Question about Casio Privia Px330 Px-330 88 Key Digital Piano New
How do you adjust casio px 300 when connected to ipad2
Usb out to camera connector on the ipad in,the keyboard is not recognized
    Champion:
  • Casio Expert
  • 411 Answers
Newer Casio models that have "class compliant" USB interfaces such as the PX-330 would work (plug and play) since they now have "class compliant" drivers.
Unfortunately PX-300 is an older model that would need specific drivers and Casio only made drivers for Windows PCs.
Posted on Aug 12, 2014
SOURCE:
SOURCE: Casio Privia keyboard PX-100
There are a number of issues that could cause this, the most likely culprit is the power supply, when I say power supply I mean the internal power supply,
This means that you have already obtained a good "known to work" AC to DC power supply, and tested it on your keyboard to see if that is the problem.
If you have completed this step, then your next step is to test your unit with batteries only, if the keyboard works, then you know your problem, is internal to the keyboard.
There are two issues to check, before proceeding please read the following note.
 (a note here for those who have no experience working with internal electronics)
If you have no experience working with internal electronics I would not recommend, opening your keyboard.
Two reasons, one, will void warranty if it still is under warranty.
secondly, you could accidently cause more damage to the unit.
Now if you are still reading, and feeling confident, you know that as a child you have dissembled many many electronic devices, just to see how they work.
If you do decide to open the box, disconnect the power supply to the unit including any batteries.
open the box and locate the power on button, clean using a Dielectric cleaning agent, can be obtained at most electronic specialty stores.
clean the power button, may work but doubtful, usually the switch itself is usually bad, there is a way to test the switch, however, that is beyond the scope of this answer, if you are following this you will most likely have the knowledge to do this.
The second and more challenging issue will be the internal power supply to the keyboard, or the interface that connects to your ac to dc converter.
This can be much more trickier, and I wont go into it here.
If you test your power switch determine that it is good then you should consider getting the unit serviced by a technician.
If you examine the boards, (electronic circuit boards,) and notice burned, connections, (darker than other circuits) then most likely it will not be worth trying to fix.
Hope this helps somewhat, if nothing else, take this print out to your local service dealer, and that will help in getting your keyboard repaired,
Delete this part, before taking this to your dealer,
Most electronic products can be easily fixed with a power switch, or power supply, however, many dealers will not tell you this and give you an estimate of fixing the unit that far exceeds the actual cost of repair,
an example, in a local TV repair shop, a friend brought in a wide screen Plasma HD TV, quoted repair, $654.00  problem,
power supply, actual cost, $75.00 my friend ordered the part online and with the help of a friend installed the new power supply returning his unit to full functionality.
So beware,
Posted on Mar 05, 2008
  • 5603 Answers
SOURCE: not able to connect to USB MIDI of my Casio CTK 810i
On reading specs, use of the USB is NOT supported on a MAC or on other than the 32 bit version of Vista. If you happen to have the 64 bit Vista, it won't work. All the other versions of Windows seem to be supported..
SOMETIMES one must install the software BEFORE connecting the USB cable to the unit. SOMETIMES one must install the drivers in SAFE MODE. These things are ridiculous, but some of the quirks of Windows are stupid.
Posted on Sep 09, 2009
  • 1140 Answers
SOURCE: Casio Privia PX-120 cannot be connected to Reason or FL
When you are using midi the sounds from your keyboard aren't sent anywhere. What happens is control messages are sent over the midi cable from midi out to midi in on the other device which must have midi sounds on it (in your case the sound card) to make any sounds. The messages can be things like note on/of or pitch bend etc. If you want to send messages to produce a result on your laptop and still here something you can loop the messages by running from midi out on the device end ( your laptop) back to midi in on your keyboard. A much better explanation is available here:http://www.indiana.edu/~emusic/etext/MIDI/chapter3_MIDI.shtml I also signed up to this site (its free) that has great people and lots of info:http://www.recordingreview.com/ I recommend downloading Killer Home Recording setting up which at this time is also free and has the best advice you could want in it. I'd also recommend checking out Reaper which is comparable to Reason, Cubase or Protools. If this helps please let me know.
Posted on Jan 21, 2010
  • 5603 Answers
SOURCE: Casio Privia PX-800: When using the sustain
Check if the cble frm the pedal MIGHT be flexing or pulling on the keyboard case when you use it. Such movement COULD vibrate the power connector causing your problem.
Make sure you have the right power supply for the unit as one with too large a hole for the power pin would be intermittent like this.
Posted on Jan 26, 2010
sparky1500
  • 1066 Answers
SOURCE: have a casio px 320 and trying to use it in
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
Posted on Nov 30, 2010
Midi Keyboard
I suggest taking it to the shop. The connector may need to be re-soldered, and if you make a mistake the keyboard could be damaged furthur.
May 04, 2015 | Music
How do you connect a casio privia px 330 usb to ipad 2
Casio don't supply PX330 drivers for IPAD.
Get a Windows 8.1 tablet or connect PX330 to a desktop PC and use IPAD to Remote control that PC.
Apr 27, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Where can i get a ctk 481 driver
CTK 481 only has MIDI-IN and MIDI-OUT ports & no USB. So you need to buy a USB-MIDI interface (cable-like) preferably one that is class-compliant for you OS. Class-compliant device do not need drivers (PCs, MACs, IPAD).
Mar 08, 2014 | Casio Keyboard Ctk-481 Ctk-631 Ctk-651
I want to record from my Korg M50 to Cubase LE4 on my laptop.
Hello, To record into a lap top you will need a USB mixer, your audio output from the SYNTH will go into the mixer, you use the midi USB cable from the mixer to the lap top. this will help pre amplify your synth to normal audio levels. hope this helps.
Feb 17, 2014 | Korg M50 61-Key Music Workstation Keyboard...
Hello guys, i have a problem with my midi keyboard. My PC doesn't recognize the USB connection and i can't find any solution.
Well first start by verifying USB port works by plugging in a hard drive or something thus proving you have a good port and USB Cable. At which point hook the keyboard up ( and make sure to properly install drivers provided on cd with purchase) being a pc this may take several attempts to install. What software are you trying to control? Reason? Logic? Fruityloops?
Oct 07, 2011 | Alesis Q49 USB/MIDI Keyboard Controller
How do i fix the usb port on oxygen 49 it seems to be loose . the keyboard powers on but is not being recognized.
The usual problem of these not being recognized is improper installaation or missing the driver software in the computer. The jacks sometimes appear loose but that can be normal. If you wiggle the jack and there is marginal connections, usually the computer will respond with the USB found and the disconnect tones. If the USB cable has been yanked, then solder could have been broken at the connector. Opening these units one has to be very careful to not damage the cables between the halves of the shell... also keeping track of the screws and type is a must.
Sep 07, 2011 | M-Audio Oxygen 49 USB Midi Controller
I want to transfer some midi files to my Casio LK-230 keyboard. When I plug in the usb cable it does recognize the casio unit but it does not show up on my computer...like there is not unit... How do...
The keyboard will NOT show up on MY COMPUTER as it does not have memory to record and save MIDI files... It will PLAY them real time as the computer sends the data to the keyboard. You can't transfer and save the files IN the keyboard. Some higher level keyboards do have memory and even hard drives... this one does not. This one will have some built in,that you can play but even those you cannot access as if they were memory.
With the USB cable connected, you should be able to see the device listed in the device manager section of the control panel under system hardware.
Apr 03, 2011 | Casio LK 230 Lighted Personal Keyboard, 61...
My oxygen 49 3rd generation (m-audio) midi keyboard just stopped working for me. Ive tried changing the usb lead, and I've tried it on a different computer, and it still doesn't work. I have a macbook pro,...
If the keyboard is lighting up, there is a 90% chance the problem is in the software in your MAC.
Hint: Software "breaks" easier than the hardware !!!
Re-install your software as a first step.
Sep 12, 2010 | M-Audio Oxygen 49 USB Midi Controller
Connect usbtocomputer
Hello - I am too a personal owner of a CASIO CTK keyboard, a little older than yours (model CTK-601) a great keyboard BTW, and I have connected it to my computer successfuly.
There are 2 ways of connecting the keyboard to your PC......Using the MIDI outputs and a special MIDI to gameport adapter - if you have a very old system and have a joystick port (D-sub shape) on your soundcard or PC, then you use that cable. Of course this is legacy and stopped existing in newer computers, now USB is used.
Only the professional line of soundcards have direct MIDI inputs. For most of us, with consumer soundcards and PCs, there are no MIDI inputs.
The good news is that newer keyboards support USB MIDI and features direct USB connection - so all you have to do is install the drivers that are provided with your keyboard, usually a CD, and follow the instruction to install the USB drivers for your casio keyboard, BEFORE you plug in the cable (very important!) once installed you reboot and connect your keyboard using a USB cable
Now if your keyboard is older and has MIDI outputs, like mine for example, you will need to purchase a MIDI to USB adapter, those have MIDI cables in one end that plug to your keyboard and the other end a USB connector....... I don't know about the rules if I am allowed to post websites, but the product i'm using is the Uno from M-Audio - in google do this search:
"m-audio"uno
(exactly as shown above with quotes, and uno outside quotes)
Your CTK-810 may alreayd have a USB connector on it, as it is a newer generation keyboard - I am pretty sure it does - what you will have to do as stated above is located your bundled CD-ROM and install the USB drivers - you will need to purchase a USB cable (seperately).
Aug 17, 2009 | Casio 76 Key Smartmedia Keyboard
Casio Privia Px330 Px-330 88 Key Digital Piano New Logo
143 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
