I have a konica minolta Pagepro 1350w and when i
I have a i have a konica minolta Pagepro 1350w and when i print, i am now getting a black line all the way down the center of the paper?
  • 135 Answers
If it occurs during printing you have a dirty charge wire in your drum unit, there should be a way for you as the user to clean, it may have a charge roller which you cannot clean. if it occurs during copying then your **** glass is dirty under your adf (1/2" strip of glass) clean with soap and water or glass cleaner (no ammonia)
Posted on Aug 05, 2009
Konica minolta pagepro 1350w not feeding full page but get stuck at half page.
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 16, 2014 | Konica Minolta PagePro 1350W Laser Printer
PagePro 1350W won't pick up paper
Clean the rubber roller that draws the paper in with isoproply alcohol, in future, blow dust off top sheet in paper stack before printing.
May 19, 2009 | Konica Minolta PagePro 1350W Laser Printer
Pagepro 1350w prints with streaks on left side
Hello sir; Not thing you can use forever if lifetime is out you need to change otherwise the streak line not go away.
May 13, 2009 | Konica Minolta PagePro 1350W Laser Printer
After printing first page, the second page gets folded as envelope
Hello sir; It seems like registration roller clutch defect, replace it!
May 06, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer won't print anymore
Go to printer faxes check and it might change the default setting and it might default Microsoft Office Document Image Writer. When you print make sure that you are printing to a right printer you can select the printer of your choice by clicking the down arrow. If you select the right printer and it did not print I suggest that uninstall the print driver to the control panel, add or remove and install a new printer driver. make sure set as a default.
Jan 27, 2009 | Konica Minolta PagePro 1350W Laser Printer
Where exactly is the printhead on the Konica Minolta 1350W?
I believe the drum is the problem and not the print head. Remove the OPC drum and check its surface for lines, if there are any lines, you can bet it will be printed on the paper. The print head is beneath the drum, you can see a long glass, that is where the print head sits.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Dec 18, 2008 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta 1350w
If you're getting white lines, you are running out of toner, but if the lines are black, I believe the drum is the problem .Remove the OPC drum and check its surface for lines, if there are any lines, you can bet it will be printed on the paper.
Apr 25, 2008 | Konica Minolta PagePro 1350W Laser Printer
HELP WITH INK LINES DOWN THE SIDE OF PRINTOUTS
If the line is solid from top to bottom of the page, the problem can be in different parts of the printer. Try a different toner cartridge if you have an extra one.
Jul 25, 2007 | Konica Minolta PagePro 1350W Laser Printer
217 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
