Question about Panasonic TC-P50S1 50 in. Plasma LCD HDTV
Scratch on plasma screen
Small scratch on the screen. looks like plastic is raised up. does the TC-P50S1 have a protective screen? Can I repair the nic/scratch?
  • mixy60 Jun 21, 2009
    thank you for the suggestion...it seems to be working except now there are almost fingerprint like marks on the screen. anyway to remove those?
  • 439 Answers
You should be able to make the scratch become invisible using a white eraser. A pink one will work, but the white one works better. Just simply erase the scratch, it may take awhile, but your basically buffing the surface down even again making the scratch un-noticeable.
Posted on Jun 21, 2009
Can I fix or cover up small scratch on my iPhone?
discuss the problem with a phone repair shop as it may have a glass screen before the led screen that can be replaced
Jan 16, 2016 | Apple iPhone Cell Phones
What does it mean if i get 6 blinks on my tc-p50s1
i guess it would be the PSU board,remove the back lid an check for any blown capacitor and replace it yourself - having an ESR meter will help to detect the other bad ones that will not last long
Jun 05, 2014 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
TC-P50S1 will not power on after power surge
try unplugging from power for at least 30 seconds. if that doesn't work, it may be a fuse. see the picture for the fuse location.2_25_2013_1_41_21_am.jpg
Feb 24, 2013 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
I have a Panasonic Model TC-P50S1 plasma TV and the red indicator light continuously blinks and the TV never does come on. Can this be fixed?
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
May 28, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
WHILE WATCHING MY TV TONIGHT I HEARD A LOUD POP AND NOW NO PICTURE JUST BLINKING RED LIGHT
10 blinks for this tv is not always an A Board issue. It can be a problem with the power board as well. A technician should look at the set to dertermine where the problem lies otherwise it is just a guessing game of inni minni miny moe.
Apr 03, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
I have a Panasonic TC-P50S1 Plasma HDTV. I am trying to run my PC into it via DVI to HDMI. It will work, sort of, for a little bit. Then eventually the screen flickers and I lose the picture completely. I...
I BELIEVE THE ISSUE IS THE RESOLUTION THAT THE VIDEO CARD IS SET AT. IF YOU ARE USING THE SAME RESOLUTION AS THE PC, IT WON'T WORK.
TRY SETTING THE VIDEO CARD RESOLUTION AT 1920 X 1080. THIS SHOULD WORK.
ED P
Jan 20, 2010 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
I have a 3 inch scratch on my plasma tv that happened in a move. I think it is a glass screen. Is there any way to cover or fill this scratch. It isn't very deep but it bugs me that I can see it.
You must determine whether or not the scratch is on a protective fromt screen or the panel itself. I don't know your specific model, but some of the LGs have a front glass behind which is the actual panel. If that is the case with yours, you can replace the front glass. If it is only the panel, then there is no way to repair other than replacing the panel which is VERY expensive.
If you wish to try something, go to a local auto parts store and purchase a windshield repair kit. This will contain an optically transparent epoxy that can fill in the scratch and make it at least less noticable similar to filling a scratch or crack on a windshield.
Dan
Mar 06, 2009 | LG 30FZ4D TV
Small scratches on my plasma ,
There are 2 possibilities that may work. I can't state for sure as I don't know the make and model.
1) Some sets have a protective front "glass" that resides in front of the actual panel. That protective sheet can be replaced.
2) If it is the panel itself, the repalcement cost will likely be more than replacing the entire set. You can try using a windshield repair kit to fill in the scratch. Since the material contained in that kit is optically the same as glass, the scratch should be filled in and not be quite as obvious. This may not make the scratch completely disappear, but it should help.
Good luck,
Dan
Jan 22, 2009 | Televison & Video
My plasma tv has several really deep scratches on the screen, how can i go about repairing this?
There are liquid solutions for filling LCD scratches
it's basically a plastic material that fills the scratch.
Big scratches are more of a problem. I am assuming that your
Plasma screen has a glass surface and that it's only scratched,
not physically broken. You may also try glass polishing compounds
for filling and polishing chipped windshields. Be careful, try it on a small spot first to make sure that you don't dissolve any plastic anti-reflection coatings etc.
Good luck
Apr 18, 2008 | Computers & Internet
Scratches on Plasma TV Screen
My daughter scratched my TV Plasma with a Pen - It now has scratches. What can I use to get rid of these scratches.
Mar 26, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Panasonic TC-P50S1 50 in. Plasma LCD HDTV Logo
478 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
