Question about SanDisk Sansa e250 MP3 Player
Memory full!! unable to create database
I've had my sansa e250 for more than a year now and it's been fine until today, when i tried to sync some new songs to it. At first my laptop couldn't register my sansa, but when I tried to go ahead with the syncing it went ahead. But then suddenly it says on my screen,"Memory full! Unable to create database," eventhough i KNOW for a fact that i have about 500MB of free memory left in it.
So, I unplugged my sansa and it just hangs! I tried shutting it off by pressing the off button but it didn't work. So, being desperate, I unscrew the back, and shut it off my taking out the battery for a bit. When i turn it back on, the"Memory full!" came up again, and i checked through my playlist and all the songs were gone!! I checked my memory, but still only 500MB was available. Tried to reset everything, but it doesn't seem to work. HELP ME!!!
Re: memory full!! unable to create database
Plug in the mp3 to the computer, go to my computer and look for Removable F: OR Removable E, right click and press format and hit ok, it will reset the whole mp3
Posted on Nov 04, 2007
0 characters
3 Points
When turning on my sansa e250, the msg "Refresh Database" and "Not enough space for music DB. Please free 6MB" display on the screen. How do I do that?
Remove the microSD card, then connect the player to your computer and delete stuff from its internal memory until you have 6MB free.
Jan 26, 2010 | SanDisk Sansa e250 MP3 Player
I need help
The device is supposed to refresh each time in case you put in a new memory card or added additional files. That's not the problem - this is: There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
May 16, 2009 | SanDisk Sansa e250 MP3 Player
My Sansa e250 won't stay connected or sync
haha your welcome. good luck with your mp3 player in the future!
Dec 26, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Refresh Database
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
Mar 16, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database message
Check out solution 4 here:
Several people have said that it didn't work for them but it has worked 100% for me. I've bought about 10 problem Sansas from Ebay and fixed them all at (least 6) with this problem.
Feb 27, 2008 | SanDisk Sansa e250 MP3 Player
SD card wont let me add anything
I don't think that the sansa e250 supports sdhc cards these cards 4gb and up are only compatible with newer electronics
Jan 28, 2008 | SanDisk Sansa e250 MP3 Player
How to upload songs into Sansa E250
Th device may be too full. You need at least 6MB for each GB of music on the device to create the "database" or GUI. Delete a few song, restart the device. Best of Luck.
Oct 08, 2007 | SanDisk Sansa e250 MP3 Player
Unable to find new songs on SD card
If your device is too full, it wont have enough room to create the music database for the new songs. Move some of your music off of the device onto the memory card. Try to keep about 10MB free for each GB of music you have. You can add to this question for further assistance. Best of Luck.
Sep 24, 2007 | SanDisk Sansa e260 MP3 Player
First switch your USB control to MSC. Then turn off your mp3 player and activate the hold icon. Then turn it on while holding the record button with hold icon still being activated. then it will go to recovery mode. Now plug your sandisk into the computer and wait until it says RECOVERY COMPLETE...PLEASE DISCONNECT or when it just says for you to disconnect. This worked on my sandisk, and it hopefully work for you.
Jan 13, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
83 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
