Question about RTO 110cc Basic Manual ATV # ATD-125C
What oil does my 110cc bike take - RTO 110cc Basic Manual ATV # ATD-125C
  • 241 Answers
Use oil designed for motorbikes and NOT cars! The oil for bikes is designed to work with wet clutches to prevent clutch slip. Halfrauds do a good range and it's cheap enough. I use their own 10w 40 semi synthetic and change it very regulary without any problems so far. Also used it in both my Husaberg motards without any problems.
Posted on Jun 22, 2009
2 Suggested Answers
highspeedsan
  • 61 Answers
SOURCE: 110cc pocket bike carberator
That tube would be the overflow tube. Your carb float is sticking open and allowing fuel to flow in constantly. You need to take carb apart, clean needle valve, and inspect or replace carb float.
Posted on May 01, 2009
Wireing for a sdg pit bike
110cc sdg pit bike is not getting any spark what are some causes that it isn't getting spark please help!!
Aug 19, 2012 | Pit SSR 110CC Pro Beginner Bike
What kind of oil do i put in engine
motorcycle 4 stroke engine oil 20w40, get it from bike shops, if you use car oils the clutch may slip.
May 26, 2011 | Pit SSR 110CC Pro Beginner Bike
My pit bike wont start my plug keeps gettin full of prtrol and oil and it wont tick over.
take the carb off clean it out then have a play around with the fuel air mixture,that should fix it.
Mar 16, 2010 | Pit SSR 110CC Pro Beginner Bike
110cc pit bike; The kick start kicker used to
Hello - i don't know whether you have sorted this or not, but ill help you anyway. Well.. First of all to get to the kickstart mechanism, you need to drain the oil. Get an oil tub, or a metal jug, or anything along those lines and place it underneath the engine..
Underneath the engine there is a big bolt which should have a red rubber washer, well.. undo that. The oil will drain out of it, tilt the bike left and right to make sure it's all out.
Now you undo the bolts, holding the clutch cover on, this will reveal the clutch. In the middle of the clutch there is a ring with teeth on it, bend them out and the clutch will just pull off, also there is a circlip so be careful and dont lose it. Now it's time to take the whole engine casing off, just undo all of the bolts, and keep them in order because some are different sizes. There is a large gasket so make sure you dont rip it!
There it is. The spring mechanism, if you want to go further, you will have to take the cylinder off to split the engine to get to the gear box.
Jan 14, 2010 | Pit SSR 110CC Pro Beginner Bike
Apr 21, 2009 | Pit SSR 110CC Pro Beginner Bike
Pit bike
Black is usually a sign that the motor is running rich. A carb adjustment would be in order.
Apr 18, 2009 | Pit SSR 110CC Pro Beginner Bike
Engine oil type
ther is no need as it is a 4stoke engine but if it is a new engine make sure u run it in and dnt over heat it
Apr 04, 2009 | Pit SSR 110CC Pro Beginner Bike
110cc blowin smoke
the engines getting hot you need the right amont of oil to cool the engine , it has to b the rite oil too,go to your loacal bike shop and tell them your bike details,ok
Mar 29, 2009 | Pit SSR 110CC Pro Beginner Bike
RTO 110cc Basic Manual ATV  # ATD-125C Logo
452 people viewed this question
Top RTO Cycling Experts
Michial Gueffroy
Lloyd Carter
Gregg Mahin
Gregg Mahin
Are you a RTO Cycling Expert? Answer questions, earn points and help others
