Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
Water dispensing problem
I just installed a new filter. I have water to my ice maker but no water out of the water dispenser. I took apart the coupling under the door and i get water to there. Is there another solenoid inside the door. What could this be?
  • 1 more comment
  • Anonymous Feb 08, 2008
    I have the same model and the same problem. I replaced the filter in the refrigerator and the inline filter I installed in the basement. This did not fix the problem. Does anyone have a solution to this?
  • Anonymous Nov 26, 2008
    Same problem here.
    I will run a hair dryer on it to see if it thaws and verify the issue.
    Where is the heat tape applied to keep it un-frozen?
  • timothy678 Nov 26, 2008
    Thanks GEsucks.
    And GE dos indeed sucks ( out loud ) !!! I have the same
    model refrigerator and called GE, at the number supplied on 26 Nov 08
    and got the exact same reply. That their is a fix, installing the heat
    tape at your expense. Even though GE knows of the design flaw.
    This is not the only GE product I have had problems with that GE
    knew of and would only correct at the expense of the owner. That
    is a GE over the oven pacemaker microwave oven
    model # JVM1650SH01that stopped operating the (program timer)
    the computer that controls the programming of the device. This
    failed just 9 months after installation. GE dos ****. Please keep me informed at
    Problem Solver:
  • 5 Answers
Contact GE and notify them of the problem. Also let them know that you have located numerous other cases of the problem online of people with the same problem. They will set up a service call and will cover the cost of the parts.
Posted on Aug 03, 2008
  • 3 Answers
OK guys, GE does have a solution to this problem and it's EXPENSIVE. I goofed and called GE repair. $263 later it was fixed. Here's what I've done to villify them:
General Electric Company March 31, 2008
3135 Easton Turnpike
Fairfield, CT 06828-0001 Attn: J. Immelt Dear sir or madam, or whoever opens this because I know Jeff Immelt won't be the actual person to open it. This has already been sent to GE Corporation Appliance Park 6, Room 129 Louisville, KY. 40224 so don't send it to them. Send it to someone who may actually do something about this problem. I have a GE refrigerator, Model GSS25WGPAWW, S# AF 217252 which has had a continuing problem for several years. My first error was in not reporting this sooner. My home is in a gated community in which the developer used GE appliances exclusively. What I have determined now (after I paid for the repair) is that many residents have had the exact same problem: the in-door water dispenser freezes solid. The second mistake I made was calling GE repair to fix the problem. I was charged a total of $ 263.15 for the repair; $ 63.30 for the part, a flat rate of $79.95 for the repairman to show up and then $105.00 labor cost plus tax. Our community has an Internet based communications system ( Googlelist) and I posted the following message there. . My fellow residents responded that GE did fix many of the same problems at no charge after they call GE Customer Care rather than GE repair. Several others have paid for the repair. I then reported this to your sales department up until the 25th of March , I have received no reply. ____________________________________________________________________________ TO: Just thought you'd like to know: I live in a gated community with over 1400 residents and they all got the following message: Posted on Googlelist-at Herons Glen So my water line to the in-door dispenser kept freezing up. I'd have to turn the fridge off and open the freezer door for up to 5 hours for it to melt. Then 3 or 4 days later it would freeze again. So the GE repair guy came and installed a $63 part in about 20 minutes. It was a heat tape applied inside the dispenser cover. Now for the fun part: $79 just to show up and then $105 "labor" ??? That's about $315 per hour - my kind of job. Oh yea, another $14.90 in taxes. Once I had the part number, I found the part on-line for $42. Forget about it really being a manufacturing defect that should be covered by warrantee. GE does not care! They advertise how "energy conscious" they are and then solve a defect with a heat tape that adds heat to an appliance that's supposed to be cold! Go figure! If this offends any ex-GE employees....GOOD _____________________________________________________________________________________ When I subsequently called GE customer Care on March 25th I was told "we have no recalls on that model and there is nothing we can do". I've gone on-line and searched for "GE water dispenser" problems and, WOW, you've got lots of problems. On March 26 I got a reply from From: They gave me a Tracking Number and another phone number to call 1-888-348-7563. I called that number on 3-27-08 and got the same answer: "we have no recalls on that model, have a nice day". My question is: Will GE do something about this? I have $ 263.15 out of pocket cost, a copy of the repair bill is enclosed, for what appears to be a design flaw and that flaw has been repaired for others "at no cost". Sincerely, Tom Morookian 20729 Mystic Way No. Ft. Myers, FL 33917 239-731-3452 encl: (1)
The real problem is that the water line is supposed to be installed against the front panel of the freezer door. During assembly they don't do this so some of the lines are against the inside edge of the door, they then "foam" the door and they freeze. The heat tape does fix the problem and you can do it yourself. I'm "GEsucks" for a real good reason. I've posted this on several web-sites and I'm looking for a lawyer to file a class action suit!
Posted on Apr 21, 2008
  • 100 Answers
No there isn't another solenoid in the door but remember that the waterline is running through the freezer door so if your freezer is to cold or if the channel the waterline runs through in the door is running to close to the inside of the door(usually happens in produstion when they inject the foam in the door it moves the channel) it will freeze your waterline.
Posted on Nov 03, 2007
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
P.O. Box 2370
Cleveland,TN 37320-2370
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
Feb 24, 2017 | Refrigerators
No Water going in to the fridge
Hi Norm,
Most fridges don't need a motor to run in order to dispense water. A simple on / off solenoid on the water line (same for the ice maker) that makes a click when changing from off to on and on to off is usually all anyone hears (the ice maker makes rumbling sounds and you can hear ice falling into the bin - too).
Check for ice. If it has a maker and it is making ice, the problem could be a defective water dispenser switch, solenoid or other circuit component or wire. If no ice, I'd suspect a filter or water supply issue.
Make sure the filter is fully inserted and twisted into place. Many filters have marks to align when 1) inserting and 2) to let you know when it is installed correctly. When sure it is installed correctly - try to dispense water again. Many fridges will dispense water without a filter. Check your manual before trying this though! If not working still, remove the filter and try to dispense water. If you're able to dispense water, the problem is either the installation of the filter or the filter itself. Try to re-install it correctly. Try to dispense water again.
If it still doesn't work - call the plumber back and ask why there's no water. Or - try this yourself:
Locate the point of attachment to the domestic water supply that the plumber used. There should be a valve to turn the water on and off. If off, turn ON. Try to dispense water again.
If that doesn't work - check to see if the fridge has pinched, kinked or crushed the water supply line. You may need to move the fridge forward to gain access to the water line and connection point on the fridge. Repair or replace the line as needed and route in such a way that moving the fridge in or out will not cause it to damage the line again.
Nov 06, 2015 | Refrigerators
Ice maker does not dispense ice through the door
Hello. I had the same problem. I replaced the auger motor(around$95) 3 times and would only last about a little longer than a year. I bought the 4th one but this time, I wanted to diagnose the issue. So it turns out that the auger motor goes installed with the impeller upwards. What was happening was that if a piece of ice would stay in the dispenser chamber and melt, the water would go into the auger motor eventually causing the auger casing to get full of water and slow it down or short it out. I took the casing apart and noticed that there was a small space between the motor and the casing. I drilled 2 nice sized holes in the dimple of the new motor very gently as to not drill into the impeller motor and installed the auger. To this day, 3 years later, no more having to buy new auger motors. Hope this helps!
Mar 10, 2015 | Refrigerators
How do I "Prime the Water Supply System" refereed to in use and care guide that came with my new Kenmore French Door Bottom Freezer, #253.70413411. Cannot find instructions in the manual only reference to...
Assuming you followed the water line installation directions and you have water available to your new refrigerator/freezer here is the rest of the "priming" info you requested. (basically it tells you how to run a bunch of water through the system by filling cups or glasses to remove any debris and/or air...
Automatic Ice & Water Dispenser
Priming the Water Supply System
1. Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle. 2. Keep the glass in this position until water comes out of the dispenser. It may take about 1½ minutes. 3. Continue dispensing water for about three minutes to flush the system and plumbing connections of any impurities (stopping to empty the glass as necessary).
Ice Maker Operation & Care After the refrigerator is installed properly and has cooled for several hours, the ice maker can produce ice within 24 hours. The ice maker will fill the ice bin from the rear. You must dispense some ice to force the ice forward in the bin. This will allow the bin to fill completely.
Turning the Fresh Food Ice Maker On and Off Ice production is controlled by the ice maker's On/Off icon on the control panel. Press and hold the "Ice Off" icon for three seconds to turn the ice maker "ON" or "OFF". The ice maker is turned off when the LED above the "Ice Off" icon is illuminated.
Using the Ice Maker after Installation Before making ice for the first time, be sure to prime the water supply system. Air in new plumbing lines can result in two or three empty ice maker cycles. Furthermore, if the system is not flushed, the first ice cubes may be discolored or have an odd flavor.
For proper dispenser operation, recommended water supply pressure should fall between 30 psi and 100 psi. Excessive pressure may cause water filter to malfunction.
NOTE The water dispenser has a built-in device that shuts off the water flow after three minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle.
IMPORTANT On occasion, unusually small ice cubes may be noticed in the bucket or in dispensed ice. This could occur in normal operation of the ice maker. If you start seeing these more frequently, it may be an indication of low water pressure or the water filter needs to be replaced. As the water filter nears the end of its useful life and becomes clogged with particles, less water is delivered to the ice maker during each cycle. Remember, if it's been six months or longer since you last changed your water filter, replace the water filter with a new one. Poor quality household water may require the filter to be changed more frequently.
IMPORTANT Your ice maker is turned on at the factory so it can work as soon as you install your refrigerator. If you cannot connect a water supply, set the ice maker's On/Off icon to Off and turn off the water supply valve; otherwise, the ice maker's fill valve may make a loud chattering noise when it attempts to operate without water.
Hope this helps. Randy
Mar 02, 2015 | Kenmore Refrigerators
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
Water despenser
The water dispensing valve may not be functioning, if the valve buzzes or hums when the water dispenser is pressed the valve may be mechanically deficient, if there is no sound whatsoever the switch for the dispenser,the dispensing valve coil or its electrical connections may have failed.
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dispenser problem
nope. if your ice maker is making ice, then there is no problem with your water filter.
i'm thinking you have a problem with the micro switch that is being triggered when you press the dispenser. or the board where it is attached to choose from water to crushed or cube...
either one of those but definitely not the water filter.
tnx 4 using fixya,
Oct 31, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
 Is the ice dispenser stalling while dispensing “crushed”
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
the water line is frozen inside the door. very common ge problem. you can defrost the dispenser area with a hair dryer. it takes about 30 min to do. it will freeze up again. if the frig is less than 3 years old, even though it out of warranty you can argue with ge and youll get a new door to fix the problem
Nov 26, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
295 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
