2006 Toyota Sienna Logo
L
Liz Ging Posted on May 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you reprogram a remote for a toyota sienna
I have an extra remote that is programmed to an old sienna. I would like to program to my current sienna.
J.J. Feregrino
Level 2:
Loyalty:
Visited the website for 30 consecutive days.
  • Expert 83 Answers
  • Posted on Aug 31, 2018
J.J. Feregrino
Expert
Level 2:
Loyalty:
Answers
83
Questions
0
Helped
93674
Points
493
The exact procedure for programming another remote to your Toyota Sienna depends on the year. Find the key fob programming instructions for your Toyota Sienna key fob here.
John Mueller
Level 2:
Habit-Forming:
New Friend:
  • Toyota Expert 95 Answers
  • Posted on Feb 19, 2015
John Mueller
Toyota Expert
Level 2:
Habit-Forming:
New Friend:
Answers
95
Questions
0
Helped
126708
Points
495
I've written a detailed tutorial for programming a remote for 2004-2010 Toyota Siennas. One thing to note is that you must re-program them ALL to add one. See my website at: John Fixes Stuff How to Program Keyless Entry Remote for 2004 2010 Toyota...
magoly auto
Level 2:
Sergeant:
  • Toyota Expert 303 Answers
  • Posted on Jun 21, 2014
magoly auto
Toyota Expert
Level 2:
Sergeant:
Answers
303
Questions
Helped
158268
Points
873
Before we get into details, if remotes don't match body style or part number it cannot be program to your vehicle they are very specific for each model.
5 Related Answers
Anonymous
  • 1861 Answers
  • Posted on Sep 10, 2008
SOURCE: yaris smart key programing with out scaner
There is no manual method to program a smart key. Impossible. You must use the Toyota scan tool. Sorry.
Anonymous
  • 244 Answers
  • Posted on Feb 14, 2009
SOURCE: 2008 toyota sienna
arent you under warranty
Anonymous
  • 155 Answers
  • Posted on Jul 06, 2009
SOURCE: '00 Toyota Sienna-stuck door
the lock actuator is binding/hanging up, replace it and lube the linkages this should cure that problem....hope this helps...let me know...GL
Anonymous
  • 9 Answers
  • Posted on Aug 20, 2009
SOURCE: 2004 Toyota Camry key fob programation
sit in car all doors closed put key in ignition and turn from OFF to ACC 3 times as fast as you can leaving it in ACC on the last cycle then press your remote button. your blinkers should flash to tell you this has worked.... may take you a couple of tries to get it!!
Anonymous
  • 1861 Answers
  • Posted on Sep 17, 2009
SOURCE: how to program bulldog TX4BL707 on Toyota Rav4
Do yourself a favor and return it to where you got it; get your money back. I have installed several of these for my customers and they all failed withing 3 months. Nothing but trouble, and, their customer support is very poor.
Does the 98 Toyota Sienna have a transponder key ignition
Yes it does, and programmable fob
https://www.carandtruckremotes.com/1998toyotasiennakey.html
Program Remote
PRESS the LOCK and UNLOCK buttons on the remote simultaneously for 1 second. b. PRESS and HOLD the LOCK button for 2 seconds. The Door Locks will cycle LOCK/UNLOCK to indicate successful programming of the remote.
1998 Toyota Sienna Keyless Entry Remote Fob Programming ...
https://www.google.com/search?q=98+toyota+sienna+transponder+key+programming
1helpful
3answers
What is envolved to program a new ignition switch
Hi found this link when researching your post , it would appear the 2004 sienna has to go to a dealer to be programmed , follow this link and see what you think about it
Toyota Transponder key programing
Toyota tundra keyless remote will not program
You have to go to a toyota dealer service centre to program the remote. But I am sure you are well aware of that.
Saab experts
May be keyfob needs reprogramming.
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.
If the remote s faulty then key fob will not get programmed.
Insert the key in ignition. Turn the key to on position, and cycle the key three times off-on-off-on-off-on. Then with the key fob remote select your remote and then try to operate the vehicle with remote.
These are just the basic procedure, but sometimes it will not help.
On that case dealer is the only option.
There are few much related troubleshooting links mentioned below for remote key fob reprogramming. I suggest you to go through the list and click the link below to go through its details and procedure: -------
Theft indicator not letting car to start?
http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html
2009 Toyota Highlander: Smart Key Not getting Detected?
http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
2007 Toyota Prius: Reprogram Remote Keyfob?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
Pin that holds the flick key part to the key fob?
http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key?
http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
Where is Key chip memory located on 2004 ford Freestar?
http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
Ford Keyless Remote Fob Reprogramming?
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure?
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
Audi A8 Key Fob Programming?
http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html
Oldsmobile Aurora Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html
Buick Lesabre Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html
Keyfob remote not working on 2003 Ford E350 Econoline?
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
KeyFob will open the doors but not start on BMW?
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
Mitsubishi Car Key Not getting detected after replacing ECM
http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
Key Fob will not lock and unlock doors?
http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
2000 Jeep Cherokee Limited: KeyFob Remote Not Working?
http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
2012 Dodge Ram: Ignition Key will not release?
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.
Thanks.
Peugeot 206 key fob
Try with brand new key fob battery and see.If that helps.
Otherwise May be keyfob needs to be reprogrammed.
KEYFOB PROGRAMMING
Thanks.
1helpful
3answers
How program the key remot
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.If the remote s faulty then keyfob will not get programmed.Insert the key in ignition.Turn the key to on position,and cycle the key three times off-on-off-on-off-on.Then with the keyfob remote select your remote and then try to operate the vehicle with remote.These is just the basic procedure,but sometimes it will not help.
---------There are few very relted troubleshooting links mentioned below for remote key fob reprogramming.I suggest you to go through the list and click the link below to go through its details and procedure:-------
2009 Toyota Highlander: Smart Key Not getting Detected? http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
----------2007 Toyota Prius: Reprogram Remote Keyfob? http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
----------- Pin that holds the flick key part to the key fob? http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key? http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
----------Where is Key chip memory located on 2004 ford Freestar? http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
----------Ford Keyless Remote Fob Reprogramming?
----------After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
-----------Audi A8 Key Fob Programming?
Mitsubishi Car Key Not getting detected after replacing ECM http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
----------- Key Fob will not lock and unlock doors?
2000 Jeep Cherokee Limited: KeyFob Remote Not Working? http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
----------- Chevrolet Malibu: Key Stuck in ON position? http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
----------- Theft indicator not letting car to start?
2012 Dodge Ram: Ignition Key will not release? http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.Thanks.
2006 Sienna battery went dead. After charging, navigation and radio don't work. Screen works and says "NO MAP DVD - Insert Disc" Checked Radio fuses 1,2 and 3 are good, as well as 12v...
System memory may have been erased/lost due to extended loss of power. System may have to be reprogrammed to effectively work. Do you have the programming CD? If so, check owners manual for programming procedures
My wife lost her keys. I had to by another key and program it to the car. Now, she has found her keys and the remote does not work. Does it have to be reprogramed or do I have to get another one? If the...
The old remote can be programmed again but you need to take the remotes to be programmed together. They must be programmed at the same time and I believe you can program up to 4 remotes per vehicle. I think the venture requires a scan tool for reprogramming. Try this first- 1. Sit in the drivers seat and put the key in the ignition in the off position. 2. With your left hand hold down the unlock button on the door panel and turn the key to the on (not the run position) then off, then on and off. 3. If the horn honks, take one remote and hold down the lock and unlock buttons until the doors lock and unlock, then do the same for the second remote. 4. Now, turn the key to the on position, then off position and the horn should sound again. Try unlocking/locking the car with each remote. **step 2 may require the key to be turned on then off 3 times instead of 2 before the horn honks. This my not work but if it fails it will not change any of the current settings but you will need to have the dealer program the remotes together.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
