no idea
Feb 18, 2013 | Computers & Internet
Maxtor diamondmax plus 9 hard drive not seen by computer
I'd say you did a good job troubleshooting. Replace the drive.
Dec 29, 2012 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
It only blink the orange light and the computer could not start.
What, orange light, when you ask a question tell me all the details, what motherboard? are you talking about a motherboard or computer or laptop? There's lots of lights on a motherboard you see, so saying light on the motherboard could mean anything. does the computer post. Does it get into the bios. If it gets into the bios but won't get into windows your hard drive may be broken or unplugged. Are you sure the monitor is on and connected, have you tried turning it off and on again, if you can get into bios, go and see if your hard drive is listed under sata or pata devices, if not check your connections then maybe replace your hard drive or call your computer manufacturer.
Jan 25, 2011 | Computers & Internet
When computer Switch On button press computer will not be start and processor fan aslo not start so which problem accured on mother board or cpu? But Motherboard light is always on board provide power...
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Sep 07, 2010 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
Lg crt monior display cable wire circuit diagram
Pin Signal 1 Red Video 2 Green Video 3 Blue Video 4 Monitor ID - Bit 2 5 Ground 6 Red Ground 7 Green Ground 8 Blue Ground 9 [KEY] 10 Sync Ground 11 Monitor ID - Bit 1 12 Monitor ID - Bit 0 13 Horizontal Sync 14 Vertical Sync 15 N/C (Reserved)
Feb 11, 2010 | Computers & Internet
HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Oct 29, 2009 | HP Pavilion DV6700T Notebook PC
The hard drive won't boot up
the hard drive is dead ( dreaded click of ***** syndrome )
you can have that verified at a computer repair shop and if that is the case use a solid state hard drive as a replacement and not the spinning disc type as for the data you have stored , there are places than can recover it from the dead hard drive but unless you have it all backed up on an external hard drive or storage device then it is lost
Jun 04, 2017 | Adaptec 1 Bay ACS-100 (2177400) USB 2.0...
Computers & Internet Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
