Unit makes noise, but no air is coming out of vents
Between last night and this morning, my A/C quite working. When I lower the temp on the thermostat, I can hear noise coming from unit in attic and the unit outside runs, yet no air is coming through vents. I checked the ducts and it all seems connected. While in the attic, the unit makes a hissing sound, like you would hear letting air out of a tank, but nothing else engages. Is there a pilot or something? I need help, its very hot out!!
  • Sqweezinby Jun 22, 2009
    okay, I checked for icing and found none. The ac unit outside is functioning normally and doesnt seem to have a clog in lines. I also changed the filter today. When i switch the thermostat to fan and cool, you can hear the furnace in attic engage, but doesn't blow air. So the blower motor is not working? Easy fix? Maybe a relay or some switch is faulty? Any way to reset the furnace at the furnace behind the panel?
  • 284 Answers
Check the unit in attic for iced up and outdoor unit you may notice ice on lines or connecting tubing and in attic also-------- if so turn unit off at thermostat and leave fan switch on the thermostat to on while sytem switch is off
should be nothing running but the indoor fan
will have to thaw if it is iced up for a while couple hrs. a guess
you will know when it is thawed as your airflow will begin to come back
check your air filter to be sure it is clean
suggestion only-- keep your house thermostat set at 70 degrees or above
you may have developed a refrigerant leak (freon) which would require a hvac service tech to verify.
if it was iced you can turn all back on and try again once you have good airflow again.
or if your system has not been serviced lately? might be a good time to have it serviced?
Posted on Jun 21, 2009
  • panilling9
    panilling9 Jun 22, 2009
    pull the cover off the unit to access the fan may need some common tools could be a reset on the fan but most of the time they are internally protected
    turn the switch or breaker off before you check things
    try to turn the motor by hand is it free wheeling?
    check the motor is it hot to the touch?
    check the capacitor it mounts on the blower housing near the motor with a capacitor tester or ohm meter be sure power is off and remove capacitors 2 wires? check with a meter for shorted cap. constant(ohms) when testing across its terminals. to check open cap. you would need a tester or a good analog meter.
    deflection and come back to zero says its not open only not the capacitance
    check power coming in to the heater a/c blower with a meter to see if you have it to the motor?
    if you have a heater emergency switch be sure it is on....
    if you dont have power to motor for check wires back to the fan relay for power
    check for loose or broken wires in this area also
Kitchenaid Model KGSK901SSS. This is a brand new stove functioning at 6500 ft. altitude. In the morning, the flame from the burners is primarily orange flame. Later in the day and evening, the flame burns...
is the temperature in your kitchen a lot lower in the mornings than later in the day. If yes the problem is caused by the orifice shrinking n low temp .
Oct 04, 2017 | KitchenAid KGSK901SSS Gas Range
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Feb 13, 2011 | Samsung Refrigerators
I have a Frigidaire cooling and heating unit. Last night we had freezing rain and ice. I heard a weird noise coming from the unit then smelled a burning smell. I turned the unit off. The top vent...
Sounds like the motor burned up when the ice blocked the air which it was not able to cool the motor it will need to be replaced. (the motor)
Jan 29, 2010 | Heating & Cooling
Air worked fine all last night and his morning.
if the air comes on for a short time and then turns off for 15-30 minutes, the overload protection inside the compressor is shutting down to protect the compressor. this can be caused by blocked supply or return vents, improper charge, bad valves in the compressor, and a multitude of other things. the problem will have to be corrected first.
Dec 14, 2009 | Heating & Cooling
RV AC unit won't cool, blows chuncks of ice
It's most likely an airflow problem, you say you had the vents closed? Icing up is normally caused by lack of load (air flow) or loss of refrigerant charge. Make sure all your vents are open to allow for as much airflow as possible and that your filter is clean. Some units do not work well on low airflow setting when the outdoor temps cool down at night.
Sep 09, 2009 | Dometic Rooftop RV Air Conditioner
Oustide unit fan won't work
It sure sounds like the out side condenser fan has gone out.If you need to Fix a water hose to run on it like a spray fanning out over the out side coils(condenser)and try and see if it will cool.It will do the trick,until you get it fixed on week days.If I can help,let me know.>>>roniecon@gmail.com
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
One of 2 Lennox AC units not working well.
check the filters if it needs cleaning....or check the refrigerant level if it is below normal
Aug 11, 2009 | Heating & Cooling
Ac making noise
sounds like the drain is clogged, it usually comes out if the outside of the unit just below the coil in the middle of the back, there may or may not be a hose attached to the front pan below the evaporator, try pressuring it up to blow it out. worst case you may have to remove from the window, disassemble and clean. hope this helps...
Jul 18, 2009 | Heating & Cooling
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions hillbuck29@aol.com Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
Ruud Problems
compressor is probably bad. disconnect it tape the wires off and start unit. if breaker doesnt trip it is the compressor.
Aug 17, 2008 | Ruud UAKA030 Air Conditioner
Heating & Cooling Logo
1,523 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
