Question about Maytag MDB6000 Dishwasher
My dishwasher will not drain. I have taken it apart and cleaned the screens but it still will not drain. Any ideas? It is a Maytag MDB6000AWW
  • 439 Answers
More than likely it is your food disposal. Remove your drain line from the disposal and clean and inspect it, then clean out where it connects in the disposal. This should allow it to drain, if not remove the drain from the bottom of the dishwasher and clean it out there. This should fix your problem.
Posted on Jun 21, 2009
Heating element will not shut off
Check thermostat. If it is Ok check other parts that triggers heater circuit.
Apr 05, 2010 | Maytag MDB6000 Dishwasher
I have a Maytag MDB9100A leaving food particles
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
m,.bn
Feb 23, 2010 | Maytag MDB9100A Dishwasher
We have a MDB6000AWW model d/w. It is leaking
Yes what happens is it gets past the rubber seal somewhere higher during the cycle and gravity pulls the water down to where you see it leaking. 11 years is a good lifespan of a door seal. Plus they are easy to pull out and replace. Just yank it out and push the new one in. Hope this helps.
Jan 25, 2010 | Maytag MDB6000 Dishwasher
Dishwasher doesn't drain
The drain motor might be worn so it still pumps out fairly well but will let wtare back in once it stops pumping. It may also have something stuck in it so it ot is worth removing and cleaning through with a good degreasing cleaner.
Sep 10, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Does not drain!
did you check to see if the pump is plug with stuff
Jul 28, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag dishwasher that won't drain when finished
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jun 22, 2009 | Maytag MDB6000 Dishwasher
Dishwasher will not drain completely
dishwasher will not drain.kenmore model.
I have taken it apart can not figure our how to take out last plastic part a bowl shaped black plastic.
Mar 22, 2009 | Jenn-Air 24 in. JDB1250 Built-in...
MAYTAG DISHWASHER MODEL MDB7100AWQ
My MDB7100AWQ has suddenly stopped working. It will fill but then stops and will not move into wash. When I press the drain/off button the lights work but it does not drain. I do hear a switch in the door operate when I press the drain/off.
Jan 21, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
398 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
