Question about Sport & Outdoor - Others
Instructions and Review on American Camper Tent
It seems that the company is either out of business or hasn't caught up to the rest of the world in terms of technology. I have an American Camper Dome Tent Style #14648 and I can't find the instructions. Also I can't seem to find any reviews on the product. Can you help?
  • Samantha Neverson Jun 27, 2009
    There are some color poles. But others are plain metal. It also just has regular rope.
  • Shannon Greer
    Shannon Greer May 11, 2010
    American Camper is a brande that was sold at JCPenney. Generic consumer tents are usually manufactured by some company that makes a wide variety of "cheap" products and providing customer service for its products would cost the company more time and money than they want to spend, and would be pretty difficult to do since they do make such a wide range of things. I couldnt find anything either as far as instructions. Does it have color coded poles, and are they connected with shock cord?
SOURCE: No Instructions
Peg out the "brown" ground sheet of the inner tent and hold it up like a standard ridge tent.
Put the two shorter upright poles on the inside of the compartment (with something under the feet to prevent damage to the ground sheet). Put the 40mm tubes on the spike that pokes through, and then put the ridge pole on the outside.
Everything should then hold in place while you put the fly sheet over the top with the 2 longer poles at the front.......
tip - line up the seam on the fly sheet with the front of the inner tent as you peg it out....
Good luck
Posted on May 20, 2009
  • 272 Answers
SOURCE: Wenzel Monarch Tent instructions
Wenzel does. They e-mailed me one for a different model that I bought on eBay. They're website doesn't offer any help but they were very helpful when I called!
1-800-325-8368
Posted on Jun 03, 2009
SOURCE: ripped outwell tent
log onto http://www.imagescotland.com/scottishmountaingear-home.asp
this is outwell's recommended repairer!
Good luck
ps. putting the pins in is very tricky - needs strength and patience!
Posted on Aug 20, 2009
SOURCE: I have a greatland tent item #15710. This is a two
I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
Posted on Sep 20, 2009
SOURCE: coleman salt lake tent 9 man no instructions please help?
the instructions are useless anyway. you put the red poles through the 2 side bedrooms. the black rods and the black poles with the bends in join together and go diagonally through the middle of the tent. the yellow rods join together with the black poles with the yellow tape round the ends and u fit these from the inside of the front and back entrance then when the tent is up you just hook the bedrooms in. hope this was usefull
Posted on Oct 23, 2010
Instructions for assembling an American Camper Screen Tent #4662
Contact American Camper and request instructions for assembling screen tent #4662.
Jul 25, 2018 | Sport & Outdoor - Others
I have a 6-8 persons tent by NORTH POLE (Northwest Terr.) that i bought several years ago from Walmart and now seem to lack all the fiberglass poles. where can a go to find some?
Hello, Dietrich -
I believe North Pole Ltd., maker of North Pole tents, headquartered at one time in the St. Louis, Missouri area (with products manufactured in China) is no longer in business. I found some newspaper articles dated 2012 and 2013 indicating the company had financial problems and went into receivership (bankruptcy.)
However, I did find a blog from 2013, My Favorite Camping Store,
http://www.my-favorite-camping-store.com/important-update-for-replacement-parts-northpole.html
which provided a link to a tent pole replacement business, TentPole Technologies:
http://tentpoletechnologies.com/
This is a link to another business, Quest Outfitters, mentioned in the blog:
http://www.questoutfitters.com/tent_poles.htm
Best wishes.
Jun 05, 2018 | Sport & Outdoor - Others
I need directions for setup of a Osage 3 room tent
Tent Tips ALPS Mountaineering
https://www.sportsmansguide.com/product/index/alps-mountaineering-osage-3-room-tent?a=599579
BWCA Gear
Alps Mountaineering Osage Three Room Tent
Alps Chaos 3 person tent setup
Just when you are looking for simple instructions, I come along. 1st I cannot locate instructions and don't believe the tent is still made. 2nd, the Alps Chaos 3 person tent setup is a uTube clip that may suffice. 3rd, there are various tips here that suggest the best setup for this tent. 4th and lastly, the zippers seem to be subject to leaking plus it is probably a good idea to have some sealant handy to reseal seams probably as a preventative. It is better to know now rather than be caught in a storm.
Aug 09, 2017 | Sport & Outdoor - Others
American camper gazebo assembly instructions? Where can I find them
American Camper might be able to supply them.
Oct 10, 2016 | Garden
Instruction manuel pdf 16x8 tent sleeps eight people
Videos here
  • Ozark trail 8-person instant tent - YouTube www.youtube.com/watch?v=HOVGTmbKEZ0
    • BY NICK CRISCIONE
    • 5 MIN
    • 86K VIEWS
    2013-06-13 · Video embedded · Ozark trail 8-person instant tent Nick Criscione. Subscribe Subscribed Unsubscribe 15 15. ... Ozark Trail 10 person 3 room cabin tent - Duration: 8...
  • Ozark Trail 8-Person Dome Tent - Walmart.com www.walmart.com > ... > Camping > Tents & Accessories > Tents Ozark Trail Weatherbuster 9 Person Dome Tent with Two Bonus Queen Airbeds Value Bundle
  • Ozark Trail Tent 13 x 9 - Instant Tent - YouTube www.youtube.com/watch?v=PmZx-p3fYkk
    • BY FABIOMEGIATI
    • 2 MIN
    • 286K VIEWS
    2013-09-29 · Video embedded · Ozark Trail Tent 13 x 9 - Instant Tent fabiomegiati. Subscribe Subscribed Unsubscribe 208 208. Loading ... Ozark trail 8-person instant tent ...
  • Setting up my Ozark Trail instant tent - YouTube www.youtube.com/watch?v=xzU9uiPswP0
    • BY THE LONE WOOD ELF
    • 11 MIN
    • 58K VIEWS
    2013-03-30 · Video embedded · Setting up my Ozark Trail instant tent ... Ozark Trail Tent 13 x 9 ... Quechua Waterproof Pop Up Camping Tent 2 Seconds +IIII, 4 Man ...
  • Ozark Trail 12' x 8' 6-Person Dome Tent Reviews ... www.trailspace.com > Hike and Camp > Tents and Shelters
    • 2.5/5
    • 18 REVIEWS
    Ozark Trail 12' x 8' 6-Person Dome Tent. by Ozark ... Following all instructions included with the tent, ... The Ozark Trail 12' x 8' 6-Person Dome Tent is not ...
  • Family Camping Tents : Tents - Walmart.com www.walmart.com > ... > Camping > Tents & Accessories > Tents Tents > Family Camping Tents; Refine. Store availability. ... Ozark Trail 8-Person Family Cabin Tent with Screen Porch. 4.0 stars 4.0 (14) ratings. Free shipping ...
  • Ozark Trail 8 Person 2 Room Instant Cabin Tent - Walmart.com www.walmart.com > ... > Ozark Trail 8 Person 2 Room Instant Cabin Tent Ozark Trail 8 Person 2 Room Instant Cabin Tent; Back. Customer reviews. ... ozark trail tent. 6/10/2015. Customer review by hhhh. 5.0 stars 6/10/2015 by hhhh.
  • How to Assemble an Ozark Trail Tent ' Trails.com https://www.trails.com/how_841_assemble-ozark-trail-tent.html How to Assemble an Ozark Trail Tent. ... The easiest way to do this is to position one person on each end of the pole ... Assembly Instructions for Ozark Trail Tents
  • Ozark Trail 8 Person Instant Cabin Tent Review - amazon.com www.amazon.com/Ozark-Trail-8-Person-Instant-Cabin/product-reviews/... Bought the Ozark Trail 8-Person Instant Cabin Tent for a camping trip that was 1 week away. ... Ozark Trail 8 Person 2 Room Instant Cabin Tent Orange/Tan.
  • Ozark Trail Family Dome Tent 15' X 9' Instructions https://bepesepa.files.wordpress.com/2015/10/ozark-trail-family... · PDF file Ozark Trail Family Dome Tent 15' X 9' Instructions ... Ozark Trail 8 man tent 16 x 10 family dome tent ... Ozark Trail Family Dome Tent 15' X 9' Instructions
  • http://www.bing.com/search?q=Instructions+for+Ozark+8+man+tent&qs=n&form=QBRE&pq=instructions+for+ozark+8+man+tent&sc=0-33&sp=-1&sk=&cvid=7A70D36988944F338B1525CBCDCB0B19
    Jun 08, 2016 | Sport & Outdoor - Others
    Can you help with assembling american tent
    Need more info. Any model number or any numbers or description
    May 19, 2014 | Grilling
    Black hard plastic broke, its where the three poles goes in to hold the tent up. need to find this part so we can enjoy using the tent
    Remington tents were a licensed product manufactured by American Camper. For more information concerning Remington tents please contact them at:
    Avid Outdoors/American Camper
    1-800-782-2843
    Sep 02, 2013 | Camping, Backpacking & Hiking
    Bought this tent from a friend but sadly no instructions on how to erect.Is there anywhere i can download the instructions ?
    Your best bet would be to ask your friend what make the tent is then do a google search for the company or the model of the tent. Typically most companies would be happy to help out.
    Apr 10, 2011 | Sport & Outdoor - Others
    I have a Coleman Savannah 6 tent but no instructions. Does anyone have any instructions on how to erect this tent?
    It does not come with instructions oddly.
    However, start with the external frames and then hang the main inner tent onto it. Finaly drag the flysheet over at the end.
    The middle legs sort of cross over towards each other and meet in the middle at the bottom - this is crucial!
    Hope this helps.
    Paul
    Apr 11, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
    Sport & Outdoor - Others Logo
    1,841 people viewed this question
    Top Sport & Outdoor - Others Experts
    Marvin
    Marvin
    Bill Eager
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
