Question about Maytag Dryers
Maytag de7500 will not heat. New heating element.
Maytag de7500 will not heat. New heating element. Dryer spins fine.
  • 7 Answers
SOURCE: Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Posted on Jan 21, 2009
canbruce75
  • 1776 Answers
SOURCE: Heat Element is working and drum spins, but no air is blowing?
First make sure that the dryer is vented properly, then check the blower wheel. A common problem is for the center of the blower wheel to get rounded out through wear and tear, allowing the blower wheel to spin on the shaft, thus not spinning at the same speed as the motor. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 07, 2009
VtToolMan
  • 704 Answers
SOURCE: maytag dryer is not heat up. I think the heating
Hello, There are a couple of variations of the heating element, depending on the series number of your dryer.
Here's a link to the parts list and line drawing so you can verify the proper element you need.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=SDE4606AYW&productCategoryId=0151200&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00005&componentDescription=REAR%20BLKHD,%20AIR%20DUCT,%20ROLLER&HTR%20(ELE)&documentId=M0510059&blt=06
If you have a Series 14 dryer, the element part number is #37001134, otherwise, there are a couple of other elements that your particular dryer might use, so check the model number and product tag so you can get the right parts.
You might want to check the element first, to make sure it is defective, before you order replacement parts, as it might be a faulty thermal fuse, which is much less expensive to replace than the heating element.
If you have a multimeter, you can check the fuse to see if it's failed. Be sure to turn the power off and unplug the dryer before removing the back access panel and checking the thermal fuse (see drawing in link above)
With the meter set to measure resisitance (Ohms) you can put a test lead on each side of the thermal fuse and if you get a reading showing no continuitity, then the thermal fuse is blown and needs to be replaced.
You can also check the heating element using the same method, again, make sure the dryer is unplugged before testing the continuity of the heating element, if you don't get a continuity reading, then the heating element is bad too.
I hope you find this Very Helpful and best regards!
Posted on Nov 13, 2009
  • 53 Answers
SOURCE: maytag DE7500 electric dryer
You need a voltmeter to check the continuity across the two terminals, it should be open. If there is no continuity the limit is bad..
If you found this helpful please leave a thumbs up........
Posted on Jan 09, 2011
  • 552 Answers
SOURCE: My Maytag Mod. DE7500 elec. dryer is no longer
On this dryer the element is what fails, the screws are on the lower front that hold front on. You will need an ohm meter to verify unless you pull the element out and visually inspect it.
http://www.appliancerepairlesson.com/
Posted on Mar 01, 2011
Maytag atlantis gas dryer not heating up
I thank you need a new Heating Element Assembly part # Y308612 here is a image of the Heating Element Assembly
Jan 20, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer heat fails intermittently
Probably an intermittent timer, not the heating element.
Jul 26, 2017 | Maytag Neptune MCE8000AY Electric Dryer
My Maytag Mod. DE7500 elec. dryer is no longer heating up. Starts and goes around fine just no heat
Mar 01, 2011 | Maytag Dryers
Maytag DE7500 electric dryer blows cold air only,checked heating element.ok could it be hi temp thermostat on heating element if so how to check it to make sure
Jan 01, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer willnot heat
heating eliment is most likely burned out. Better off getting new dryer. But if that is not an option then call a repair person that can replace the heating element.
Nov 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't heat up! It tumbles fine, but no heat! My Maytag dryer is only two or three years old!
This problem is normally caused by a faulty thermostat and or heating element. Test and replace if needed
Sep 23, 2009 | Maytag Dryers
Sep 07, 2009 | Maytag MDE308DAYW Electric Dryer
Jan 21, 2009 | Dryers
Not drying no heat.
be element are thermo fuse on element no easy to change remove 2 screws on door hinge 2 screws on the ather side frount comes off there the element
Feb 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
127 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
