Hi, I have an 1985 Chelsea attic fan. The motor is still working fine, and it is turning the main bolt on which the fan blades are hung. This main bolt turns very fast, at the speed of the motor. The fan blades start slowly, and they used to accelerate to full speed, but now they just stay at a slow speed. What could be the problem? Thanks, Joe
  • 439 Answers
It is the fan clutch. Like in a truck with a full time fan, it has a clutch that accelerates the fan as it is needed. Your clutch on the fan has probably burned out.
Posted on Jun 21, 2009
Vornado fan Model CR1-0023 , Type 750 I bought this fan used 3 days ago. Seemed to work fine but not as powerfully as another new Vornado shop fan I have. Today the fan blades stopped turning. I can...
I have had the same model for almost ten years, and have had to lubricate it twice - both times when the fan stopped rotating. It's obvious that Vornado never intended the bearings to be serviced, but if you're patient, it can be done. You must remove the front louver section (press the three clips inward gently). Then firmly pull the fan toward the front, off the shaft. Then remove the four nuts on the front of the motor housing - you'll note that the bolts appear to be free-floating, but that allows re-assembly after the bearings are lubricated. When the nuts are removed, firmly pull the front of the motor housing toward you. This may require a firm pull or GENTLE prying, as the rear bearing sometimes doesn't want to let go. When you have the front portion of the housing and shaft out, hold the housing and pull the shaft out of the front bearing. Again, this may require a steady firm pull straight back. When the rotor & shaft are free, you'll need some very fine emery paper to remove the varnish that's built up on the shaft (it's unmistakable where to clean the shaft.) And I never attempt to do anything with the front and rear bearing themselves - too much work, and cleaning the shaft does the job for me. Then clean everything up carefully and lubricate the shaft where it enters the bearings (and maybe a drop in the rear bearing itself.) I use a very fine machine oil that I bought at Sears, but I think any good oil would work. Then, it's re-assembly time - shaft into front bearing, shaft into rear bearing as the motor housing is put back together (lining up the bolts), four nuts on the bolts & tighten (firmly, no gorilla), press fan back on shaft (don't force it too far on - it'll stop when it's in the right place), plug in and check, re-attach front louver (just press - the clips will snap easily into place.)
Jul 27, 2011 | Vornado CR10023-06 Air Circulator Fan
I just bought a new motor and installed it but now
Centrifugal force.....If you replaced the motor only and not the blades, the blades are likely out of balance or possibly bent. Check for wobble and to see that the shaft is fitting tight inside the blade collar.If there is a bushing on the fan blade or shf itself, check it for play as well
Sep 13, 2009 | Dayton (2C373) Fan
Attic fan problem
The belt may be slipping and reducing the flow of air
Aug 16, 2009 | Heating & Cooling
The fan blade came off my attic fan, a Leslie
Slide the fan on the shaft. Rotate the blade so the allen screw is over the flat side of the blade and tighten it down. That's it! Be careful how far you put the fan down the shaft so it won't hit the motor or the fan shroud.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 23, 2009 | Dryers
Replace old attic fan motor, or replace the entire fan assembly.
I am assuming you replaced your fan by now. However in the future call Gibraltar Industries, they are the ones who manufacture all fans and motors. My attic motor fan also died and I first called Ventamatic and they wanted $65 for a new motor. I then called Gibraltar and they shipped one our for free. 800-527-1924.
Jun 26, 2009 | Ventamatic Gable Mount Power Attic...
Attic fan stops running after one hour
I need to verify you have adaquate air flow, to cool the motor. If you have a window open, and the crawl hole open is there enough air flow into the the attic? It there is enough air flow and it still stops after about an hour, does this unit have a humidistate and a temperature switch on the housing or extension.
If all the switches are working correctly then I could be the motor overloading/heating shutting down and then reseting.
InMrFixIt
Oct 12, 2008 | Ventamatic Direct Drive Whole House Fan...
Dayton Attic fan running backwards
First see if the switch has a reverse position. Sometimes you turn the fan assembly in the frame, sometimes you turn the whole frame around. Take the cover off the wiring compartment to see if there are instructions there. Also check on the name plate on the motor, there may be instructions there. Attic fans are usually engineered to blow out.
Aug 02, 2008 | Dayton (2C373) Fan
Broken mount attic exhaust fan
buy new blade or keep soaking shaft.collar with rust penetrant,
Jul 25, 2008 | Ventamatic Gable Mount Power Attic...
Attic roof vent fan- brand unknown. need motor and blade
Any Blade will be ok if it will fit shaft and they all should be cosistant and of course the higher the amp the better quality.I like the Pro 3 model at Home depot but I believe the Pro 1 gable is the 12 inch blade,pro 3 is 17 inch houseing and maybe 12 inch also.
Please rate jj505 Guru
Jul 11, 2008 | Kitchen Ranges
Need replacement motor for Ventamatic Attic Fan
common motor. get from butler ventamatic or Johnstone Supply if you have an account. Hint, buy a whole new fan for $60; cheaper then buying piece by piece, then you get a new blade,motor and tstat for a little more then motor alone costs.
Apr 26, 2008 | Ventamatic Gable Mount Power Attic...
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
