Question about HP PSC 1410 All-In-One InkJet Printer
The printer will not stop spooling a document. It
The printer will not stop spooling a document. It will not cancel
    President:
  • HP Master
  • 1,996 Answers
Try to follow the steps in this article and see if you have better success. Click here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 21, 2009
Can't cancel printing jobs on Samsung SCX-4655f
Hello Lulian,
Provided you have the correct software and driver/firmware update then the ONLY thing that can cause this is the RAM buffer.
Yes I know that software on Win 7 can sometimes "loose" the odd icon, but with the printer problem you have I know its not that.
What is going on is that the on-board memory is buffering everything to the printer. What this means is that you can stop it at the printer (as its all there) but the software on the PC (IF its up to date) cannot do anything as all its been doing is spooling the file to the printer.
If you can....you could look through the printer booklet and see if there is a way to switch off the buffer which would then mean that the print job would be spooled to the printer via the PC bit by bit and the software would be able to stop it.
But before you do all that.... just go and manually look for the firmware and software upgrade and then see if that solves it.
Hope that helps you and if so please rate me.
Regards
Nov 11, 2013 | Samsung SCX Office Equipment & Supplies
HP 1500 will not stop Printing
Printer of all types connet to a computer and make use of a spooling service on the computer. You may need to go into the Printers and Faxes section of the computer from the Start button and open up the printer you are using and right click on all the documents that are listed there and click on cancel. There is a relationship between printer and computer with handshaking so you need to cancel and let the printer be connected to cancel the jobs. Pull out the paper tray might be a way to have it stop printing while to cancel the jobs. The cancel or clear on the printer only affect the jobs held in the memory on the printer and then as soon as that is clear the next job from the spool comes in. Clear printer spooling and then the printer should stop.
Jan 30, 2013 | HEWLETT-PACKARD Hewlett Packard Products -...
Pimxa mx340 document won't stop spooling
try removing the power cord to the printer buy turning off the power point to try and clear the printer's memory .
Jun 10, 2017 | HP PSC 1410v All-in-One Printer
My daugther is trying to print but the documents are coming out side ways and the printer is printing the same thing over and over. I tried to cancel the printing , cut off the printer, unplug it and is...
hi,
you need to give the following commands at the run
you can get it from the start menu..
in it give the following code
one by one each line
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
it actually cancels the print jobs and deletes the contents in the buffer..
you should give the files to print again....
if it helps you please give a vote....
Mar 02, 2010 | Brother MFC-7340 All-In-One Laser Printer
Having problems deleting pending documents
Assuming you have a modern windows pc, You will need to manually stop the print service. Do this by running the command "net stop spooler" from the "run" line. Then go to "C:\WINDOWS\System32\spool\PRINTERS" and delete all the files from there. After these files are gone, start the spooler service again by running "net start spooler". You should be all set after that.
Jun 09, 2009 | Office Equipment & Supplies
Cannot print with Lexmark x4875, Windows Vista OS.
You need to cancel all print jobs for a printer, you must have permission to manage documents on the printer.
1. Open printers by clicking the "Start" button , clicking "Control Panel," clicking "Hardware and Sound," and then clicking "Printers."
2. To open the print queue, double-click the printer you are using.
3. Click the "Printer" menu, and then click "Cancel All Documents." Depending on the printer, the item currently printing might finish, but the remaining items will be cancelled.
Next, you may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 4800 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
Apr 17, 2009 | Lexmark X4875 All-In-One InkJet Printer
The printer is a HP Deskjet F4100 it gives a document name.... then there is a status and it says deleting...... the question is --How do I remove the deloeting?
You have to cancel the document in the spool: click on the small icon of the printer in the task bar (it is probably in the right end), right click on the document and select cancel.
Dec 11, 2008 | Office Equipment & Supplies
Printer will not print page 2 of a cancelled document, nor anything else since
you need to stop and restart your print spooler service. From the control panel, select administrative tools, then services. find the print spooler, right click and stop. then right click and start.
This should clear out the stuck print job. and free up the printer.
Sep 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Unable to Cancel Documents in a Print Run
if you want to stop a print run simply press the stop button on the printer
next go to the control panel and get to the add a printer section
click on the printer and open up see what is printing
highlight all in the print queue and delete it there no print queue , nothing to print
to be sure and not waste paper remove all but 1 sheet and press the start button
keep using that paper until what is spooled in the printer memory has been used
Mar 24, 2017 | Canon BJC 4400 InkJet Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
HP PSC 1410 All-In-One InkJet Printer Logo
162 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
