Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Steering column How do I get the steering column off my craftsman riding lawnmower? the gears are stripped.
  • Dwain Pippen May 11, 2010
    What is the model # under the seat? Starts with 917. Then I can tell what steering system you have.
  • 513 Answers
Take the side pannels off of dash there are a few bolts & the steering column is held in by a long pin if i can further help e-mail me wade at wadembly@aol.com
Posted on Jun 28, 2009
How to make gears/teeth on lower part of steering line up on 268-H T Wheel Horse line up? Rmove deck, orwhat? There is some wear on the teeth, & was bumping last time I mowed. Now, won't turn at all.
There is a spacer/bushing on the very bottom of the steering column. With wear the bushing fails and lets the steering column/and gear on the bottom of it slip down to the point that the gears don't mesh. Replace the Bushing.
Sep 14, 2015 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Lawnmower tractor turns more to the left then to the rightt
look at the plastic connector where the steering shaft meets the main gear the plastic wears out and the gears jump out of time its a $15 part at sears parts online
May 25, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a sears craftsman riding lawnmower 5 years old. It will steer only hard to the left and will not turn to the right. the steering wheel turns but the mower does not. any suggestions
I had the same problem with my 15 year old Craftsman lawn tractor. I tried to adjust the steering travel but it gave me marginal relief for a year until the steering failed with my steering wheel spinning freely and the wheels free to go left and right. The left bias for steering indicates that the steering shaft pinion weld was shearing prior to failure.
I took the steering apart and found that the drive pinion gear was sheared off the end of the steering shaft at the weld. I replaced the shaft and sector gear to fix this issue.
This fix requires good amount of mechanical disassembly to get the replacement parts in place so you might need to go to a shop to get a mechanic to fix this if you aren't set up for this kind of fix by disconnecting the mower deck and jacking up the front end to access the steering gear assembly and steering arm links.
Mar 26, 2011 | Sears Craftsman 46 in Mulching Tractor...
I have a 42" craftsman tractor... when you turn all the way to left the wheels get stuck... can I adjust anything?
What happens when you turn right? Does it turn as sharp as it used to? Almost sounds like the steering gear teeth have slipped and now it is steering to far to the left. You'll have to check the steering sector gears at the bottom of the steering column.
Oct 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Steering wheel gear is stripped
Please for the love of god tell me you have an answer to this, same problem, sooo angry, hit me up at reid72@aol.com pleeeesee
Jul 15, 2010 | Troy Bilt 175HP Manual 42" Riding Mower
My steering wheel will not turn towards the right. it sounds like it stripping gears. How do i repair it?
raise the hood and follow the steering wheel shaft down ti the gears. u either have gears stripped or a worn out bushing.get parts and replace or have a lawnmower repair person do it.
May 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hit Object - Steering gear shifted....decreasing right turn to 15 degrees...increased left turn to 90 degress. How best to reset?
look down at the base of the steering column and you should notice that the steering is like two gears faceing each other. when you hit an object hard enough it is possible for the gears to jump out of alignment, simply loosen and realign, gears should be facing each other equally, to give you the same turn radius, left and right
Oct 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sears craftsman lawnmower has steering linkage poping out of socket
It should have a keeper on the top or your linkage is bent, how does it compair to the other side or is this the linkage under the steering wheel?
Oct 22, 2009 | Craftsman Garden
We have a Sears Craftsman riding mower 917.258671 the steering wheel has a lot of play in it and has turned a full half turn when going straight. In other words the top of the steering wheel is at the...
The steering assembly your mower has is very difficult to repair. Thank God they no longer make that type. Forget about trying to tighten that screw, it won't solve your problem anyway. Believe me, you should take it to a repair shop.
Oct 03, 2009 | Craftsman Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
402 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Mike Squire
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
