Question about Teac CD-RW880 CD Player / Recorder
Won't open, clicking noises
I,ve had the same problem along with a host of other problems: locked up, fault codes not in the manual, finalized cd that won't read or play, unit stopping after a half hour and locking up. It's useless now.
I checked and it's still in warranty.
Thanks anyway.
Posted on Jun 22, 2009
Tip
Requirements RedHat Linux (should apply to 7.x and up) This tutorial covers...
Requirements
This tutorial covers changing your hostname in RedHat Linux without having to do a reboot for the changes to take effect. I’ve tested this on RedHat 7.3, 9, Fedora Core 9, and RHEL 5.3. It should work for all the versions in between since they all closely follow the same RedHat configuration. What’s the point of this tutorial? Never reboot if you don’t have to and keep your uptime intact.
Make sure you are logged in as root and move to /etc/sysconfig and open the network file in vi.
cd /etc/sysconfig
vi network
Look for the HOSTNAME line and replace it with the new hostname you want to use. In this example I want to replace localhost with “MyServer”.
HOSTNAME=MyServer
When you are done, save your changes and exit vi. Next we will edit the /etc/hosts file and set the new hostname.
vi /etc/hosts
In hosts, edit the line that has the old hostname and replace it with your new one.
10.33.44.55 MyServer
Save your changes and exit vi. The changes to /etc/hosts and/etc/sysconfig/network are necessary to make your changes persistent(in the event of an unscheduled reboot).
Now we use the hostname program to change the hostname that is currently set.
hostname MyServer
And run it again without any parameters to see if the hostname changed.
hostname
Finally we will restart the network to apply the changes we made to /etc/hosts and /etc/sysconfig/network.
service network restart
To verify the hostname has been fully changed, logout of your system and you should see your new hostname being used at the login prompt and after you’ve logged back in.
Quick, painless, and you won’t lose your server’s uptime.
on Jan 13, 2010 | Computers & Internet
Tip
Change your Hostname without Rebooting in RedHat Linux
Requirements
This tutorial covers changing your hostname in RedHat Linux without having to do a reboot for the changes to take effect. I’ve tested this on RedHat 7.3, 9, Fedora Core 9, and RHEL 5.3. It should work for all the versions in between since they all closely follow the same RedHa tconfiguration. What’s the point of this tutorial? Never reboot if you don’t have to and keep your uptime intact.
cd /etc/sysconfig
vi network
Look for the HOSTNAME line and replace it with the new hostname youwant to use. In this example I want to replace localhost with“MyServer”.
HOSTNAME=MyServer
vi /etc/hosts
Save your changes and exit vi. The changes to /etc/hosts and/etc/sysconfig/network are necessary to make your changes persistent (in the event of an unscheduled reboot).
hostname MyServer
hostname
1995 Sunfire Engine Hood stuck closed
lever catch on hood latch is sticking .light thump with hand ' in area of h hood catch should pop hood
Jun 13, 2012 | 1995 Pontiac Sunfire
Error code 13019
look at the article on this forum it should help you http://support.apple.com/kb/TS2830
Dec 07, 2011 | Apple iPod touch
Whirlpool duet GHW9100LW won't start, won't give error code. No locking noise when trying to start, and makes a couple of clicks "in the back" when pressing start in troubleshoot mode. No...
Hi, I've only just come on line to see and glad that you have identified the problem yourself- as you say persistence pays. I'm not even sure that I would have been able to suggest anything myself other than 'are you sure the lock and sensor are physically working?' ;-0) John C
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I just recieved a system fisher dac-9345 and the cd changer wont eject the cds what could be the problem
Sounds like you've got a problem with either the Drive Motor, Drive Controller or Drive Belt.
It could be an easy fix but it depends on the where the fault is.
Does it make any noise or effort to open the tray?
May 12, 2011 | Audio Players & Recorders
Teac CD-RW880 CD Player / Recorder Logo
157 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
