Question about Polk Audio RTi A7 Main / Stereo Speaker
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and negative connections and the same for the left speaker. I recently purchased a set of Polk Audio RTi A7's and each speaker has tow positive and negative attachments. The instrucions are not the most informative, but talk about Bi-wiring, or using separate speaker wire connections for high and low frequency section. The pre-amp will allow the use of two separate speaker systems. I have never had to use both and usually used speaker system A. Can I do as I have done before and attach a speaker wire from the pre-amp speaker system A to one right speaker positive and negative connection and do the same for the left or do I have to connect speaker wire to the two positive and negative connections on the right speaker using speaker system A and then do the same for the left speaker using speaker system B?
  • elvira1214 May 11, 2010
    No the problem is not resolved, but I am not interested in the premium plan!
    fares
    Problem Solver:
  • 6 Answers
Bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Posted on Sep 13, 2010
  • 6 more comments
  • wilson_beaul Sep 13, 2010
    bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: how to bi wire polk
You mean "buy-wiring"?
Before you go investing in boutique speaker cable (times two) read up on biwiring.
It's a bogus electrical theory to get you to buy more speaker wire.
http://en.wikipedia.org/wiki/Bi-wiring
I don't see that capacity on this receiver.
http://www.theaudiocritic.com/downloads/article_1.pdf
Posted on Jun 25, 2011
Connect skytec subwoofers passive speakers
Be sure the sub pre-out is intended to drive a powered sub (RCA to RCA). Is there a sub power indicator on? If not, there may be a blown internal fuse. Also some custom speaker configurations such as speaker size can override what you think you want to do.
Feb 01, 2014 | Pioneer Audio Players & Recorders
Polk pad5000.5 amp going into protection
Jake I am having the same problem What was the solution if you don't mind me asking
Apr 21, 2013 | Polk Audio PAD5000.5 900W RMS, 5-Channel...
I have recently aquired bose 520b acoutimass panray base module. can this be connected and work with my 2 pairs of bose 901's.i use pioneer SPEC 1 & SPEC 4{ power amp/pre amp}
Don't you mean "502B"?
Specs:
http://pro.bose.com/pdf/pro/brochures/panaray_502_b/b_panaray_502.pdf
http://pro.bose.com/ProController?url=/pro/products/panaray/panaray502b.jsp
http://pro.bose.com/pdf/pro/manuals/panaray_502_b/ig_panaray_502b.pdf
Why do they call the SPEC-1 a PREamp when it seems to be an INTEGRATED AMP with speaker outputs and all?
http://sportsbil.com/stereo/spec/
I'm going to assume one of the numbered, presumably volume-controlled outputs (1,2) goes to the 901 Active Equalizer and on to the SPEC-4.
The OTHER numbered output could feed the missing Panaray Digital Controller and then, presumably, another amp but like many a 901 owner I've heard of, you COULD skip that part for the 502b and hook them to the unmodifed amps available in the SPEC-1 and see how it works out.
Jul 19, 2011 | Bose Audio Players & Recorders
DSW PRO 600 not getting signal from receiver. Why?
You don't name the electronics, which can be the source of the problem. See #3.
1. If you suspect the cable why don't you just swap in another RCA cable? BTW: there's no such thing as a "subwoofer" cable. Monster makes their money on those beliefs. Cables don't wear out but they can go bad if one or more conductors fails. Oxides devolp at either end which can inhibit conductivity. Remove each end and reinsert it with a twisting motion.
2. Maybe. You need to ensure the sub is defined. Run speaker level check. If no sound at the sub, prove the LFE/sub channel has output by running the RCA cable to a recorder or your TV (low volume). If there's no signal, duh, no speaker will work with it.
3. Mmm, not if it's exhibiting the same problem as the old one and the Polk 450. Have you looked at the setting of the Standby/Auto/On Switch? And the Power Mode LED's? Red is bad.
Mar 31, 2010 | Polk Audio DSW PRO 600 Subwoofer Speaker
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
Pioneer audio receiver pre-amp output
It is possible then that the root cause may not be electrical, but acoustic if you're noticing the issue from your listening position.
If you can run a channel test signal identically one channel at a time by positioning your meter less than a foot away and exactly the same distance with each speaker and the level differs by more than 1/2dB, then it's not the acoustics.
Dec 24, 2009 | Audio Players & Recorders
If the power light on this 1200.1 polk amp turns
i had an amp that did the same thing your amp should not be doing that i dont know how old it is but mine had internal overload switch in it which kicked on if the amp was getting to hot and in my case i would say it was because of i had the amp bridged to a set of of some 100rms 4ohm speakers very nice speakers but by bridging the amp i was over loading the ohm load to the speakers and that was cause of my amp light staying the color that its was it was an old alpine amp with duo B circuitry but i hope you get your situation with this amp straited out check your contecions and if its bridege make sure the amp itself is not over heating cause that can be a problem you dont want mess with that.
Oct 27, 2009 | Polk Audio PA1200.1 Car Audio Amplifier
Cuts out at higher volume
Your amp might now have enough power to push the subs or you need to get a better amp kit that will deliver the power the amp needs to operate at a high spl lvl
Mar 04, 2009 | Car Audio & Video
Pioneer spec 1 and spec 2 hook up with RG 2 processor and audiosource eq 1
preamp out---------to equalizer in-------------equalizer out----to amplifier in-----------amplifier out----------to loudspeakers.
Jun 12, 2008 | Pioneer Audio Players & Recorders
Polk Audio RTi A7 Main / Stereo Speaker Logo
549 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
