Question about Garmin nuvi 260W GPS Receiver
I have a Motorola dual voltage cell phone charger (5V output) with the correct connector for the back of my Garmin 260W. It seems to charge the battery perfectly fine. Is this OK for the battery? Should I use a different charger with a higher voltage output?
  • Garmin Expert
  • 343 Answers
I would not use that charger. Use the cigarette light charger that came with it or for sure a Garmin charger.
Posted on Jan 17, 2010
My garmin nuvi 260w want hold a charge
bad battery or voltage not reaching from the charger--I would test for voltage first from charger or if using lighter adapter the fuse in it.
Nov 06, 2012 | GPS
Nuvi car charger problem
the connector is defective in the GPS, this is a common problem, it must go back to Garmin dfor repair
May 28, 2010 | Garmin nuvi 260W GPS Receiver
Hi, I have a motorizr Z3 phone whose charger failed. I have run out of warranty and hence I went to a store and the guy gave me another Motorola Charger that is of 6.5 Volts. My original charger was of 5.0...
hi, you need to get the same charger if the output is to high then the phone wont put the charge into the battery as it could cause it to over heat, the best place to buy one from would be the well known online auction site you should get one from their for next to nothing and this will then solve the problem.
You know the battery is not at fault as it charges from your computer via the usb lead however the charger you have brought should still charger the battery but may cause it to over heat so to me it seems like their is a fault with the new charger. Its always best to buy the exact type of charger you had in the first place as this ensures the battery is charged properly.
What phone makers do is keep the same charge connector across most of their range of phone but as phones and technology changes they start using different batteries in their phone so they have to change the charging power to match the phones battery, so the charger you have brought is probably for a newer phone with a higher voltage battery, so you need to get the correct type of charger and this will then solve your problem.
Or if you have a car you could buy a car charger as these charge the phone alot quicker as they run off 12volt so put out more amps to the phone but keeping the volts at the correct type.
Let me know how you get on or if you need further assistance ok
Jan 27, 2010 | Motorola Mobility MOTORIZR Z3 Cellular...
For v3 razr charger can you use it with htc touch pro 2? it fits mini usb. Are voltages and amps similar?
USB Voltage is always 5V. That is standard. As far as your charger for your V3, different motorola chargers have different ampere or mA, but I wouldn't worry about it, you cannot overpower the Touch, it just may charge slower if the charger for the V3 is a weak one.
Other than that though, if it fits USB, you should definitely be fine.
Dec 02, 2009 | Motorola Mobility RAZR V3
Invalid battery..
There is too much going on here. For starters, you should only be using Motorola accessories IE batteries, chargers, screen protectors. Now that you have done this, you have actually confused the phone, it is a "smart phone" and because of this, it is able to identify the different battery/charger. You have to send this to Motorola of for a quick fix or buy a new phone.
Oct 11, 2009 | Motorola Mobility MOTOROKR E6
L7 unable to charge
All cellphone run on Lithium Ion batteries. These batteries, by nature(physics) have a max charged voltage of 3.4 to 4VDC. So, of your charger, or USB cable, has less than about 5 VDC, then either charger is defective, USB cable(if charging from PC USB port) is not a FULL USB(has data leads only wire, 5V power wire not carried through, PC does not supply 5V power to USB because it is turned off by a PC setting option, or a non-powering USB Hub or other device is in series with PC and Phone.
Are you sure you have identified the GND wire correctly? Measurements must all be made with one lead of your VoltMeter referenced to GND. Another consideration, some Windows Mobile phones will not charge off the USB cable unless the latest version of WM ActiveSync or Mobile Device software is loaded and running on the PC. These WM phones also will not charge from just any AC USB generic charger. Charger has to be for that particular phone, or phone manufacture, to be 'recognized' before provideing charge.
The
Feb 20, 2009 | Motorola Mobility V710
I game my parents a garmin 260w with just the car charger.
I would only us the Garmin charger. Why take a chance. They are fairly cheap. Plus you need the car charger since that's where you use it most of the time. The batteries don't last all that long.
Dec 26, 2008 | Garmin nuvi 200W GPS Receiver
Not charging brought new charger still not workin
The battery may have reached end-of-life. Try getting a new or refurbished battery.
Jun 13, 2008 | Samsung Cell Phones
Motorola razr v3 won't charge
have you tried measuring the output voltage on the charger?? if not... use a multimeter to check if there is a voltage coming out on the charger.. if there is... you doomed.... the charging module (charging IC) on your phone is fckd..
Jan 11, 2008 | Motorola Mobility RAZR V3
Charging with Cell Phone Charger
Well , maybe yes ,maybe not.
I will recommend this for your NUVI 660:
http://www.gpsmart.ca/item733.htm
$25.00 CDN
Dec 20, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
289 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
