Question about Classic Accessories Classic Bicycle Dynamo Generator Unit 12v 6w
HI THERE, I HAVE MOUNTED AXA-BASTA DYNAMO ONTO MY BIKE, CONNECTED THE SIMPLE WIRES,FRONT AND REAR, COST £25, BUT NO LIGHTS WORKING, IM NOW PULLING MY HAIR OUT CAN SOME KIND SOUL HELP ME. WEE JOE.
  • josephsalina Jun 22, 2009
    HI POB-H. YEAH IVE DONE THAT, THE TWONK IN THE SHOP REFUSES TO CHANGE IT, AS HE RECKONS I,M DOING IT WRONG, THANKS FOR YOUR PROMPT REPLY, YOUR A GOOD LAD.
  • Paul Hutchinson May 11, 2010
    Have you grounded the dynamo and the lights? as they both rely on being connected to the frame etc. on bear metal.
5 Suggested Answers
  • 2692 Answers
SOURCE: I would like to know how to wire a bottle dynamo to bike lights
The bottle dynamo rides against the tire turning it . The wires from it go to the front liht. The same two wires  may also be hoked to a back light. The  direction of flow is not that important but most put the same (one of the two ) wire on the center connection. If you generator has only one wire, then the light(s) will have to be grounded through the frame.
Posted on Jan 09, 2009
  • 74 Answers
SOURCE: I would like to know how to connect the dynamo lights on my bike
You want to attach this item to the rear of the bike. Mount it so that when you hit the switch the item lean over and hits the rear tire. Hook up the wire to the lights and your all set. Now I can tell you that with this item NOT engaged you will be able to ride with no problems, but with this item engaged it will give you resistance. Meaning that you will know how much harder it is to pedel the bike. I had this item and then went and purchased a battery power item.
Posted on Jan 16, 2009
Sparxxxs
  • 7 Answers
SOURCE: i have tried to wire my bottle dynamo to my new
try to fix it tightly so there wud be more friction between tire and your bikes dynamo....
Posted on Nov 18, 2009
SOURCE: HI, I have a basta trio dynamo kit. I can't get it
Hi Cathy. I have the same dynamo but no instructions, can I please have a look at your instructions.
I fitted the dynamo, but I'm not sure how to connect the wires. And I don't know which direction the wheel has to turn in.
Have you got yours working?
Posted on Nov 19, 2009
Touched wires for headlight together now no power?.
Have you checked the bulb is good? If that's okay, it has to be a bad connection on the bulb holder or you missed a blown fuse that maybe looks okay.
May 31, 2015 | 2006 Bikemaster-2008 Kawasaki Ex650a Ninja...
How to wire a Lucas dynamo
easy for a old timer like me ,the larger D terminal goes to the regulator and the smaller field terminal is the warning light ,now inside the main wire goes to one of the brushes and the other one goes to the casing ,to test hold casing on the NEG battery terminal and the pos one is connected to large connection and the motor will spin like a electric motor .To reverse polarity for a older + earth you reverse the connection casing to positive and the D and F connections joined together and connected to the NEG and spinm the motor ,positive earth dynamo ,simple isnt it
Nov 16, 2013 | Cars & Trucks
2009 ninja 500 not starting and headlight does not go on when on.
Hi i have a 750 zxr ninja and i parked it up at work went to go home from work would not start i took the seat of to have a look and checked the fuse 30 amp just behind the battery its on the the rear left hand side just behind the battery it was blown put a new green 30 amp fuse in turned on the ignition started first time hope it helps
Apr 20, 2012 | kawasaki Ex500d7 Ninja 500r Motorcycle...
No power from starter solenoid to starter, also headlights are not switch onas normally
most newer bikes have a fuse on the selenoid itself. if not check the fusebox for bad fuse. also the kickstand switch will not let the bike start in gear with the stand down.
Jan 29, 2012 | kawasaki Ninja Zx7r Zx9r '94 To '04
I WANT TO KNOW HOW TO CONNECT MY BYCICLE LIGHT GENERATOR
The generator, or dynamo, fits onto the back fork bar of the bike. The top, which rotates, should be close to the tyre of the back wheel. There's a little lever which you press downwards. When you press it the dynamo moves in against the tyre so that when you're cycling the movement of the wheel causes the top of the dynamo to rotate. To stop it, or turn off your lights, you pull the dynamo back out from the tyre. You need to adjust the dynamo so that the top of the dynamo makes contact when the lever is pressed but doesn't when it's pulled back out.
Normally a dynamo has only one wire which connects to the lights. You need to use lights designed for it. This carries the positive current. The frame of the bike usually acts as the negative. Some dynamos may have 2 wires. In this case the positive connects to the centre of the light and the negative to the outer.
Apr 13, 2011 | Cycling
1985 700 vulcan , the bike starts , runs , everything works but the headlight , fuses look good , what am i missing?
Try taking off the switch. use a jumper wire across the leads. if your headlight comes on, replace the switch.
Aug 29, 2010 | Clymer Kawasaki Vulcan 700 Vulcan 750...
HI, I have a basta trio dynamo kit. I can't get it to work, instructions aren't very clear and I'm not sure if I'm missing a bit...
Oct 11, 2009 | Cycling
Jan 09, 2009 | Classic Accessories Classic Bicycle Dynamo...
Classic Accessories Classic Bicycle Dynamo Generator Unit 12v 6w Logo
660 people viewed this question
Top Classic Accessories Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Classic Accessories Cycling Expert? Answer questions, earn points and help others
