Question about Microsoft Xbox 360 Console
Two red lights on xbox 360
I just bought an xbox 360 online ( big mistake i know) and the second time using it the fans ran loud and quickly the system shut down - the tv went back to as if the xbox was off and the system displayed two red lights on the light wheel.
    Problem Solver:
  • 16 Answers
Hey Cmull
i had this problem before because my xbox 360 was old, but this fix is only if ur out of warranty because it involves you openning up your xbox 360. It also isnt the case if your xbox 360 isnt very old, it probably means ur fans are finished. Well, back to the solution you take apart your xbox 360, just do a google search on how to dissasemble your xbox 360 if you already dont know how to do so. Just take off all the covers until you see this
then just get and air compressor or something to blow all of the dust out. i did it for mine and it never happened ever again. Enjoy.
Posted on Jun 22, 2009
  • 767 Answers
There is hope. sound like the x clamp mod failed
its at an angel ,or not makeing compleat contact
with GPU which casues to unit to over heat in about 3 to 5 mins
The fix is to reclamp the GPU.
Posted on Jun 30, 2009
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
3 rings of death turned to 2 rings. xbox 360 NEED SUGGESTIONS
you probably did something to where you messed up your xbox motherboard, making it (after less then a minute of power) get short circuited and power fails. i would recommend getting it repaired by microsoft if you have a warranty.
Dec 03, 2009 | Microsoft Xbox 360 Console
Xbox 360 wireless ownt work
xbox 360 wireless adapters are usally the worst to get.
i suggest buying a long enough ethernet cord and using that, a 50m ethernet cord is around about $25. so pretty cheap.
Sep 25, 2009 | Microsoft Xbox 360 Console
Xbox has two red rings and fan gets louder by second????????????
reflow the joints on the board it should fix the issue then let it sit for an hour and cool down
Aug 30, 2009 | Microsoft Xbox 360 Console
My Xbox 360 makes a loud humming noise while i play
The Xbox 360 does not like to be moved when playing a disk some of the mechanics may have misaligned or slightly out of sync this may be reason the DVD drive is making those sounds.
I strongly recommend you remove any visible dust from the 360 especially the sides and air vent holes using a vacuum cleaner. Once youve cleaned it place it horizontal (never on carpet) on a flat surface well ventilated away from other devices that generate a lot of heat.
As for the 'shredding sound', place in **** game into the 360 when it starts to make those sounds again gently tap the 360 on top (where the DVD drive is) until it stops making that sound. This doesnt always work but has for me and many others.
My experience tells me that dust can build up not only inside the 360 but also the drive itself which can lead disc read errors and the sounds and you mentioned.
Remember DUST and HEAT is the 360's biggest enemy and can cause RROD, 1 Red Light Problem, and disk errors.
Hope this helps..good luck!
Jul 27, 2009 | Microsoft Xbox 360 Console
2 red lights fans don;t work
Hey Marsh2Man,
It's not your fans that's causing the problem. It's the XBOX itself. The Xboxes generally overheat and this has been a big problem for Microsoft. Alot of companies are actually reflowing these system, reheating the solder under the chips allowing them to connect back down to the points on the board.
You will need your system reflowed. Contact a repair shop.
Jun 02, 2009 | Microsoft Xbox 360 Console
Well when I turn on my xbox 360 the third part flashes red.
hello.
CAUSE The three flashing red lights may indicate that your Xbox 360 console has experienced a hardware failure. Please read the letter that discusses warranty changes for three flashing red light hardware failures.
MORE INFORMATION
If you suspect that you are experiencing this issue, you can submit a console-repair request online. However, before you submit your request, we ask that you first try the following two steps to verify that you are indeed experiencing this issue:
1. When you turn on the console, examine the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps that are listed in the following Microsoft Knowledge Base articles:
906101 Xbox 360: The power supply light is red 906102 Xbox 360: The power supply light is orange 906103 Xbox 360: The power supply light is not illuminated
2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the symptom occurs again. If your console continues to display the three flashing red lights, your console may have to be repaired. For information about how to start the repair process online, please visit http://www.xbox.com/support, and then click Console Repair in the upper-right section of the Web page.
Note: The online console repair service is currently not available in all countries or regions.
If you would rather contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact for information about how to do this.
APPLIES TO
* Microsoft XBox 360 Video Game System
* Microsoft Xbox 360 Hard Drive (20 GB)
* Microsoft Xbox
Apr 27, 2009 | Microsoft Xbox 360 Console
Xbox360 1 Red light, sometimes 2
there are two things that those light mean.
-the best solution is to VACCUM the dust out of the xbox before you get other problems. The collecting dust is making ur xbox overheat. So keep it clean before you get the 3 or 4 rings of death!
-also, take off that cooling system because the 360 works best without cooling fan.
-Finally, make sure your A/V cables are securely plugged in.
Mar 23, 2008 | Microsoft Xbox 360 Console
360 probs
3 Red Lights: General Hardware Failure
This could one or more of many different problems. Before doing anything rash, I suggest you just send in your xbox provided it is still under warranty. If it's not, then there are ways. The most heard of way that I know of is knows as "the towel trick." Below are links I have found providing more information on this "trick".
http://en.wikipedia.org/wiki/Xbox_360_technical_problems
http://three-red-lights.blogspot.com/2008/01/towel-trick-how-to-fix-your-xbox-360.html
BEFORE YOU GO AND DO THIS: I urge you to not leave your xbox alone as it could potentially start a fire. Not likely, but possibly.
I personally believe this to be quite possible. There have been numerous cases reported to verify that this can work. It is not 100% full-proof. I can tell you that it will not void your warranty. If you have a warranty, it may just provide a quick fix for you while you wait on the packaging.
Other than that, you can find more info online on ways to fix it but may involve voiding your warranty.
Mar 22, 2008 | Microsoft Xbox 360 Console
As playing Xbox 360 system shuts off two red lights occurs.
Two red lights mean your 360 is over exceeding the inside temperature. Your fan must not be working at all and your 360 is overheating tremendously. That is what I know about the 2 red lights. Im not sure what to tell you to fix this but to just call 18004myxbox.
Mar 01, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
162 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
