Question about Amana Dryers
Amana gas dryer lga60 not heating - Amana Dryers
  • 6,784 Answers
Check the following areas to address this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Jun 21, 2009
  • Michael Masters
    Michael Masters Jun 21, 2009
    If all the above is ok, replace the timer/control
I have AMANA NGD 5500TQ0 DRYER AND FIRES WON'T LIT
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 18, 2011 | Amana NGD5500TQ Gas Dryer
Amana dryer not heating up
heatman101
Nov 26, 2010 | Amana NDG7800AW Gas Dryer
My Amana NDG7800AW Gas Dryer won't heat up. The dryer is about 5 years old and we have no problems with it until now. Any suggestions?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 10, 2010 | Amana NDG7800AW Gas Dryer
Amana Dryer NDG5805AW heats for a couple seconds after starting then no heat HELP
heatman101
Sep 08, 2010 | Amana NDG5805AW Gas Dryer
My heating element in my Amana dryer will heat up for a few seconds, but then goes back out. What should I do?
heatman101
Sep 07, 2010 | Amana NDG5800 Gas Dryer
Igniter on Amana gas dryer ,,Not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
wwtt
Sep 04, 2010 | Amana ALG643RB Gas Dryer
My amana gas dryer quit drying
heatman101
Aug 08, 2010 | Amana ALG643RB Gas Dryer
Amana LG4409L Gas Dryer: Ignotor comes on when
The igniter or gas valve could be defective.
Nov 18, 2017 | Amana Dryers
Amana gas dryer only heats first 20 minutes
Check your ducts that the heat blows out through. make sure there is no plug up in the dryer or in the ductwork.
You may have a problem with the termosensor or the high temp cut out safety switch/sensor. This sensor would be somewhere in the exhaust of the dryer.
Feb 04, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
158 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
