Question about Homelite Mighty Lite Lawn Trimmer
My homelite mighty lite edger starts, but will only run on either half choke or run for 10 or 15 seconds and then dies. The choke filter looks clean.
  • 59 Answers
The primer bulb may have a crack in it
Posted on Jun 25, 2009
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
You may have to replace them.
If you need further assistance, just let me know.
Jim
  • Jim Parker
    Jim Parker Jun 28, 2009
    Did this solution solve the problem?
    Jim
  • Jim Parker
    Jim Parker Jun 29, 2009
    Thanks for the rating!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Blower will start just find but will only stay started on half choke
may need a tune up--check air filter change if necessary,check and clean he exhaust screen.plug if fouled --fuel mixture --carb may need cleaning or rebuilding
Aug 16, 2016 | Homelite Mighty Lite Lawn Trimmer
Hard to start my homelite mighty lite, any clues please
Remove the air filter. Get some carburetor/choke aerosol spray at the auto parts store. Open the throttle wide open on the machine while spraying cleaner into the carb throat. A couple short bursts is all you need. Then try to start . If the engine runs till the cleaner burn off, that is a start. Do this a few more times and then try to start the machine normally. If it doesn't start, then it probably needs some type of fuel system maintenance done (filter, gas lines, carb gaskets and diaphragms, carb cleaning etc.).
Jan 18, 2011 | Homelite Mighty Lite Lawn Trimmer
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
It won't run prorerly
I had the same problem. I took it to the dumpster and used my old echo that I purchased in 1986. The Homelite was 2 years old. My sugesstion is to dump it.
Apr 06, 2010 | Homelite Mighty Lite Lawn Trimmer
How do i adjust carbuerator
Start your adjustment by turning both screws (gas and air) all the way in and then back them out one and a fourth turn. Start from there. Hope this helps.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
My mighty lite will start but it runs on full choke but it stops
Your carburetor needs cleaned you had old gas in it this cloggedup your jets and made the diaprams hard witch will not move enough to pump enough gas to keep engine running off choke.
May 15, 2009 | Homelite Mighty Lite Lawn Trimmer
Engine dies when excelerating - more gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Nov 17, 2008 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
578 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
