Question about Frigidaire ATF6000ES Front Load Washer
Front load washer ripping and putting holes in clothes!
Ok so we are on our second set of front load washer and dryer in less then 10 years! So the problem now is the washer is putting holes in our clothes! I'm very unhappy with the front load washer! Any idea's what's wrong?
We are having the same problem too. Have you find a solution yet?
Posted on Dec 01, 2009
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
Washer ripping clothes
Check the drum baffles (the paddles inside the tub) to see if one is loose and also check the front tub seal for any tears.
Nov 05, 2012 | Washing Machines
Even on "extra dry" on Cotton or Perm Press settings, clothes aren't anyplace near dry when the cycle decides it's done. I always clean the lint filter. I'm not putting in more than washes comfortably in...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 28, 2010 | Bosch Dryers
Washer doesn't stay running. filled with water, then shut down then filled some more and now stuck doing nothing. If push start button if runs for about 5 seconds then shuts off. 10 years old.
For being 10 years old...I'd say R.I.P Neptune. A 10-year-old dryer is going to cost you more in repairs than the cost of a new machine! And even if it is cheap enough to fix, the parts may be no longer available. I used to work at the Harrisburg PA Sears Parts/Service Center...trust me...I know.
Jan 29, 2010 | Maytag Neptune MAH6500A Front Load Washer
Load capacity
2/3 of the drum to the top loosly packed.... no more than that ... the clothes have to drop from the top and down to wash properly, and if overloaded you can rip the front boot off.....300 dollar repair....use he detergents and only use 1/5 of the cap as you have very little water in the washer.....Try to do atleast 2 hot loads a week to avoid mold and mildew smells and buildup....I have been fixing washers for 14 years please follow my advice
Jul 18, 2009 | Whirlpool WFW9500TC Front Load Stacked...
I have a frididaire front load washer, and lately I have been seeing hole like spots on my white or light clothes what is the problem
Check door boot at tub. sometimes is ripped. also check your dryer...at the drum to front panel....felt could be worn and will cause clothes to catch.
Jun 10, 2009 | Frigidaire GLTF1670A Front Load Washer
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Neptune top load holes in clothes
You may have something between your basket (the area where you put your clothes) and your tub (the part that holds all the water in. Check all of the holes in your basket to see if you have something sticking/ protruding out of one of them. You might also have a hole that has been bent casuing a rough edge. Next pull back the edge of your boot (the gray ,rubber part in the front) Do you have any forighn objects in there? Finnaly for the washer, check the bottom of the door. A rough area on the bottom can cause the same problem. You might also want to check your dryer. Over time the seals (the gray rings in the front and back when you look in your dryer can be worn or have a forign object caught in them. Both will cause clothes to snag and tear.
Apr 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire Front Loader Ripping Clothes
Frigidaire washer sucks. I'm tired of this useless machine ripping my clothes. You need to change your bellows(boot) kits around the door on front load. I have changed this kit twice now and each time, I spent $200 in repair fees. I wished I never bought this washer. Will never recommend to anyone i know.
Dec 20, 2007 | Frigidaire ATF6000ES Front Load Washer
GE top load Washer ripping clothes
Solution!
GE has replaced the "boot" (the large rubber gasket at the opening of the washer) on my washer. This has fixed the problem!
Although the majority of people I spoke with at GE did not know about this, eventually I got a repair technician out here who spoke with one of the engineers. The engineer said that there was a problem with the boot causing clothing to rip. The new boot we have on our washer covers a ring of plastic just on the outside of the metal drum (the plastic rim remains stationary while the metal drum spins - this is the cause of the ripped clothing) - the old boot left this plastic ring exposed. Our washer was only 8 months old - so even if your washer is new, if your clothing is being ripped, insist that the boot be replaced for an updated version.
May 03, 2007 | GE Energy Star WCVH6260F Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
798 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
