Question about Frigidaire ATF6000ES Front Load Washer
Need to clean the pump out. How to acess. AtF 6000.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 121 Answers
Remove the front bottom cover to access the pump. Remove the two hoses. Make sure you have a pan to catch the water from the hoses. You will be able to remove the objects after the hoses are removed.
Posted on Jul 10, 2009
SOURCE:
Have a 2004 f150 and when put in reverse it clings
Gud day please try to check the atf level and the atf,some times atf need to be replaced and need to clean or replace the atf strainer
Sep 21, 2012 | 2004 Ford F150
Someone put motor oil in power steering fluid
drain all the oil in your power steering system then fill it up again with atf.
May 27, 2010 | 2004 Saab 9-3
How many liters ATF for a 96 sentra automatic transmission?
a drain and fill is about 3.5 litres.if you pump it out completely including the torque converter,about 10 litres
Jul 18, 2009 | 1996 Nissan Sentra
Need manual
You can get info on your keyboard/mouse series 6000 from this page.
If you scroll around this page, you should be able to find downloads (if available) along with a full tour of the features.
http://www.microsoft.com/hardware/mouseandkeyboard/ProductDetails.aspx?pid=109&active_tab=systemRequirements
Mar 28, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Whirlpool deut washer - is the a lint screen on washer like the top loading washing? If yes how do you clean and service the lint screen? Thanks.
there s a"button trap" located on the side of your pump assy, behind the lower acess panel ( youll need to remove 3 torx 20 screws from the from bottom of machine ) after emoving the panel oull see the clean out directly in forn t of you. BE WARNED THERE WILL BE WATER behind that acess point grab a towle!!!!
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Car started making noise and the wheel became hard to turn
Is the belt on the power steering pump tight or loose does the pump makes a huming noise when turning steering all these are causes of hard to turn steering belt need to be (tight) on pump and pump must not be huming when turning steering add fluid if needed and play with steering to see if help if not need to replace pump
Nov 12, 2008 | 2003 BMW 325
How to clean out your frontload kemore washer basket that is inside the pump
you ll need to remove the lower acess panel you find the pmp there, remove the hoses and clean out all the debris.UNPLUG UNIT LIVE WIRES TO PUMP AT ALL TIMES!!!!!
Oct 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Atf 6000 front loader not spinning or draining
HI .you probably have a no drain problem. remove bottom panel. the pump is on the right. put drain hose on the floor, in a bucket, drain water out. check the pump. remove the hoses to the pump. clean out. thanks the appliance doc please rate my answer.
Oct 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer won't drain completely. gives me an error code E20. affinity atf 6000
YOU NEED TO CHECK FOR A BLOCKAGE IN THE PUMP OR THE PIPES LEADING TO THE PUMPS.ALSO CHECK IF THE PUMP PROPELLER IS SPINNING CORRECTLY AND IT HAS NOT BEEN DAMAGED.GOODLUCK.MOHAMED
Sep 16, 2008 | Frigidaire Washing Machines
Cleaning out debri in pump
if youve acess below the filter screen ther is only 2 more screws holding down 2 more covers giving you acess to the chopper assy, this is where youll find broken glass and stuff hitting against hte chopper try to break up.. the first of 2 covers lifts right off,,, the second will require sorta prying up and off, beyond this no real acess to any more
Apr 03, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
Frigidaire ATF6000ES Front Load Washer Logo
108 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
