Question about GE Advantium 120 Convection/Microwave Oven
The interior light is out on our GE Profile Sensor Micorwave Oven. I don't see any directions on how to replace it. Can you help? The model number is JE 1860CB 001
  • GE Master
  • 9,098 Answers
You have to remove the outer cover to replace the bulb in this model.
The bulb is located in the air duct that covers the magnetron on the right side of the unit.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven (entered as JE1860CB01 without spaces) here.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores or you can order them ahead of time here.
Posted on Jun 24, 2009
Direct replacement for pvm2070 microwave
The control panel assemblies for these touch screen models can now be repaired affordably if you have issues with seeing or setting the clock and operating it, etc. See details here.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Aug 28, 2014 | GE Profile PVM2070DMWW White Spacemaker...
Control panel not responding to touch -- NOT in locked mode!
Sounds like you have a shorting membrane keypad, or there any be moisture or grease in the controls.
To remove the controller to check for grease and moisture, see the video here.
We would need your full model number from the tag in the cooking cavity or elsewhere on the oven to help you further, and our advice is free.
Please post a new help request with the full model number.
Jun 09, 2013 | GE Appliances 30" Trivection Built-in...
Bought house with GE Profile Convection Oven. Do not know proper cooking directions, nor how to work many of the features. Also no light bulb in it & would like to know which one to buy. Need manual t
GE has the manuals for most of their appliances on their site: http://www.geappliances.com/service_and_support/literature/ . Just enter the model number and click Submit.
The direct link to the manual for the JVM1790 Over-the-Range Convection/Microwave oven is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40480-1.pdf . GE only lists the JVM1790CK, JVM1790BK, JVM1790WK and JVM1790SK.
I hope this helps.
Nov 10, 2011 | GE JVM1790 Convection / Microwave Oven
I need to replace the interior bulb on my GE profile model jvm1850dm2vv microwave oven. Can I access it from the area where the replaceable filter is?
The oven interior bulb is on the top. Look closely at the grille above the door. There are two recessed screws that hold the grille in place. Remove these and carefully pull the grille straight out. You may have to wiggle it a bit - it's a tight fit on most of those I've serviced. Look in the center of the oven above the door. There is a sheet metal cover held in place with one or two screws (usually one, plus a plastic tab going into a slot in the sheet metal). Remove this screw and pull out the sheet metal. You will see the light bulb and the microwave stirring plate motor. Note that the instructions say you should unplug the oven before changing the light bulb. GE's lawyers are afraid you'll stick your fingers in the wrong place and somehow get shocked if you don't have the power removed.
Jan 31, 2011 | GE Profile Over-the-Range Microwave
GE Profile mod # JE2160WF03 does not heat up and the interior light does not come on but the timer runs as though it was operating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 16, 2010 | GE Microwave Ovens
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE profile spacemaker mircoware oven change interior light bulb
Check behind the grill on the front top of unit. you can remove it by takign out a few screws from the top. There may be an access door there, if not unit would have to be pulled down and the case taken apart.
Dec 02, 2009 | Microwave Ovens
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
GE Advantium 120 Convection/Microwave Oven Logo
197 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
