Question about Garden
Craftsman GT3000 Lawn Tractor
Have a craftaman GT3000,lawn tractor. one of the housings that the blades bolts to has a bearing going bad. My question - If I need to replace one. I might as well do all three. Can I get by with just the bearings, # 110485X, or do I need to get new shafts and housings as well?
    Problem Solver:
  • 18 Answers
Searsparts.com has all the parts you need.
Posted on Jun 21, 2009
  • Truckerjohn Jun 22, 2009
    I replaced the housings all three and bearings two years ago with no problems. The reason I put searsparts.com on my post is you order what you need and delivered to your door in a couple of days. 80% of what I own is from Sears becouse they have parts for everything they sell. Hope this helps. Better thay my last post. I'm new at this Fixya help web site.
Have gt 3000 craftsman riding garden tractor. battery reads 19 volts. what is that all about
Posted on Mar 27, 2011
What is the drive belt diagram for a Craftsman GT3000 lawn tractor?
https://www.scribd.com/document/148079291/Craftsman-GT3000-Owners-Manual
Aug 06, 2017 | Craftsman Garden
How do you check to see if Drive pulley bearings are bad
take belt off, grab blade at end and watch center bolt move more than a little bit or swing by itself when turned loose. Try turn blade with hand to feel bearing roughest is another way
Jul 13, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman riding mower vibrates so bad when I engage the mower. How do I stop vibration?
Things you need to check, loose blades, blades out off balance, bad belt or loose belt, bearings in the blade mandrels worn.
Jun 29, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you change the blade on a craftsman lawn tractor model 917.28726? I have the tractor on ramps, but can't seem to get the bolt off!
Disconnect the spark plug wire from the engine to prevent accidental starting. Use a wrench or socket to remove the bolt, turn in a counter clock wise rotation for removal. You'll need to hold the blade still while attempting to remove the bolt. Use a breaker bar for more leverage if needed,sometimes these bolts are difficult.
Sep 01, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman 42", 18.5 lawn tractor: blades are hitting in the mower deck. Blades are new and deck is balanced. Is it wear on the Mandrel - Shaft? Mandrel bearing?
Oh boy!!! Welcome to the craftsman worst design of their mower decks CHEAP!!!!! I had to replace my mandrel on the right side, side where the grass shoots out several times!! Cheap aluminum casting ****, one or more of your ears on the mandrel probably snapped, if you have an air wrench they are not too bad to replace, the screws that go into the mandrel are self threading and is easier to work on with air wrench but can be done with socket set, hope this helps!!!! good luck!
Aug 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Replacing blades
It is standard threads and should turn left.
May 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Sep 29, 2008 | Garden
Garden Logo
1,532 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
