Question about Kole audio QX2-1920 Car Audio Amplifier
Bad ground feedback?
My car is giving bad ground feedback. i tried everything moved the ground many places in the car. can it be the deck?was working fine then one day started feedback bad?
    Problem Solver:
  • 13 Answers
Make sure you run the Positive wire from battery on one side,which is normaly the drivers side. Then run the remote wire and the spearkers on the passininger side. Feedback comes from two places, Your radio or your amplifiers. If running to amps always run sepert positive wires with 25amp fuses on each. For the ground (8g) and power wires are always best at 4g or 8g wiring. The ground wire must go to a clean spot of metal that is ether the frame or chasey of the car. Plus use metal srew to mount the ground wire. If it is not giving you feedback then thats a good ground which is ok to mount 2 or 3 amps max. If you still hear feedback, it's time to look at the radio and make sure the ground wire is good.
Posted on Jun 21, 2009
Loud buzz from deck, seems to be coming from RCA cable
It seems that is bad grounding of the gear, check i everything is conected to ground. I can also be the quality of the cable, Bad cables can produce a lot of noise, try using other cables.
Apr 07, 2015 | Technics SL-1210 Turntable
Technics SL 1210 feedback/grounding problem.
Do you have these turntables on an anti-static mat, or some other non-conductive surface?
Jun 09, 2008 | Technics SL-1210 Turntable
Wiring JVC car deck
Do you have factory infinity sound. If you do you need a another harness or bypass that infinity system. Also What year is the truck. I know for a dodge ram after 02 is a canbus system. When wiring in the harness leave the blue remote wire alone do not connect from radio harness to the harness that connects to factory harness. Unless you are running to an aftermarket amp. There is a brown wire also that you should not connect leave the remote blue and brown wires alone. this is atleast on a 02 dodge 1500 or newer and 03 or newer 2500+. not sure if this will solve your issue but it fixed my buddies.
Apr 29, 2013 | Dodge Cars & Trucks
Two problems...1) I have a faint blue horizontal line that is moving from bottom to top. It is rather distracting. I also am getting a lot of feedback in the desktop speakers. The light green wire is...
try the monitor on another PC, be super simple and ends 1/2 the possibles is 5 min works and what we cant do here.
bad cable? is my wild guess.
feedback (with no mic?) or just noise, feedback is squealing.
with the green jack speaker wire pulled is the screen ok now?
Dec 05, 2017 | HP W19b LCD Monitor
I have a fairly good sound system in my jeep cherokee, new speakers, deck, new battery, rca cables, and a new box for my subs. But recently i've been dealing with some problems. i've had my amp grounded...
there are really only 2 causes for this.
  1. grounds. Make sure the grounds are clean and tight and all paint and dirt was removed before they were fastened.
  2. Your alternator is starting to go bad.
I would lean toward the grounding problem as you have said you just changed them. Also make sure the grounds are as short as possible.
Dec 24, 2009 | Car Audio & Video
I have a 1991 chevrolet caprice classic and
BAD GROUND. CHECK GROUND CONNECTION IN THE KICK SIDE OF THE DRIVER PLACE, UNDER CARPET YOU WILL FIND A NUT ATTACHING SEVERAL CABLES TO CHASIS, CLEAN AND RE ADJUST
Sep 18, 2009 | 1991 Chevrolet Caprice
Eating gas bad no leaks
You either have a bad O2 sensor or you can try to reset you computer by disconnecting the ground cable on your battery for about a minute and then reconnecting it. It will then take about 50 to 200 miles for your computer to decide if everything is working right.
Aug 05, 2009 | Chrysler Voyager Cars & Trucks
My car amp wont come out of protection mode.
hey i had this happen to me, pull the deck out and move the rca cables to a different channel and see if that does not fix it. i blew out my sub pre out channel in my deck and had to use the rear pre outs. try this and let me know what you come up with. good luck
Mar 07, 2009 | American Pro Car Audio & Video
Gemini cdt-05 hybrid grounding noise
Well, number #1 - it's a Gemini. So, you can rest assured that the craftsmanship is not the greatest. It's hit or miss with this company.
#2, if the issue you are having is a ground issue, then perhaps the internal ground wire might have come loose, or there is some sort of interference somewhere. Do you have your turntables next to anything that draws alot of power? Such as air conditioner, or a microwave, fridge, etc? Also, connecting to the same power outlet with something that draws alot of electricity might have the same effect. Try a different power outlet. One that is not being used if possible. If you use a power strip or extension cord, try a new one.
There could be many issues which cause feedback.. the main thing is to determine what is NOT causing the problem. So, you know it's NOT your mixer. Great. Now, move on to the next step. Check your cartridges also. Try swapping them out, see if the problem follows. Many times the tonearms aren't grounded properly. There are 5 wires coming out from the tonearm - L+, L-, R+, R- and GROUND. If the ground came off during transport, or movement, this might be your problem.
- Davis
We are the Turntable Experts!
DIGITAL ANALOG THERAPY
Aug 08, 2008 | Philips gemini CDT-05 Turntable
Humming noise/ feedback
your mixer should be grounded by the power cord, and the decks have a seperate ground wire which connects, usually on a screw terminal, to the mixer, which provides the ground for the decks. I would try the headshells to make sure they are tight and connected correctly also make sure the power socket on the wall is earthed properly.
Feb 19, 2008 | Stanton STR8-150 Turntable
Car Audio & Video Logo
144 people viewed this question
Top Kole audio Car Audio & Video Experts
David Burbee
David Burbee
Hashim Khan
Hashim Khan
Terry Hair
Are you a Kole audio Car Audio and Video Expert? Answer questions, earn points and help others
