Question about Dremel Variable - Speed Multipro Rotary Tool 395
Dremel multipro stopped working. I used it for a hour, letting it cool down, but now will not start
rowdy45176
  • 2176 Answers
SOURCE: worn front bearing on Dremel Multipro
To speak to Dremel about bearing call 1-800-437-3635 and also ask to speak with their tech service, this is all I could find
Posted on Dec 24, 2008
  • 3 Answers
SOURCE: Dremel 395 rotary tool - not working
it is the coupling inside of it called a flex coupling and it seem s like it is made of wax or something. tomorrow i will go to home depot to see if they carry metal ones that won't break.
Posted on May 29, 2009
  • 165 Answers
SOURCE: Dremel MultiPro Model 395 was used to cut out
Drywall dust has ruined your tool. It seizes up bearings and bushings like you wouldn't believe.
Posted on Feb 28, 2010
  • 468 Answers
SOURCE: How do i take the bit off of a dremel multipro
unscrew the collet nut, and then if it's still stuck, tap the end of the bit on the table or something solid. It'll come loose then.
Posted on Mar 16, 2010
  • 86 Answers
SOURCE: I don't know how to change the bit on my dremel
Push the pin on the side next to the tip and hold it while Your wrench is turning the hex shaped piece around the bit that is what is holding your bit in. this should help as i am a proud owner of a Dremel. Hope this helps . if you have any further questions write back.
Posted on May 06, 2010
My Dremel sijmply stopped working suddenly. Where do I begin? Brushes?
If you have a volt/ohms meter It is a process of elimination. First unplug tool and remove the brushes turn the switch on and check for continuity to the brush holders and if none work backwards start with the cord and then the switch etc until the problem is found.
Jun 24, 2011 | Dremel Variable - Speed Multipro Rotary...
As I was using the tool the motor was over heating so I turned it off and now it won't start. Is there a reset for it?
it failed. there is no rhyme or reason. Even a new anything can break at anytime. If it doesnt turn on after it cooled down no use fixing it.
Aug 12, 2010 | Dremel Variable - Speed Multipro Rotary...
How do I attach tools to my Dremel?
hello. You loosen the arbor at the base of the shaft closest to the tool. There is a tiny wrench in the kit that came with the dremel, or you can use a pair of pliers to loosen it. Joe
Apr 17, 2010 | Dremel Variable - Speed Multipro Rotary...
Dremel 395 motor just stopped
if you cant afford a new one, and you are mechanically minded Id say why not give it a crack and open it up, could be something simple least it will give you some idea.
Sep 02, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Dremel 395 in the middle of drilling sea glass and the collet and bit stop turning while the motor is still running fine! GRRRRR Thanks for any suggestions!
sounds like the rubber connector between the motor and collet.i use rubber tubing and hot glue to keep it working. bad news is you have to disassemble it to install a new connector.
Jul 13, 2009 | Dremel Variable - Speed Multipro Rotary...
I own a Dremel model 395 type 5 variable speed and it suddenly stopped working. I was wondering if it was common for the switches to go bad or if it's known for other parts to cause it not to turn on.
I would recommend going to Dremel.com and asking their tech section about this. I have one also and mine works fine other than a small amount of heat at the spindle area.
Jun 17, 2009 | Dremel 395 Variable Speed Multipro Rotary...
New Dremel 300 stopped working. What's wrong?
Something amazing just happened! On my monitor screen, window popped up that said, "ASK A QUESTION - LET OUR EXPERTS SOLVE YOUR PROBLEM FOR FREE".
I couldn't resist getting expert advice for free, so I clicked on the window. I was immediately taken to a magical world where I can pay for expert advice. I opted not to pay for expert advice. The next day, I was asked if the help I received was helpful. So here I am posting this response. I haven't received any expert advice yet, but when I do....!
Jun 14, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Mar 30, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
228 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
