Question about Sony Playstation 3 (PS3) Console
DNS error 80710102
I need help with an error code that is coming up on my PS3 - DNS 80710102. I've restarted my modem, restarted my PS3.. and still no luck. IP address was fine. please help?
    Scholar:
  • 46 Answers
If you receive an eight digit 800 series error code, there may be a few solutions.
Update the System Software.
Visit Playstation 3 System Software Update to download and install the most recent version.
To check what version of the System Software is currently installed on your PLAYSTATION 3:
1. From the XMB home menu, go to (Settings) > (System Settings) > [System Information].
2. The system will display the System Software version number.
Power-Cycle all Network Equipment
Power-cycle means to turn the networking devices OFF (i.e., unplug it from the power source), and then to turn it back ON after a set period of time. This will allow the network devices to refresh its settings.
Please power-cycle ALL of your network equipment, including any wireless access points, routers, Voice Over IP (VOIP) modems, and broadband modems for two (2) full minutes. After 2 minutes, you can turn on (or plug in) your equipment.
Check Your Enviroment
  • Make sure to allow adequate ventilation to flow from the PLAYSTATION 3's vents (i.e., avoid obstructing the vents with long/shaggy carpet, inadequate airflow from cramped entertainment cabinet setups, etc.).
  • Make sure to keep the PLAYSTATION 3 away from excessive dust, smoke, steam, extreme temperatures, humidity, or direct sunlight.
  • See the PLAYSTATION 3 system Safety and Support manual for full details on Safety Precautions and Use and Handling (manual included with the PLAYSTATION 3 system and available for download from PLAYSTATION 3 Manuals)
Restore Default Settings
During certain troubleshooting situations, it may be necessary to restore all of the PLAYSTATION 3 system settings back to their original "default" configuration.
  1. From the XMB home menu, go to (Settings) > (System Settings) > [Restore Default Settings].
  2. Once you select [Restore Default Settings], you will see a list of settings that will be restored. Scroll through them and press the (X) button to restore the settings.
  3. After the operation is complete, you will see the initial setup screen that appeared the first time you turned on the PLAYSTATION 3.
    You will need to go through the initial setup screen before you can use the PLAYSTATION 3.
IMPORTANT
The Restore Default Settings feature will erase any previously saved settings and restore all of the following settings to the default:
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Date and Time Settings
  • Accessory Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
  • Internet Browser Settings
Also, do not confuse "Restore Default Settings" with the "Restore PS3 System" option (the next option down on the menu). The "Restore PS3 System" will not only restore the default settings, but it will also delete all hard disk content (You will lose all saved content from your PS3 system's hard drive if you use "Restore PS3 System.
If all these fixes fail to work you can contact sony at:
http://www.uk.playstation.com/Support/PS3
or
http://www.us.playstation.com/help-support/PS3
Hope this helps.
Posted on Jun 24, 2009
How to fix ps3 error 80130182
Hi lucious_howa
Turn your router/modem & PS3 off unplug all cables plug them back in & turn both router/modem & ps3 on see if this helps.You may get DNS error code (80710102)... If so try going to the link i have provided and see if that information helps...
http://community.us.playstation.com/message/1661203
Cheers nikki
Please take a few seconds of your time to rate my solution as i have taken time to answer your question the best i can Thank You......
Jan 16, 2011 | Sony Playstation 3 (PS3) Console
I keep geting a dns error code 80710102 on my ps3 what is this
Hi Sir
80710102 PS3 Cannot connect to the router with current IP information - Try rebooting your router
May 19, 2010 | Sony Playstation 3 (PS3) Console
Ps3 DNS error 80710104
not a big problem check out this link here
http://boardsus.playstation.com/t5/PlayStation-Network/Possible-Solution-to-DNS-Errors-80710102-and-80710103/m-p/27590520
Mar 29, 2010 | Sony PlayStation® 3 (80GB) Console
DNS error code 80710102
turn off modem and/or router then reset the ps3s internet settings and that should do the trick
Oct 04, 2009 | Sony Playstation 3 (PS3) Console
PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
Goto the command prompt bar in the start menu type ' cmd ' then click o.k . A black dos screen will appear type in ' ipconfig/all ' and it will the the two servers you need under dns servers but if your doing a wired connection to your ps3 then you need to manually configure your dns on the custom method of setting up your internet connection on your ps3 as if this is auto config that will give you a dns error. Hope that helps ,I can go into more detail and guide you through it if need to .
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
I am getting a dns error (80710102)
I get this problem a lot and i just reset my modem and that usually fixes it for me or if it doesn't work it may just be a problem with the internet provider.
May 06, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Dns error for ps3
O.K. I had just had that little problem out of nowhere 2 days ago! First off Reboot the Modem, then the Router. When they are done turn on the PS3. In the PS3 Menu go to the 2nd Row from the Left and Down to Network Settings. Choose your setup Wired or Wireless. Choose DHCP and AUTO all the way through. If you are Wireless you will need your CODE! When done wait a minute then run the Network test right below in the Menu. You should be Good! This should reset your Network Automatically!
May 04, 2009 | Sony Playstation 3 (PS3) Console
Dns error 80710102
call sony and ask for help you may have to reset the system
May 18, 2008 | Sony Playstation 3 (PS3) Console
PS3 Error Code 80710102
The 80710102 problem is caused by a DNS error, which basically means that your PS3 is trying to navigate the Internet without knowing where it needs to go.
If you follow the link below I have written an in-depth (and free) article about how to fix PS3 DNS errors and get rid of the 80710102 code on your console.
Mar 30, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
371 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
