Question about Amana ARS266ZBS Side by Side Refrigerator
Refrigerator compressor cuts off , ice starts melting ,frozen food gets mushy. After a while it starts again and runs a day or two fine. then compressor cuts off again , same thing. I cleaned the condenser coils. It starting working properly again. This morning it quit again. this time I turned the red button on the defrost timer just a bit to the right( clockwise) and it started working. What could my trouble be?
  • 87 Answers
SOURCE: Refrigerator
Have looked at the schematics for this cabinet and am unsure as to the location of both defrost thermostats as unclear on drawings. The purpose of the defrost thermostat is to overide the heater and end the defrost cycle, once the temperature on the evaporator is high enough (normally around 0'C). If you have two then one will probably control the heaters going off and the other may well control the fan, for coming back on. I.E. once the defrost has ended the second sensor will tell the fan when the coil is cold enough to come on, this prevents heat being pushed into the main area after a defrost cycle. If you feel competent enough then I would bypass the heater thermostat temporarily and see if the heaters kick in. The other thing to check is that you have a resistance across the two ends of the defrost heater. In my experience the heater is the most likely to fail, the sensor sometimes fail and the timers rarely fail. The age of your cabinet would suggest the heaters. Please do not leave the sensor bypassed as it performs an essential role. Hope this helps.
Posted on Sep 05, 2007
catriver
  • 878 Answers
SOURCE: Constant freezing up
Doug, This model has an adaptive defrost board. You can put it into a forced defrost through the control panel. Most of the time I have been finding the control board (Jazz) board to be the culprit. To enter into a forced defrost, open the right door only. Hold the light switch down. Press the refrigerator temp down key 3 times. Release the light switch. Display should show Fd. Press the refer temp down key 1 more time to confirm. Toggle between short S and long L defrost by pressing the refer temp up key. For testing, use the L. Press the refer temp down key once more and you are now in defrost. Now, if you want you can peel the freezer back panel off to see if the heater is coming on. With it in forced defrost you should hear sizzling and popping after a while. To get out of the test mode, just close both doors. The Jazz board, part 12002449, is in line with a defrost bi metal that sits on the evap. If the bi-metal is bulged, that could be the problem. Like I said earlier, I have found in most cases the Jazz board itself to be the problem. Hope this helps you understand the refer a little better...Catriver.
Posted on Oct 06, 2007
aborcass
  • 2651 Answers
SOURCE: Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
Posted on Apr 02, 2008
SOURCE: defrost timer board for mzd2766geq
Defrost control board is in the top of the refrigerator behind the two levers that control the temperature. You have to take off the plastic cover. There are two screws and then you slide to cover to the side to remove. The board is in a white plastic housing.
Posted on Aug 25, 2008
SOURCE: Maytag PBF 2255 HEW refrigerator defrost timer location?
These look like schematics that might help you.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=PBF2255HEW&mfgModelNum=&fkMfgID=1
Posted on Dec 27, 2008
GE Profile refrigerator does not get cold enough to keep food. The compressor is humming but even after having it plugged in for 3 days it has not frozen anything or kept any of the food cold.
Could be the t stat not shutting the unit off..so it runs all the time untill it freezes the evaporator in the the freezer then it runs and runs and gets hot...or if it has had a compressor replace before..the freon level what not put back in thr right way..meaning its overcharged, or undercharged..this will also do this...The coils are dirty under the unit...
May 29, 2014 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ge profile pss25sgna - freezer 60 degrees and fridge 58
the compressor is not running,you need to buy a new ptc overload/relay and replace the defective one on the compressor,it unplugs off the side of the compressor,its what starts and runs the compressor
Mar 16, 2013 | GE Refrigerators
The fan is constantly running and the refrigerator is not cold enough and the freezer is not cold either. all the ice melted and the food thawed. i was out of town for 4 days. returned last night to find...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 27, 2011 | Refrigerators
Food defrosted pulled away from wall improved then defrosted again. Un plugged for day in case frozen somewhere, plugged back in and worked for a day. Now defrosted again. At times fridge has frozen food...
Refrigerator
heatman101
Feb 23, 2011 | Frigidaire Gallery Series GLRT83TEK 30"...
Ice maker not working and freezer not cold enough, food is not frozen solid, but ice we put in tray does not melt completelyu
Refrigerator
heatman101
Feb 05, 2011 | Microwave Ovens
I have a Kenmore/Frigidaire side-by-side that shut itself off while I was gone for a few days. When I returned the frozen food and ice had melted and food in the refrigerator was at about 50 degrees. I...
you say its operational again, does that include the cooling as well, or is it running and not cold. if its running and cold, and it was not running when it was previously discovered warm, then your problem is likely with the cold temperature control that you adjusted to get it going. When you first adjusted both controls to the coldest setting, did the unit kick on then or shortly thereafter? then absolutely that is your problem.
Mar 06, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Beaumark Bottom Freezer Refrigerator Doesn't Work
problem is probably that the evaporator is frozen up preventing circulation of air and the fan is jammed with ice.
remove the back panel inside the freezer. melt off the ice with a hairdryer taking care not to heat up any stats mounted on the pipework.
appliance will now work but this is a temporary repair. you must find out the cause of the ice build-up ie why not defrosting.
for starters, check the defrost heater and the thermal cut-out inseries with it.
let me know how you get on and what you find. make sure the fan is free to rotate.
tresilla
Nov 05, 2008 | Refrigerators
Freezer/Fridge work SOMETIMES
Sounds like you have a bad relay on the compressor or a bad compressor. If the compressor is a Tecumpseh brand then it is most likely the problem.
Oct 04, 2007 | Jenn-Air JCD2290HES Side by Side...
Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
Apr 21, 2007 | KitchenAid KSRS25ILSS Side by Side...
Amana ARS266ZBS Side by Side Refrigerator Logo
215 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
